I'm talking about the external-gate it self though
What if you run a highflow turbo or even a stock turbo with an external gate... then no one will know you have a larger turbo - example
taking off the gate, taking off the gate
abu u should be taking off ur gate :D
Just another quick question, Can i still pass the EPA test with my stock catback but still have my 3inch front trust/greddy pipe and turbo dump pipe?
bceause i just connect my catback to them. Its not that noisy but just to make sure.
I failed EPA once with a massive 111DB, what i did is i got the exhaust shop (the one that did the test) to make up a 2 1/4 inch pipe with a normal muffler to replace my cannon. So i had a 3 inch turbo back right down to near the muffler which then went to a 2 1/4, through a normal oval muffler. It just passed at 89DB.
So if he wanted me to pay for the custom muffler pipe he made it would have to pass :)
So if he wanted me to pay for the custom muffler pipe he made it would have to pass :P
Same thing I did. Nobel Park Brake and Clutch did mine. Good service there.
Anyone have some standard RB20 cooler pipes laying around? I need a cross over pipe without a BOV and an intake pipe for between the afm and turbo intake. I can't fit a standard filter box because my intake pipe is a fancy Apexi one. thanks guys.
I have a standard intake pipe and plumb back pipe if you need
Might have some stock cooler pipes laying around
PM me your best offer
:thumbsup:
Thanks abu.
PM sent
Will i get a standard intake pipe to fit my Z32 afm? I imagine that the pipe diameter will be smaller than the afm. Can you interchange afm's with a Apexi Power FC?
You will only get dicked if 1. you have something illegal 2.they find it.
The SAFC is not legal, but if they dont find it you wont get caught. What i'm getting at is take it or, or hide the shit out of it!
If l take out the SAFC ... would that mean taking out all the wiring fromt he ECU back, or just unplugging the unit.
Got a letter from EPA today in relation to a Emissions control system & noise. Exhaust isn't a problem, but not sure what to do with the SAFC.
Hi, I asked this question in a wrong section.
Does anyone know whether dump pipes/visible adjustable cam gears are defectable?
Also, if a cop pulls you over, does he actually go through your car eg., glovebox, etc? I hide my boost controller in there. Can you just unplug it and hide it under your seat or something? Also I heard turbo timers are defectable?!?!
Thanks.
hey just got pulled over 2night by a cop,
just got a few q's...
all the cop did was take two photos, one of my intercoller and one of the pod intake pipe heading out of the engine bay.
when they epa you, do the giv u a canery on the spot?
cause all he did was look at my licence for 10 seconds max, i dunno if he even wrote anything down. then he said u'll get a letter.
then i drove off, i was only pulled over for 30 secs.
any help would be heaps appreciated.
I just cleared my defect today. Relieved that it's all over. Pretty frustrating and vic roads didn't even come out to see the car. After all the work put in getting rwc and taking off mods, it hardly seems worth it.
I don't understand the one intake mod rule. How does having an intercooler and a pod make it unroadworthy? Is it because of the induction noise?
    • Biggest thing is you're okay!   It sounds like between the accident, and the drive home, it was a pretty torturous trip again! On the bright side, you took the opportunity to enjoy the event more from the perspective of a spectator, than as an entrant!   Sad to see so much damage to the car. It really has taken a HUGE hit in the front end. If/when you choose to repair, hopefully the rails are straight (At least from shock tower backwards). Hopefully the extra cage coming through there has save most of the chassis rails, and HOPEFULLY saved the motor too. Best of luck when you eventually get motivated to start pulling it down to check it all out
    • Sounds more like what Brad said, that it's mainly transfer. What pad bed in procedure did you use, and did you replace/machine the rotors, or just swap pads?
    • The stutter is almost entirely in the pedal. I don't feel the brakes release and reapply as you would with ABS engaging but the pedal feels that way, without the brakes releasing. It only lasts for less than a second and the pedal is fine again. It's hard to explain, sorry.  I'll get under this weekend and just double check everything is tight. Fluid is at max where I left it.
    • What bedding in procedure did you use?   When you say stutter, what exactly do you mean? Like it feels like someone letting go of the brakes momentarily and regrabbing them again to get you to stop? Re-reading your post, and that is what it kind of makes me think you're explaining, like theres a little bit of a jolt, likely just as you're reaching a stop. I've only had this issue once. And if its caused by what caused mine, you will want to get the car up on stands again and check it over. Mine was a case of a caliper mounting bolt coming out and letting the caliper rotate on the other remaining bolt and gave play in a wheel as it came to a stop. But not every stop either!
    • Yeop... binned it   This will be a summary will not many pics atm and cbf  Fixed the samsonas - it was totally munched Put a new precision 7675 T4 on with proper split pulse mani Got to Sydney to get to car - drove to canberra to get racecar - drive back to sydney that night Next day all day at Plasmaman putting on new clamps cleaning some things up and adding another large engine oil cooler sitting at the rear above diffuser to keep things cooler Next day - Tuesday - on Dyno - killer wikid awesome pumped out really good numbers - more mid range and on lower boost levels Wednesday - first prac - all day again getting the suspension right - had to borrow front suspension again - out do a lap come in - out do a lap - in - what i had just couldnt handle the load at the more consistent higher speeds - got a lap in at the end of the day that was pretty reasonable  Put it this way that lap wouldve had me in 4th in Pro am for the whole event - with only 700 hp and used tyres Thurs first official prac day - lap out warm up - then entered a hotlap with above setting and 80% effort took corners 1,2,3 and into 4 car felt awesome -  rear came around out of nowhere bang into the wall near front on at whatever 140 kmph Done, over, gone Just one of those how did that happen apparently as all indications show nothing out of the ordinary Got to spend the rest of the time at the event like I hadnt done before - was actually Ok mainly as I had my family and my boy is 9 and got treated like a rockstar Long trip home, lost a trailer wheel in nowhere land, X5 airbag suspension gave up half way across nullabour and rode on bumps stops (its now completely fine) had to do a 19 hr drive day on day 3 as accommodation got screwed up so just had to keep driving till found a town with some Now to reassess - hopefully the motor and other things are OK but yet to be seen too. There is no easy fix there is no i'll just order that part and get it sent - we'll have a talk to people see what can happen and what the go is but at minimum its rebuild from scratch struts forward and alot of time effort and $ should and if I return and if but maybe/ when  I have the cage tied into the front strut towers - if I didnt have that things couldnt been worse you can say its just a front end but if you know what goes into these cars... you'll know what that actually means in reality   Car was very fast. Disappointing we just didnt get to show it Effort doesnt win you races though     Apparently this is motorsport !
