MonstaS4 Posted November 18, 2005 Share Posted November 18, 2005 I have 2 adjustable tensioners, but no matter which way i adjusted them, i couldn't get them right. The first hole i drilled went straight into the water gallery so i drilled and tapped another further from the centre of the block. In hindsight, the first probably would have been ok with some locktite, but i didn't want to risk a water leak at the time. I have an R33 head and the VCT gear is adjustable from behind, and i bought an adjustable exh gear. Hopefully problem solved. Well i spent a weekend dialling in the cams, so it better be solved! Sky30, it's a 5 speed manual. Link to comment https://www.sau.com.au/forums/topic/15420-r33-rb30-conversion/page/132/#findComment-1727251 Share on other sites More sharing options...
StockyMcStock Posted November 18, 2005 Share Posted November 18, 2005 yeah i think i should buy an adjustable exhaust gear, or get one made up by my lathe man. would be a good investment when i go for the power tune i think. Link to comment https://www.sau.com.au/forums/topic/15420-r33-rb30-conversion/page/132/#findComment-1727988 Share on other sites More sharing options...
Guilt-Toy Posted November 21, 2005 Share Posted November 21, 2005 RB25 n/a head, GT35/40 turbo, 19-20psi <{POST_SNAPBACK}> Youve got to be kidding me right ???? What specs are you running ? 270k km and 20psi with gt3540 ??? I got my rb30det which has done about 30,000km so far with a smallish turbo now I too am going the GT3540 .82 with tial 38mm gate with a top mount manifold and 740cc injectors (still off the road) Got some questions for ya... When does boost come on ? is it laggy ??? How does it sound ? got any pics??? be very keen to find out more Do you have .82 rear ? when do you get full boost by ??? whats you fuel economy like?? tell us abit about it.. thanks Link to comment https://www.sau.com.au/forums/topic/15420-r33-rb30-conversion/page/132/#findComment-1733668 Share on other sites More sharing options...
sky30 Posted November 22, 2005 Share Posted November 22, 2005 Youve got to be kidding me right ????What specs are you running ? 270k km and 20psi with gt3540 ??? I got my rb30det which has done about 30,000km so far with a smallish turbo now I too am going the GT3540 .82 with tial 38mm gate with a top mount manifold and 740cc injectors (still off the road) Got some questions for ya... When does boost come on ? is it laggy ??? How does it sound ? got any pics??? be very keen to find out more Do you have .82 rear ? when do you get full boost by ??? whats you fuel economy like?? tell us abit about it.. thanks <{POST_SNAPBACK}> Why would i have to be kidding??? Its .82 rear housing, makes 20psi at about 3400rpm. Link to comment https://www.sau.com.au/forums/topic/15420-r33-rb30-conversion/page/132/#findComment-1734430 Share on other sites More sharing options...
mr_rbman Posted November 22, 2005 Share Posted November 22, 2005 Why would i have to be kidding???Its .82 rear housing, makes 20psi at about 3400rpm. <{POST_SNAPBACK}> I've seen this car in the flesh and on the dyno, he aint kidding its a sleeper monster! Link to comment https://www.sau.com.au/forums/topic/15420-r33-rb30-conversion/page/132/#findComment-1734513 Share on other sites More sharing options...
Cubes Posted November 22, 2005 Share Posted November 22, 2005 I want an sound file of when it was on the dyno, the initial little punch shaun gave it sounded awesome.. Link to comment https://www.sau.com.au/forums/topic/15420-r33-rb30-conversion/page/132/#findComment-1734562 Share on other sites More sharing options...
lukits01 Posted November 22, 2005 Share Posted November 22, 2005 Can anyone help me find a set of forged pistons for RB30 that can give me a CR of 8.3:1 or more? was looking at ARIAS but not even rocketindustries have them in stock atm, they only have the flat top piston that give 8:1 CR, any idea how this would drive? Anyone selling these or CP, or Wiseco? Link to comment https://www.sau.com.au/forums/topic/15420-r33-rb30-conversion/page/132/#findComment-1734630 Share on other sites More sharing options...
clean_vl Posted November 22, 2005 Share Posted November 22, 2005 Im thinking of adapting the rb25 oil squirters to the rb30 block. Im just asking if anyone had any pics, of a rb25 block with the oil squirters removed showing the whole location. (I have looked at Cubes guide). Or do u think I’m wasting my time trying to make them fit or is it just impossible. Link to comment https://www.sau.com.au/forums/topic/15420-r33-rb30-conversion/page/132/#findComment-1735845 Share on other sites More sharing options...
SirRacer Posted November 23, 2005 Share Posted November 23, 2005 (edited) Im also interested in forged pistons for a comp ration of 8.5.1 or more Edited November 23, 2005 by SirRacer Link to comment https://www.sau.com.au/forums/topic/15420-r33-rb30-conversion/page/132/#findComment-1738307 Share on other sites More sharing options...
sky30 Posted November 23, 2005 Share Posted November 23, 2005 got any pics??? be very keen to find out morethanks <{POST_SNAPBACK}> A pic of my engine in R32 as it is, makes 312rwkw. Link to comment https://www.sau.com.au/forums/topic/15420-r33-rb30-conversion/page/132/#findComment-1738774 Share on other sites More sharing options...
