i thought i saw in his nick/sig 35 at some point.... anyway wouldnt the 30 be a bit on the small side, whats it like to drive cubes? must spool quick
It feels perfect and doesn't ease up until the 7000rpm rev cut.
Its all in a shade over 3000rpm and making a good 7-8psi by ~2400rpm. Extremely responsive. Perfect roll-on acceleration turbo.
I found the GT35 .82 to lack the roll on response in second gear; it felt as if you would always hang level then click third and hammer away; with the gt30 its instant go.
The GT35 doesn't really make its peak boost much later in the rpm but the transient response in comparison is very very noticeable especially in the lower gears.
To drive it feels less laggy and with more torque everywhere than an rb25det with its std turbo.
And the interesting part is for under 300rwkw with the stock exhaust manifold they both make the same sort of power for the same boost. Which is why I don't recommend the GT35 unless your going a nice exhaust manifold and cams to really make use of the potential.
You really need to drive the two setups both on std exhaust manifolds with std bits everywhere to see where I'm coming from.
Was speaking to Tony Rigoli tonight at WSID and he said they make their own sump adaptors but use 10mm sump bolt holes (same as RB26) not the factory size. He said with the extra weight of the sump/diff the standard RB30 holes aren't adequate.
Thoughts?
10mm bolts on what side of the adapter
plate to block or sump to plate?
theres 17 M6 & 6 M8 bolts holding the plate to the block. then theres 8 M6, 7 M8 & 13 M10 bolts holding the sump to the plate. whice imo is more than adequate
Thoughts?
I used a RIPS plate before Pro Engines started making them, as far as I remember they use the standard holes and have been doing so for years. When I see an RB30 with the bottom torn off I'll believe they need bigger fasteners.
Cheers
I was only passing on info from a highly respected engine builder....
I took the sump of my rb30 this morning, was actually suprised how small the bolts were but then their were plenty of bolts.
Can anyone give me a fairly close estimate on the weight of and RB30DET for freight purposes Complete motor with clutch and GT3540
any recommendations of freight companies more than welcome too!
need to know asap
does anyone know if a RB30DET with low compression RB30ET ACL pistons with a 3 layer cometic head gasket be a interference engine ? or non intererance ?
Would the valves smash the pistons if the timing belt let go?
anyone know?
after getting my RB30E and my RB25DE, and taking the head off the RB30E....What is recommended to be done if im wanting to replace
i.e. measuring/checking etc etc
a)main bearings
b)welsch plugs
c)big end bearings
d)piston rings
anything else anyone recommend to replace bar rods and pistons...
Cheers David
a)main bearings
b)welsch plugs
c)big end bearings
d)piston rings
Cheers David
All the seals ie. sump, rear main, head gasket, oil pump etc...
Make sure u clear the oil feed gallery for the turbo in the block as every na Rb30 I've seen has been blocked with sludge.
Edited by Alf
anyone know?
dont mean to sound rube but what difference does it make? your going to all that effort just buy a decent timing belt and its not an issue
I think the whole thing is, he might want to build a non-interference motor incase the timing belt lets go...
With all the engine failures recorded below I've only seen a couple when the belt let go. Just heard of one this morning but no detail yet. Of the others I know it was either a poor quality bolt in the idler/adjuster and a cam cap galled and the belt jumped a bit (GTR cams into RB20) so I've yet to actually see where the belt has failed instantly and catastrophically. There is usually noise and time to inspect the problem.
    • When you crank your car, and hit it with a timing light, can you see a steady crank timing?
    • Oh, forgot to add, A few months ago I was getting mixture codes and the car was using crap loads of fuel. You could smell the unburned fuel in the exhaust, it was crazy strong. Economy was over 17.5 l/100 and usually around 19. I smoked the engine and found a leaky CCV hose which I replaced and then I replaced my two pre cat O2 sensors, I also replaced the MAF. This fixed my mixture codes and improved my exonomy but I'm still 14 - 15 l/100 when pottering about town so something is still amiss. Throttle response is much better and it has more pep but I'd like to know why it's still so thirsty (and I'm hoping that whatever it is gives me a bit more poke).
    • Car is on factory injectors/z32 maf/ q45 throttle body/ z32 ecu with nistune
    • Hello all, currently finishing up a rb25 swap into my s14. Having issues with starting, car has spark (confirmed by pulling a plug and watching it spark), has fuel(confirmed by checking pulse/voltage at injectors all spark plugs are soaked in fuel). Car cranks over and pops into the exhaust with a heavy fuel smell but no attempt to start or run, I have torn the timing cover off and triple confirmed timing, turned the CAS in multiple spots both directions, attempted to start with coolant temp and maf unplugged, checked my fuel lines and made sure they weren’t backwards, checked voltage at cas/injectors/coilpacks, made sure all the grounds in the harness are connected and added a few grounding straps (1 from chassis to block, 1 from chassis to head, and 1 from chassis to igniter chip) I am getting stumped here. As a last ditch effort I made a full grounding harness tonight that’s going to run from the battery and add an extra ground from the battery onto the coil pack harness/igniter chip/ intake manifold/ Wiring specialties harness ground/ and alternator. I’m hoping maybe the grounding harness will fix it here but posting here to see if anyone has any other ideas on what else I can check. My fuel pressure is unknown right gauge will be here tomorrow.  IMG_3206.mov
    • yeah I was shocked when I checked my spare OEM on and as below that's how they come from Nissan. (side interesting note new NEO gearbox and replacement park lack the brass bush on the tips and its just all alloy) unsure about damage to the box currently back at 1110 to be pulled down/inspected and selector fork replaced as he built it previously and given the never before seen failure on his billet forks he is replacing it under warranty. He said he has used always OEM the keyway tab without issue for years so it could be an unlucky coincidence. I did talk to him about the sharp corners and stress concentration too. Re: hard shifts i got 7+ years out of the OEM one and the fork itself failed not the keyway. so could be bad luck as I said or an age thing + heat cycles in box and during fabrication of billet?
