so if you did get pulled over for being too low in a factory fezza... what happens then?
the law CLEARLY states that no point of any road driven vehicle can be below 100mm... (i have looked on the vic roads site and it does not say "except fezza's cos they are cool and hyperexpensive"
when i got defected last week EPA was there and they tested my exhaust and i was 9db over and i am going to make my exhaust and make it more quite and around the legal limit. but im running a PFC in my car and just to be on the safe side if they do an emmisons test im gonna install a stock ecu for the test but having a highflow turbo will it still give a different emissons reading even though its running a stock computer?
An f430 has 4.5 inches ground clearAnce which is like 11cm. I'm guessing it looks low cuz the body is prob the lowest point and not a hanging exhaust
yah, but they have other models too... i'm not sure of fezza dimentions tho...
and the exhaust is not always the lowest point in a car.... mine is a custom job and is all tucked away :)
I'm getting around to clearing my EPA that I got last august.
They only show 2 places for Emissions and noise. Hoppers and Moorabin.
Anyone know of closer to where I live in doncaster east? I heard there was one in McCloud but can't find it on their website.
I have to get an EPA noise and emissions test done fairly soon and was wondering If I could get some advice? I have a R33 gtr vspec series 3, current mods are, -5 turbos, power fc, greedy elec boost controller, nismo fuel pump, fuel pressure regulator and injectors, cam gears, exhaust, and pods
I was planning to remove the boost controller, return the injectors and ecu to stock. I believe that the turbos shouldnt be a problem as they are nearly the same as stock. Do I need to return the fuel pump and pressure regulator to stock, I know Im meant to but will they effect emissions if the stock ecu is controlling them and would the inspectors be able to tell between the stock and nismo items. I will quieten the exhaust and leave it that way. Also if I refit the stock ecu will I need to get the car retuned? And is there a difference between an ecu for a gtr and gtr vspec. Any advice is appreciated. Thanks.
I live in Greensborough and still had to go to Hoppers to get my full emissions test done. Was a major pain in the arse. Apparently the Macleod one doesn't to that kind of stuff, which sucks coz its like 10 mins away from me.
Mcloud do that sort of stuff. They only send you there when you have had prior EPA issues. I've been to 2 noise test and a full emissions test in moorabbin. Then got another EPA and they said I must go to mcloud. Which is better because they don't have a hoist :P
Did you explain the situation?
Just said that McCleod would be a lot easier since I will be towing it there and they said that those 2 places are the only ones I can go to.
Typical Government Agency. Everything is just too hard for them.
    • Yea - I mean I've seen my fuel pump which is decades old and uh, while I'm not saying this with real knowledge... but I sure get the ick at using anything in the fuel system that produced the state of that pump. Many years ago I went through multiple pumps (and strainers) before I dropped the tank to clean it out with extreme violence. I'm talking the car would do maybe 50km before coming to a halt, which resulted in me cleaning out the filter with some brake cleaner and going on my way. None of my stuff ever looked like what came out of your fuel tank. I don't think I'd be happy with it unless every single component was replaced (or at least checked/cleaned/confirmed to be clean here).
    • I'm not going to recommend an EBC pad. I don't like them. Just about anything else would suit me better. I've been using Intima pads for a while now.
    • Agreed, and in particular the earth strap that should go from the subframe to the chassis but it often broken or left off. There is a section in the R32 workshop manual you can follow for troubleshooting if you don't see anything suspicious, and depending where you are (there is no location on your user profile) you should be able to get your hands on a second hand replacement unit still if needed
    • Yeah they mention as a R34 for 2.5 Turbo...but then again thos "small" were also for R34 by that different site. But i look into it and that 310mm EBC is for R34 GTT. And by those you linked the specs are the same 🙂    EDIT: I found these on one site here: DBA 4000 series T3 DBA42304S They are 310mm...and it says are for R34GTT...are there good? EDIT2: ok they have pads too.  What "color" should i get for street use? I dont want/need some noisy ones...(and if they are not that dusty that is good too)
    • Yeah, shame. Maybe  driver's carpet is available 🙏. I am waiting for both amayama and nangun to confirm.