SirRacer Posted November 23, 2005 Share Posted November 23, 2005 It'll be in an R31, heh.Anyway, I have an R32 RB25DE loom and RB20DET ecu on the way. Should be able to get the RB25DE loom if necessary. <{POST_SNAPBACK}> so the rb20det computer will be able to be tuned to suit the rb30 with no problems whatsoever? i suppose the rb25de runs top feed injectors also? will this also be fine if you upgrade to gtr injectors? and i then presume a z32 afm is necessary (if not a q45) Link to comment https://www.sau.com.au/forums/topic/15420-r33-rb30-conversion/page/132/#findComment-1738972 Share on other sites More sharing options...
mr_rbman Posted November 24, 2005 Share Posted November 24, 2005 so the rb20det computer will be able to be tuned to suit the rb30 with no problems whatsoever?i suppose the rb25de runs top feed injectors also? will this also be fine if you upgrade to gtr injectors? and i then presume a z32 afm is necessary (if not a q45) <{POST_SNAPBACK}> the rb25de injectors are them same style as rb20 and rb26 injectors! Link to comment https://www.sau.com.au/forums/topic/15420-r33-rb30-conversion/page/132/#findComment-1740143 Share on other sites More sharing options...
Cubes Posted November 24, 2005 Share Posted November 24, 2005 Rb25de injectors are rb20det injectors. Same part number, same flow. I ran my RB30DET in on the stock RB20DET ecu, it couldn't handle any more than approx 6-7psi as it would fuel cut. Link to comment https://www.sau.com.au/forums/topic/15420-r33-rb30-conversion/page/132/#findComment-1740251 Share on other sites More sharing options...
SirRacer Posted November 24, 2005 Share Posted November 24, 2005 Rb25de injectors are rb20det injectors. Same part number, same flow. I ran my RB30DET in on the stock RB20DET ecu, it couldn't handle any more than approx 6-7psi as it would fuel cut. <{POST_SNAPBACK}> What did you do loom wise with the conversion? I thought the extra capacity of the head may confuse the power fc Link to comment https://www.sau.com.au/forums/topic/15420-r33-rb30-conversion/page/132/#findComment-1742046 Share on other sites More sharing options...
Cubes Posted November 24, 2005 Share Posted November 24, 2005 What did you do loom wise with the conversion? I thought the extra capacity of the head may confuse the power fc <{POST_SNAPBACK}> Cars are very simple.. The measure how much air enters the motor then puts in say 1 part fuel for every 15parts air. As a result.. the car runs fine on the stock ecu. Obviously limited as the RB25 head flows so much more air, as a result I was hitting fuel cut. The PowerFC handled it quit well. AFRs were pretty much spot on, light load didn't need touching. WOT required a small tweak of afr's around 3500rpm - 5000rpm. Ignition timing had to be pulled out a little due to the back pressure the stock turbo caused on the 3ltr. After putting the VG30DET BB turbo on its taken another 6-7degree's ign. timing at wot. Link to comment https://www.sau.com.au/forums/topic/15420-r33-rb30-conversion/page/132/#findComment-1742266 Share on other sites More sharing options...
lukits01 Posted November 25, 2005 Share Posted November 25, 2005 With regards to the higher RB30 block, how much of this affects the piping around the engine. For example, intercooler piping, exhaust manifold and dump pipe, radiator coolant piping. How much of these needs to be modified due to the higher RB30 block? Link to comment https://www.sau.com.au/forums/topic/15420-r33-rb30-conversion/page/132/#findComment-1744481 Share on other sites More sharing options...
Cubes Posted November 25, 2005 Share Posted November 25, 2005 My std IC piping actually fitted much better; like it was meant to be. Radiator hoses are not affected. Exhaust manifold is not affected, how can it be?! Dump pipe obviously needs modification as the motor sits slightly higher. I paid $60 or something and had them cut and weld in a little spacer so to speak. It all drops in and bolts up much easier than you would expect. Link to comment https://www.sau.com.au/forums/topic/15420-r33-rb30-conversion/page/132/#findComment-1744603 Share on other sites More sharing options...
[200] Posted November 25, 2005 Share Posted November 25, 2005 I got my rb30e bottom end from a R31 skyline. A quick question. Is there ANY advantage of going for an R33 GTR head as aposed to a GTS-t? Link to comment https://www.sau.com.au/forums/topic/15420-r33-rb30-conversion/page/132/#findComment-1744879 Share on other sites More sharing options...
Scribble Posted November 25, 2005 Share Posted November 25, 2005 GTR head: Solid lifters, bigger injectors, bigger ports, better cams, better intake plenum, 6 individual throttle body's for more response... ummm... thats all i can think of for now Link to comment https://www.sau.com.au/forums/topic/15420-r33-rb30-conversion/page/132/#findComment-1744925 Share on other sites More sharing options...
[200] Posted November 25, 2005 Share Posted November 25, 2005 Thanks. I read all 149 pages at work last night. Looks like I will go for the R33 GTR head. Link to comment https://www.sau.com.au/forums/topic/15420-r33-rb30-conversion/page/132/#findComment-1744930 Share on other sites More sharing options...
