I bigger exhaust system can always pass a noise test, and probably an EPA inspection to, providing its below 90dB at the required RPM, and doesn't go over the level of emissions from the rear of the system.
Hi um i dunno if this helps but i had 3 1/2" catback then i gat the epa notice, so i had a good look at what i had under the car and found a Flange plate just under the the rear axel that had the cannon attatched, so i went to an exhaust place and got them to make the back bit out of 2 1/2" with a nice big quite muffler. It cost me 140 but at least they done what i wanted other places wanted me to replace the lot for 350!. Anyway the test showed a nice quiet 80 db.
I noticed that i had no power, no noise and no fun. so as soon as i passed the test i chucked the cannon back on all better now, and when i get another notice probably next week i already have the solution!
>_<
Thanks for the feedback, because i failed the noise test, im getting a standard exhaust fitted for the next test. I really doubt its 98db, but oh well, the exhaust shop says it is, have to believe him i guess.
Thought i'd mention that my mate got his EPA done and they checked mods under bonnet (checked for pod, (has fmic) and boost controller. Also looked at the exhaust and asked if my mate put it on prior to the test (it's this tiny gay thing i had re-installed that i bought for an exhaust noise test) my mate said nah this was on it when i bought it, last owner was 1 who got the epa. Then did the emissions test (we didnt have time to find a stock ecu so we didn't bother) and that passed luckily >_<
Dunno what he's going to say next time though :(
Your mate nearly caused himself a big drama by telling lies.
Its illegal to sell a car with an EPA on it.
If the officer goes and reports, you'll find you might get another visit, or a please explain
Nahh it hadn't been issued whilst i was the owner, EPA arrived in the mail at his house about a week ago, and it went straight to him but he was saying that it was meant for the car whilst the previous owner was driving it, if that makes sense. Was weird though at the actual EPA joint the guy had my name down so they confused themselves somewheres
I was told that if the car gets inspected again, once it has passed the noise test and have been found for excessive noise and has a different exhaust it needs to go for a full ADR compliance which costs 500 bucks. Anyone has had experience in this?
Unless the officer is writing down exactly what the exhaust was, diameter for diameter.
Then the EPA dont know, how can they? :blush:
As long as you rockup to the test, with the same exhaust as what was noted on the test prior. Then its instant pass either way.
Then the EPA dont know, how can they? :(
I forgot to mention its not the officer that told me that, its actually one of the approved noise testers, as I only went for the noise test instead of the full emission test. But yea i guess you are right, I doubt they know the exhaust layout's design, ie , a straight flow as opposed to a standard one with another box before the rear muffler. Thanks for the help
Cheers
I heard that if your car is manufactured after a certain year you can have a POD without a box, which year is this? Does anyone know?
Please READ this thread. It is already answered quite clearly
Just say you have both a FMIC and PODs and you also have a full engineer certificate what will happen?
will the engineer certifcate allso clear everything including bigger turbos, exhausts, BOV, perfomance mods etc.etc.??
Edited by Shadow01
speaking to a worker from the local exhaust joint tells me under the new VIC LAWS
1st epa free
getting caught and going back to the epa a 2nd time $500bux penalty, because people just keep removing mods=to keep the epa happy then when they get home just put all their mods back on, BOV, pod, loud exhaust whatever is'nt EPA friendly...
1st epa free
What you were told is in essence correct, however. It all comes down do what is documented by police/epa, and as a direct result of this, what they can prove.
Some people have been asking why police take photos of your car when you are defected, it is so they can keep track of your mods. For example if you are continually defected for 2 intake mods, boost controller and/or ecu but every time you get tested by EPA your car passes they will wonder why you keep getting sent back. If the police can prove that you have these mods usually, but are simply removing them in time for EPA test then you can find yourself in trouble.
I have always found that with EPA it's a case of; 'I'ts not illegal until you get caught'. Many cars pass Mcleod with things they shouldn't, (I have personally passed with atmo BOV, aftermarket ECU and variable boost all at once!) you just need to work out what they look for and what they dont.
    • I’m not sure what happened I told them about sonic tunes free OTS tune and the next the I know .. I was booted..   To funny
    • Yea - I mean I've seen my fuel pump which is decades old and uh, while I'm not saying this with real knowledge... but I sure get the ick at using anything in the fuel system that produced the state of that pump. Many years ago I went through multiple pumps (and strainers) before I dropped the tank to clean it out with extreme violence. I'm talking the car would do maybe 50km before coming to a halt, which resulted in me cleaning out the filter with some brake cleaner and going on my way. None of my stuff ever looked like what came out of your fuel tank. I don't think I'd be happy with it unless every single component was replaced (or at least checked/cleaned/confirmed to be clean here).
    • I'm not going to recommend an EBC pad. I don't like them. Just about anything else would suit me better. I've been using Intima pads for a while now.
    • Agreed, and in particular the earth strap that should go from the subframe to the chassis but it often broken or left off. There is a section in the R32 workshop manual you can follow for troubleshooting if you don't see anything suspicious, and depending where you are (there is no location on your user profile) you should be able to get your hands on a second hand replacement unit still if needed
    • Yeah they mention as a R34 for 2.5 Turbo...but then again thos "small" were also for R34 by that different site. But i look into it and that 310mm EBC is for R34 GTT. And by those you linked the specs are the same 🙂    EDIT: I found these on one site here: DBA 4000 series T3 DBA42304S They are 310mm...and it says are for R34GTT...are there good? EDIT2: ok they have pads too.  What "color" should i get for street use? I dont want/need some noisy ones...(and if they are not that dusty that is good too)
