if he doesnt have one buy one or borrow one, best bet is to buy one as you'll have headaches from teh popo for having front mount & pod as your only allowed one intake mod. same applies for bov should be able to pick up both for under $100.
as for speedo no idea.
Sweet thanks.
So wreckers for the stock air box then? eBay didn't seem to have one.
I just hope the engine passes the compression test on Tuesday! I'm getting excited now!
  • 1 month later...
I recnetly got a series 2 r33 gtst and was driving it home from endeavour hills to hawthorn and got pulled over within 45mins of owning the car, i showed the cop the rwc i got with the car so he didnt really look over it much, however i didnt have any p plates up, hadnt been to pety station to get any, so i got done for no p plates, i thought i was f**ked as being too powerful car for p plate driver, but he didnt mention it, LLuucky, but i havent recieved any letter from vic roads regarding licencing issues and its already been a month, strange?? im hoping someone f**ked up along the way cause i opnly have one point left... aaagggrrr
What are you asking exactly or are you just telling us a story?
well i think people here are unsure about whether they can drive a r33 turbo on ps or not or not, i was just saying that the cop knew i was on my p plates but didnt investigate whether i was aloud to drive the car or not, so maybe p platers are aloud. i had a look on vicroads websit and we r aloud to drive turbos but its limited to 130kw per tonne or something, so my reason for posting is to hopefully clear confusion for other members
What you have posted is factually wrong.
I doubt there are any P platers under the OLD system. (125kw/tonne)
The new system outright bans turbos - that is fact, that is on the VicRoads website.
Your story is one of luck only.
even then a r33 gtst is still over the power to weight ratio anyway
So what about something like a BT-50..
I mean I highly doubt a cop is gunna rag on a kid for driving one as its hardly a performance vehicle , but technically it is a turbo
    • I’m not sure what happened I told them about sonic tunes free OTS tune and the next the I know .. I was booted..   To funny
    • Yea - I mean I've seen my fuel pump which is decades old and uh, while I'm not saying this with real knowledge... but I sure get the ick at using anything in the fuel system that produced the state of that pump. Many years ago I went through multiple pumps (and strainers) before I dropped the tank to clean it out with extreme violence. I'm talking the car would do maybe 50km before coming to a halt, which resulted in me cleaning out the filter with some brake cleaner and going on my way. None of my stuff ever looked like what came out of your fuel tank. I don't think I'd be happy with it unless every single component was replaced (or at least checked/cleaned/confirmed to be clean here).
    • I'm not going to recommend an EBC pad. I don't like them. Just about anything else would suit me better. I've been using Intima pads for a while now.
    • Agreed, and in particular the earth strap that should go from the subframe to the chassis but it often broken or left off. There is a section in the R32 workshop manual you can follow for troubleshooting if you don't see anything suspicious, and depending where you are (there is no location on your user profile) you should be able to get your hands on a second hand replacement unit still if needed
    • Yeah they mention as a R34 for 2.5 Turbo...but then again thos "small" were also for R34 by that different site. But i look into it and that 310mm EBC is for R34 GTT. And by those you linked the specs are the same 🙂    EDIT: I found these on one site here: DBA 4000 series T3 DBA42304S They are 310mm...and it says are for R34GTT...are there good? EDIT2: ok they have pads too.  What "color" should i get for street use? I dont want/need some noisy ones...(and if they are not that dusty that is good too)
