Hey guys,
I'm just wondering who amongst all of you has had their car tuned by Advan Performace in Silverwater.
Reason I'm asking is after they tuned my car I have been experiencing high levels of engine knock, high as in the hundreds according to the Power FC hand controller, and my ignition timing is at 42 degrees which I have been told is extremely high. I have had the engine compression tested, result was 145 across all cylinders, car doesn't blow any smoke or make any strange noises. The drive home Advan the knock level did not exceed 22, then the following day I think it went up to 120 something, highest reading from the hand controller was 200 and something, I'm hoping it's a faulty knock sensor or something. Hasn't seemed to damage the engine at all.
So I'm just trying to find out if anyone else has had a problem with their tuning. I'm thinking of taking it to CRD to be retuned.
Any suggestions or input is appreciated
Thanks
With a power curve like that.
I would be taking it back and asking for a retune, or alternatively something might be wrong with the car, part not 100% or something.
The curve is all over the place. Not what a good tune should look like
I knew I should've taken it to SAS in the first place. One of the guys from SAS told me that Advan don't even have a proper tuner working for them, said they specialise in "bling" only.
Any idea what part might not be 100% to 'cause that sloppy power curve?
that is f**king horrible!
I street tuned my own car and the curve is 100% better then that crap - i hired a dyno the week after to get a couple of power readings and this was one of the runs.. totally different.
How much did the tune cost you ? I cant believe they let a car out like that.
the tune looks fine
the top higher power run is the "after" dyno plot
the lower one is the "before" dyno plot
if its knocking a bit more than 60 then you just need to spend a few minutes getting accustomed with knocking and how to correct it. the pfc faq (in my sig) will tell you in great detail how to work with knocking and debug it correctly.
read that and it will help you sort out the knocking
er, i wouldnt be doing any fixing yourself at all (regardless of how easy it is after reading the faq)
id be taking it back and telling them its knocking and make them fix it
Look at the power surge between 130 - 145 - that looks like something that would happen with rich and retard not with a full power Fc tune.
I would like to see the ignition map and fuel maps of this tune.. there must be a reason why its doing that.. if its not the tuners fault then there must be something wrong with something there.
the tune looks fine
before getting carried away with taking it somewhere else, or accc etc. just go back to advan and tell them your concerns... at least give them a chance to help you out. I'm sure if they did make a mistake, or possibly something changed on your car since the tune they will be happy to take a look and at least diagnose the problem (if there is one) for you.
^^^ I agree with that... if they screwed up go back to em and see what they have to say about... but 43 degrees of timing is faily high isn't it? standard is like 15 or something like that.. according to the sticker on the bonnet...
Some workshops are really good to there customers - i know if it was Turbotechnics in newcastle they would put the car back on the dyno and double check it and fix it if they can for free.
I hear lots of good storys about advan so i wouldnt be suprised if they do that for you too.
Hey mate,
I had my car tuned by SAS a month or so ago and they did a great job. Good blokes, especially Rodney real helpful, i would recomend them to anyone they are straight talkers...
i wouldnt be to concerned what the guys from one workshop said about another .
your chart looks ok , not great but ok and you said it drove home fine
i think something else is wrong , lots of timing advance will cause detonation and something is f**kign that uo
Yes, even if you approach the ACCC for help, they will always tell you to go back and seek a resolution with the service providors.
Lets not jump the gun with suggestions of involving the ACCC, thats ridiculous
its really not a big deal, 42deg isnt much of a concern
im up near 50deg on my tune and it rawks
if its just knocking in one or two spots
use the pfc faq to help work out where in the maps it is and
then goto advan and ask them to kindly sort it out
every tune knocks differenelty on the street with the owner dirving it compared to being on a dyno in a simulation. happens and just needs a quick touch up once its out of the simulator and in the real world
As Paul said, knock over 60 is something to be concerned about. 120-200 would sound like someone pouring a bucket of gravel under your bonnet.
If you heard abnormal sounds, it's probably knock and should be dealt with. If you didn't hear it, it's probably a bad sensor.
If it IS knock, it could be a caused by a bunch of things, some of which are not the tuner's fault, but most of which probably are. Try some fresh gas before you get too worried.
I wouldn't hesitate to fix it myself, but I like that sort of thing. If you paid someone to do a job, give 'em a crack at fixing it.
Good luck!
Dan
Cost me $3000 for the Power FC, Z32 air-flow meter and the tune which means I paid over $1000 for a dodgy tune. I'll get someone to check out the sensor.
I don't think I'll go back there, they seemed kind of hostile towards me.
I have a friend who highly recommends Powertune in Fairfield, and from what I have read on these forums, they're not so good, but my friend assures me they can do just as good a job as Unique Autosports.
Anyone on here had experiences with them?
Thanks for all the help.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
    • Does that German restaurant still exist in the old place out the NW end of Goulburn? When I say "out the NW end of"...I am really being vague. It was 1997 when I was last there, and the only point of reference I can recall is that it was on the opposite side of the main drag from the big merino. And when I say "opposite side of the main drag", I don't mean "on the main drag". It was either a couple of streets back from there, or might have even been out in the sticks a bit further. Was an old farm building or mill or somesuch. And when I say "the big merino" I might actually be thinking of a completely different part of town, because I just looked on maps and the big bugger is not where I remembered him to be! The food was good, consisting largely of various German mystery-meat sausage/loaf things and kartofflen.
    • So while the second sentence is completely correct and the whole point of the conversation, the first sentence bears consideration. If this bloke is just hoping to throw big turbos on and drive it around, because there are no helpful facilities at all in his tropical paradise** then he likely has zero chance of even knowing what the TP is on the last column in the stock maps, let alone know whether the ECU is operating anywhere near it or past it. So the point is very very moot. And, per what I said before, at stock boost on those turbos, you may well be off the end of the map. **I'm just back from Vanuatu, so I know exactly what small Pacific nations can be like wrt paradise without requisite facilities. But it's not even that simple. I put a high flow on my car and had to drive it around without a proper tune because of the lack of opportunity*** to put the bigger AFM and injectors into it to allow it to be tuned. I had to turn the boost down to less than I had before, and back off the boost controller's ramp, because it was exploring parts of the map that it didn't drive in before, and really couldn't access for tuning on the dyno either, and so was pinging. It was still well within the last column, because when I first**** set up the Nistune on the Neo I rescaled all axes of the maps to give some more space to explore. ***Family dyno was broken ****This was 13 years ago, and the TIM thing wasn't a thing then and so TP would definitely grow when pushing past the stock tune's limits.
    • Yep, this bit another local owner. I caught it before putting the transmission back into the car, what I noticed was the pressure plate fingers weren't flat and even. It's more obvious with the pull style clutch because the throwout bearing ring was visibly not flat once everything is put together. Nismo should really update their instructions to call out this specific detail. I'm not even sure the clutch as-shipped orients everything properly.
