good info guys ^
few months back a padded half cage was legal, now its illegal.... and vic drift just changed its reg now every one must run at least a cams spec bolt in half cage for 2013
:angry:
Gents, the best thing to do is speak to your local roll cage manufacturer. The rules are constantly changing and as I said "I think" which means i am unsure, but at the time (about 5 months ago) it was illegal to run any cage. If anyone has more up to date information, please add it here!
Great write up, from what you're saying about brakes sounds like GTR Brembos into a gtst should be fine but a car like mine for instance would need to be engineered because I don't have ABS and the Brembos are designed for cars which do?
Bloody good question!
GTR Brembo's into a GTST would be a very easy conversion to get engineered. You would have to use the GTR Master Cylinder too. As you are changing the dynamics of the car (even if it's OEM) you will still need to speak to an engineer and potentially get a certificate for this change. As it's a safety system (and a damn important one at that), the chances you need a cert. for something like this is very high. The amount of work required though for an OEM style change such as the GTR brembo is minimal because you can use a very simple justification to state the weight of a GTR is slightly heavier than a GTST, the brake performance is better, therefore fitment onto a GTST using the correct Master Cylinder etc. should be just as good if not better than the factory GTST OEM system. Ends up being a fairly cheap certificate and potentially not even requiring the brake test (depending on the engineer!!!)
IF a GTST came from factory WITH Brembo's then you can fit them without a certificate..... It's a fine line. I think you could potentially get away with it, but.... :D
The fitment of D2 style or Alcons or any other non OEM style disk and caliper will require more calculation/testing/proof to make sure the brake system functions correctly such as:
1. Correct fluid amount if there is a leak in the front/rear, and how big the MC reservoir is to compensate.
2. Swept area of pads and pistons compared to the rears, to achieve correct bias. If you go with OEM ratios, you are pretty safe. The weight of the car is a factor with this. If you are changing the weight dramatically with your modifications you need to change the bias accordingly.
3. Master Cylinder size to achieve emergency stopping G force and provide suitable pressures without locking fronts or rears.
4. Performance under repeated emergency stops. I can't remember what the requirement is, i'd have to look it up, but basically you do a few cycles of 100 to 60 on a 'closed road' and then do one emergency stop of 100 to zero. The G force must be over 0.8 and pedal pressure must be within range, which leads into the next requirement.
5. Pedal pressure. Suitable testing is carried out for an emergency stop with a pedal force gauge. There is a specific requirement for an emergency stop to be a specific force (I can't remember what it is off the top of my head..) The car must achieve a G force of over 0.8 from a specific speed with a pedal force of the requirement to pass the test.
6. Pedal travel must be a certain requirement. You don't want an on/off pedal, and you don't want a pedal that takes a heap of travel to do nothing and not even have capability of providing the correct locking pressure.
7. All the stuff I have forgot goes here.
8. And here too... :D
This does take time for the Engineer and costs accordingly. One option when I was looking at calipers for my 1600 was Wilwood. They make a model that bolts straight onto the R31 strut ears. Unfortunately they weren't street legal because they didn't have an extra dust seal on the piston which is a requirement for ADR compliance. The Engineers know all of this! I ended up using R33 GTST calipers and R31 rears as the pad and piston areas are similar to a car with the same engine (200SX) and the master cylinder I used was S14 Silvia. The weight bias of the car was similar to S14, so away you go from there.
the best thing to do now in vic since all these stupid stupid rules and cops on the road is to have a track car and have a stock as a rock ve or fpv.....
The problem is cost though.
It's not like Japan where you can buy some unregistered/ready to drift car for $2,000 or something.
Paying for a track car, then paying for a daily is a lot more expensive than it should be. If police could let people off with modifications on the basis that they only thrash it out on track, then we wouldn't have this problem.
Just paint the brembo's black and have no Brembo sticker on it, as if a cop will know the difference.
As long as you keep mods looking stock ie highflow, nistune etc you can get away with alot without getting defected or getting into trouble, no need for a track only car unless your serious to the point of doing wtac and big events, you can still have a quick somewhat legal street car that'll be a good all rounder.
