You just had to bring the bolt cretins into this didnt ya, but i had already throught about them and got them covered.
Every one knows if you hang full cans of WD40 around the shed it sort of works like garlic and vampires. The garlic bit worked on the missus so i have high hopes on the bolt cretin cure.
Edited by tacker
forget fairies, find yourself some underpants gnomes. we all know they work all day, searching for underpants yay, they won't rest till they find underpants.... and so on. they are very hard working providing you can deal with them singing that song non-stop.
I have my engine sitting on the floor in the garage and it looks like the biggest pos that was ever made.
Just looking at all the bits n pieces all over the place makes me nervous to touch anything.
Day 15!
i was down to the last can of beer i had used in vain in my turbo fairy trap. The very last can, nothing else but the makers name and that was written in french and partly obsucured in blood from my torn up hands.
Thought i better wipe some of the blood away with an old rag before putting it out of its misery. And bugga me if the beer can genie didnt pop out offering me 3 wishes.
Wish one, please please put the turbos back on me car, poof .....all done!
Wish two, Return all the beer the barstard turbos fairies drank while demolishing my engine bay. Poof ...........full fridge!
Wish three, stock up the other fridge so i can at least temp the pressure plate pixies to come and replace my clutch as it aint gunna hold on too long with 455 AWHP after dyno session today.
WHOO HOO
Edited by tacker
yep all at .9 bar so i still have a bit to play with i would think just flat lined at about 7200 when wastgates opened. We did higher runs for what it was worth but we add some more fuel just to be safe and have AFR's mid 11's.
BIG improvement came from adjusting the cam timing was about 40 to 50 more HP depending on how hot the car was on its run. But just so much more agressive on ramp up really big difference mid range.
Gee I hope this is not part of the fairy tale - 455hp.
Nah - well done. Big effort. It almost makes the pain worth it.
Let's hope mine goes as well. :)
yer not to sure about the figure myself or how you calibrate a dyno dynamics 4 wheel dyno. but either way it performs sooo much better
But what a difference in performance...my hands dont hurt half as much as they did early last week.
I dont know about the figure produced but the tuner didnt seem interested in the graph reading much at all. didnt move his eyes from the wide band or remove the det cans from his head, really didnt give a rats about the figure.
  • 9 years later...
  • 1 month later...
Pay some-one else to do it...If your not a mechanic...
Cost approx...$500 to $600.Engine in..."don't make them take it out cause their lazy."
This will cost another $500
The extras such as new copper washers/bolts/gaskets/oil and water lines"if needed"
can cost though.
Great explanation / DIY Turbo replacement for a GTR..
Old thread i know. ...but..pretty sure removing the whole engine to do a more thorough job isnt being lazy, its called do it once and do it right
I will be removing my engine before I put myself thru this kind of pain and suffering, I know just from looking that there is going to be many tears
Very funny writeup.
This is the solution though. There's no way in hell I would attempt to pull all that mess down with the engine in the car!!!
To add fuel to the fire, I can remove my BW 8374 EFR completely in about 45 minutes. There are 4 nuts, 1 V-band clamp, 1 hose clamp, 1 vacuum/boost line, and 4 AN fittings to/from it. All very very accessible.
But in all honesty I did contemplate staying twin for a long time. But I DEFINITELY would convert to speed density (Haltech or other) by removing the MAF's remove ALL BOV piping spanning from the driver's side of the car over to the intake piping and change them for BOV's that don't open under part throttle, and just simplify the inlet / outlet piping in general. I think half the hassle is simply getting TO the turbos. I can't imagine trying to find a boost leak in that mess.
It can be done in the car and works without issue. How is it anymore thorough? Totally unnecessary to remove the engine!
    • I hope it's actually possible. This is a write off in insurance world.
    • Yup. 2-way with shallow ramp angles. Still works.
    • That was the first session so not a lot to take from the day. It was low 20s ambient and the coolant had got to 110 (and obviously had some pressure!) so that still needs to be addressed. I haven't downloaded the data yet but will. I had refilled the auto trans with Redline DT6 because it claimed the best viscosity I could find at 100o. It wasn't really long enough to get a good feel for that; while the trans got to 100o in the session it still wasn't shifting crisply as I hoped. I think I'll try a few more sessions before judging. No steering motor overheat but I'd hope not in only 1 session! But finally the suspension; it was night and day over the standard stuff and the car was a couple of seconds quicker on the same crappy tyres, which is a huge difference. I'll stick with that and get some sway bars and a mechanical diff sorted too and see how that all goes together
    • I guess it’s partially a compromise of how my car is used, wanting to be able to switch from drift to grip with track side on-car adjustment. Also partially with the way the knuckles are set there is more static camber but less dynamic camber gain.
    • OK, so update from the track day on Friday It was a classic "an unfortunate series of events'. There were a few cars around and when i checked my mirror coming out of the fish hook I notice some smoke from the rear of mine. Looked again and it was getting much worse, I figured I'd blown a turbo or something to got off it and pulled off the racing line. However.... since it is a left hairpin into a right kink, I was on the inside of the next corner. There was a car passing me on the left and a big drop off over the ripple strip on the right......and someone had knocked the witch's hat that was on the apex about 1m onto the track. So, between those 3, I decided to mow down the cone and not damage my car/the other car. Right choice, but surprising result.  The car decided the cone was a small pedestrian so it blew the rear bonnet hinges up to protect their head in the upcoming person to car impact....I didn't see that coming and like an airbag deployment it happened super fast. Straight into the pits from there, everything was driving fine but it became clear it was a coolant leak not smoke, it was billowing up onto the windscreen. Onto the trailer and home. I'll do a separate thread about the repair (once I work out what it is ), but the immediate problem was the bonnet wouldn't open because the front was pinched onto the front bar and would not release. Ultimately we unbolted the hinge from the bonnet, pulled it back a little and it released from the front OK. "There's your problem", the top radiator hose had popped off at the radiator.
