Lotus cars has donated a brand-new Exige to the Bankstown, NSW police force. The six-month loan gives the local constabulary a head-turner that it plans to leverage in community policing projects, particularly with regard to reaching out to local youths and car enthusiasts. The thinking is that the Exige will be an instant conversation-starter with both groups, and that, in turn, will enhance the police department's credibility with them.
Full article:
http://www.autoblog.com/2007/02/16/lotus-d...ice-department/
https://www.sau.com.au/forums/topic/156727-lotus-exige-cop-car/
"We are also very conscious of environmental issues and keen to demonstrate ways of using less fuel with more economical performance cars.
Haha, wait until the find out how often you have to service it and how much that's going to cost :happy:
Lovely cars, I'd own one in a heartbeat but they're not a fleet vehicle.
Thats so cool. Lets just hope that it goes everywhere, schools, tracks, drag strips and the guys driving it are cool and a good face for the service.
...and i cant help myself. Bankstown? LOL..it wont last the 6 months without someone vandalising it or trying to steal it .
'good to see my tax money being used so wisely'
It wasn't purchased with tax payers money, apparently it was given to the police force from lotus if you read the article. THANK GOD because i was just complaining to my gf about our tax payers money going to waste as well haha.