With engineers certs even if you get your car 100% engineered for every mod Im pretty sure a cop can defect you or send you an epa letter if they think your to loud,low or if they wanna fine you for the sake of it (but that never happens :whistling: ) You have to remember this is Vic, the only state where your guilty until you prove your innocence.
Your right. I've had mate's with almost standard cars that have been forced to go through an epa test just because the cop was having a bad day.
Another mate got canaried for having 3 piece rims and a cage even though he had the complete vic roads rules and regs in his glove box to show the officer that what he had was legal. The copper just said that he didn't care and wanted him off the road.
I had no idea the rules about cages had changed. Looks like my car might end up being track only.
Does anyone know much about club reg and how different it is to normal road reg? I heard some club reg rules have recently been changed also.
Lol that's funny, how long do you think that situation would last before some idiot screwed it up for every one?
Playing with cars has never been cheap, if you don't want or don't have the money to spend to do things right then I suggest you find a new hobby
In this country? Wouldn't take long at all to be honest. :P
I admit that the system wouldn't work perfectly, but considering the resources police have to impound/fine and even jail drivers at times, I don't see why the focus should be on modifications.
Yeah, it's expensive to buy cars. It's still more expensive to buy a track car, and then a tow car. ;)
Also, a follow up question, can you get an engineer certificate for Bride seats, or do they have to be ADR approved? Anyone ever engineered some Brides? Would really love some aftermarket recline-able bucket seats, and the only ones which are ADR approved are the cheap Autotechnica's that I'm not too fond of.
@Eightsixboy: Yeah I get what you mean completely. The only reason I'd get an engineering certificate would be so I wouldn't have to put much effort into getting the car cleared of any defects. I don't think engineering certificates are for avoiding defects as much as they're for avoiding the hassle of the defect, if you catch my drift.
I went to check out a car today.
Seems like the stock intercooler piping hole has been cut.
My question is, how could this affect a RWC, and what's the best way to fix it up? A mate suggested using a rubber grommet, but would there be any other ways that would be more effective?
I got my first EPA notice for exhaust noise about two weeks after getting my R33. Points to anyone who guesses already where i'm going with this.
Bought car with registration
Registered car must be sold with RWC
EPA notice 2 weeks after purchase
RWC lasts 30 days
EPA'ed while still having a valid RWC
Can I use that to fight off this bullshit EPA notice? It clearly states an exhaust system and emissions pass on the RWC.
Ok so in another thread i've come to understand that the RWC part of exhaust does not cover noise level.
I got EPA'ed 2 weeks after I bought my car so if it's going to happen with that kind of frequency it makes sense to fix it. Is that an unusually short period of time to get done for exhaust noise? I wasn't driving like a dick or anything I was in a 40 zone taking my partner out for dinner and got done in the street I parked in.
As u stated rwc and EPA are unrelated essentially
It's not that frequent in theory you have had 1 EPA during ownership of the car...
But it's likely you'll get more so depending how loud it is may be worth getting something quiet but basically anything other than a stock exhaust will fail
What's the legalities with exhausts?
Of course, I understand that you can't remove the catalytic converter, and it must be within 90db. What about design? How far can it protrude from the car? What's the maximum angle allowed? What about mufflers? Can you have twin "blast pipes" providing they're within legal limit DB wise?
Also, does anyone know if you can get away with removing a turbocharged engine and putting an N/A engine into a car that didn't come with that N/A engine? For instance, SR20DE in a 200SX. Would it be P-plate legal?
Cheers guys.
