  • Replies 41
Looks hot, shame it's a drift car... would be better suited to circuit :laugh:
the setup between drift and circuit is closer than one might think. in fact many top level drift cars lap nearly as fast as the track battle cars.
That's fine Trent - I wasn't talking about setup, in fact I know many drift cars do have alot of grip in their setup, my comment is simply that I think it's a shame the car is going to be used for drift and not circuit :ninja:
The [former] JGTC look is awesome ;) can't wait to see it sidewayz.
where the hell does this guy get the money to do this?
this is what?- the third full-race prepped car he's had??
Sponsors, plus George & Theo own GT Autosound here in Adel & it helps if you have friends in the auto industry. Also, like their previous pink S15 drift car this has standard internals, so that would reduce costs as well.
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