    • Back again. I returned to Japan in Jul/Aug to spend time with the car on my birthday and remind myself what all the sacrifice and compromise is for. It happened to line up with the monthly morning meet in Okutama, which I have been wanting to go to for a long time. It's a unique event at a unique spot with really rare, interesting, and quirky cars. It's where all the oldheads and OGs gather. The nighttime scene at DKF certainly has its place and should be experienced if you're into cars, but there's too much bad attention and negativity around it now. IMO the better time is Sunday morning at DKF or Okutama; it's more chill and relaxed. I'm glad I was finally able to go, but not sure it's worth the drive from all the way from Nagoya immediately the day before, unless I was already staying in Tokyo for the days right before the meet, because you have to wake up quite early to make it in time. Funnily enough though I didn't drive the car all that much this trip because it was just too damn hot. While there were zero issues and running temps were nominal and the A/C was strong, RBs already run crazy hot as it is. Sure, it took it all like a champ but something about driving these cars in the ridiculous heat/humidity bothers me and makes me feel like I'm asking too much of it. I'm just me being weird and treating the car like a living thing with feelings; I'm mechanically sympathetic to a fault. Instead I was mainly driving something else around - a KX4(silver) 2001 X-Trail GT, that I acquired in May. There's a few different flavors to choose from with Xs, but visually it's the Nissan version of the Honda CR-V. Mechanically it's a whole different story as this, being the top-trim GT, has an SR20VET mated to a four-speed auto and full-time AWD! It was a very affordable buy in exceptional condition inside and out, with very low mileage...only 48k kms. Most likely it was owned by an older person who kept it garaged and well-maintained, so I'm really happy with how it all worked out. It literally needs zero attention at the moment, albeit except for some minor visual touch-ups. I wanted something quirky, interesting, and practical and for sure it handily delivers on all three of those aspects. I was immediately able to utilize the cargo and passenger capacity to its full extent. It's a lot of fun to drive and is quite punchy through 1st and 2nd. It's very unassuming -in the twisty bits it's a lot more composed than one would think at a glance- and it'll be even better once I get better tires on it(yes, it's an SUV but still a little boat-y for my liking). So...now I have two golden-era Nissans in silver. One sports car and one that does everything else; the perfect two-car solution I think👍 The rest of the trip...I was able to turn my stressed brain off and enjoy it, although I didn't quite get to do as much as I thought. I did some interesting things, met some interesting people, and happened into some interesting situations however, that's all for another post though only if people really want to know. Project-wise, I went back to Mine's again to discuss more plans and am hoping to wrap that up real soon; keep watching this space if that interests you. Additionally, while working in the tormenting sweatbox that is the warehouse, I was able to organize most of the myriad of parts that my friend is storing for me along with the cars, and the 34 has a nice little spot carved out for it: And since it can get so stupid hot in there, that made it all the more easy -after I was standing there looking at the car and said 'f**k it'- to finally remove all the damn gauges that have mostly been an eyesore all this time. Huzzah. The heat basically makes the adhesive backing on the gauge mounts more pliable to work with, so it was far less stressful getting this done. I didn't fully clean it up or chase the wiring though; that will happen once I have the car in closer possession. Another major reason to remove all that stuff is to give people less reasons to get in my car and steal s**t while it's being exported/imported when/if the time comes, which leads us to my next point... ...and that is even though it's time in Japan is technically almost up since it's a November car and the X would be coming in March, I'm still not entirely sure where my life and career is headed; I don't really know what the future looks like and where I'm going to end up. I feel there's a great deal of uncertainty with me and as a result of that, it feels like I'm at a crossroads moreso now than any point in my life thus far and there are some choices I need to make. Yes, I've had some years to consider things and prepare myself, however too much has happened in that time to maintain confidence and everything feels so up in the air; tenuous one might say. Simply put, there's just too much nonsense going on right now from multiple vectors. Admittedly, I'm struggling to stay in the game and keep my eyes on the prize. So much so in fact, that very recently I came the closest I ever have before to calling it quits outright; selling everything and moving on and not looking back. The astute among you will pick up on key subtext within this paragraph. In the meantime I've still managed to slowly acquire some final bits for the car, but it feels nice knowing there's not much left to get and I'm almost across that finish line; I have almost everything I'll ever want for my interpretation and expression on what it is I think an R34 should be. 'til later.
    • Thanks for that, hadn’t used my brain enough to think about that.
    • Also playing with fire if they start to flow more air down low than what the stock twins can. It's not even up top you need to worry, it can be at 3000rpm and part throttle and it's getting way more flow than it should.
    • Any G40/1000 or G40/1250 results out there?
    • You still want a proper tune on the stock ECU though. Stock tune + stock ECU with GT-SS/-9s is probably playing with fire if you're running more than stock airflow/power.
