i was planning on putting a DVD player in the upper glove box also
i was thinking of not disconnecting the stock DVD rom unit, but just re-locating it backwards under the dash somewhere. i have no needto access it, it just has to be there behind the dash
then i can put a DVD player in teh stock nav position!
thats what i was thinking of doing before chris releases the final build of his satnav/dvd/radio kit
chris' kit is not going to have DVD
from what he has told me it is GPS navigation ONLY
that means we need a separate DVD solution
there are a few units on eGay that have DVD and a TV tuner in them for $250-300ish.. that means all you would need is a TV antenna (can hook into the stock one?) and bob's your uncle - TV and DVD to go with chris' GPS unit and you have all the stock features accessible through remote control and the steering wheel
some of the DVD/TV units on eGay also come with a remote infrared attachment so you can leave the unit under the upper glovebox and access it hidden for that stock look :P
the plug an dpay version is for the nav. I can do the whole lot turn key but not without having the vehicle to do it.
considering these cars (or the ones I have seen.) didn't have DVD as std its not a major issue. if you do not have the reversing camera - go in there and use a 'mod' lead to make it work.
we need to talk :P ring me in the morn.
hey mate, will call you in the afternoon as i have a session in operating theatre in the morning and i can't take a phone in with me
what is SWC? (from your other post)
Edited by WazR32GTSt
Could someone help a girl out?!!! lol.. i have no idea how to do these things.. Frank, when u get urs sorted.. would u be kind enough to show me?..
location?
I would like to say that whilst the R34 one is different.
I ripped all my stuff out after testing the front audio and video input on the xanavi satnav in the R34.
it worked for the laptop when switched to NTSC.
then i got told there is nothing else i can do.
I ripped it all out.
looked in the boot when i finally got to the sub install and the fricken tv tuner part ALSO had an AUXinput.
a fricken HTPC in there would have worked out great guns.
I am hoping if the V35 has something similar which it sounds like from IT doctors post.. then there is certainly some scope for it all.
Honestly don't know yet, I'm trying to figure out why you would need video out on that connector, for I'm pretty sure that is the remote camera hookup, as when i disconnect it, only the backup camera stops working. TV is still there. Whereas if I pull out the big connector the TV stops working, so this is the connector to splice... i think...
I've taken proper photos of that board now, but too busy this weekend to do anything.
Oh yeah and I've got a cable with connector that isn't hooked up to anything dangling up under there, next to the sub wiring. Do you guys have that too?
Might need a new thread purely for people that are interested in working together to build an aux-in connector and keep the whores out.
Thanks for reply.
As my understand, your one come with reverse camera, so you only have one empty connector isn't hooked up to anyting.
Can I ask: there are 4 connectors on TV unit, the big one for TV, and two grey ones for antennas, so the last one stay in the middle of that three is for camear?
my one doesn't come with reverse camera, so I got two cable connectors hangup there. both in grey color. I guess one for camera the other one is something else.
AS IT DOCOTR said:
He run a connector via that 6 pin connector to get a set of AV input--which in your car is used for camera? after reading post 199, i thing it is a pretty easy job expect no idear of VTR- used for.
OK then, yes my car has the camera, and that white connector on the board you are referring to is plugged in on mine. The only reason I'm thinking not to run a splice from that particular connector is that on mine I'll only get input from it if the car is in reverse. I'm not sure yet where that switch is made. Whereas the TV one works all the time. IT Doc, do you have to press the TV button on the front to see your MP3 player? When does it work?
Like I said haven't had time to play as yet, so we'll figure it out together soon.
Very interested in knowing what that other unplugged cable is for. I may ask the US guys if that is the sirius connector or if they have it at all.
Edited by -= SKiZO =-
    • The car/ECU will have all the sensor that it needs and expect to have. I think i do not have to explain to you how the Link is way better specialy if you have swapped engine   I just do not want to deal with any "problems" cuz i have only Nistune which i learned is not that great and in my case cant even deal with that speed problem (Link can) And of course it will be way more easier to tune and diagnose and safe. And for the ECU/speed problem...i dont know.
    • Per Mark Roberts of Sonictune: Mark Robert Author At this time, no. No ETA either 2016-17 models. You will be able to purchase and install a 2018.5+ TCU though   TCU purchasing and pricing info! As we near the release of TCU tuning, I am going to answer some questions I get asked often.   What do I need for TCU tuning? At this time, you will need a 2018.5+ TCU to be able to tune. If you have a 2016-to early 2018, you will need to replace your TCU with the newer version. One good way to know if your TCU is good is if you have auto upshift in manual mode in 1st gear around 6500 rpms. If your manual 1st gear goes to 7k rpm and will hit the rev limiter unless you shift, you have the older TCU.   Why do I need to buy another ecu license/phone flash if I already have it on my ECU tune? The TCU is its own computer module. It is completely separate from the ECU. Because of this, you will be required to purchase a TCU license and, if your tuner has it, the phone flash license required to tune it via phone/bluetooth.   Do I need TCU tuning? TCU tuning is NOT required. However, the faster your setup, the more it will assist in track and dragy time consistency.   If I’m ECU tuned by (tuner A) can I get my TCU tuned by (Tuner ? Yes, since it’s a different module and a completely separate flash, you can have two different tuners. However, it is highly recommend that you have both tuned by the same tuner. For me, my TCU tuning will directly complement my ECU tuning style and features and running my ECU and another TCU or vice versa MIGHT cause some issues. At this time and for the foreseeable future, I will only be tuning my current ECU tuned customers TCUs.     I have a SYVECS AWD controller. Do I still need it? Yes! The AWD controllers main job is to control your AWD system. However, with TCU tuning, you will no longer need the auto-shift function as that will be done through the TCU. The AWD controller will still be very beneficial for racers looking to maximize traction on the launch.     Shift schedule changes: holding gears longer at lower pedal input as well as max shift rpm changes. Please note, the new ECU race rom coming out will address 90% of the shitty drivability issues these cars have through custom maps from myself and Racebox—as well as others I am sure.   Increase shift speeds: as seen in the videos I’ve been posting, the TCU shifts much faster once tuned.   Increased shift pressures: as also seen in the videos, much firmer full throttle shifts.
    • The fancy pants red shock tower brace is finally incoming from MX5 Mania, getting it shipped from 'Merica has been a long and problematic process, and GWR, the 'Merican supplier will not ship directly to consumers outside of the US, Mania basically had to order a heap of them, the colour choice was silver, or red, and we all know anything red adds 5 killerwasps of dynotorques..... Whilst it does fit over a 2.5, and I've seen a few photos and videos of it being installed and fitting, google also says it might get real close to the FAB9 intake front runner, people in the US says it does fit with the FAB9 intake, except for one person who said it slightly touched.......so there is that.....LOL..... As it seems that I am the first in AU to have this combination of parts there's no local knowledge about fitment, so I'm just a willing guinea pig in this endeavour, I'll cross my fingers and toes and hope for the best In other news, I ordered stuff from China  on the same day I ordered the 23° silicone bend from Victoria, the stuff from China arrived a day ago, the 23° silicone bend is still travelling around Australia thanks to Australia Post, and "may" be here next week
    • Very good news...I contacted Racebox about it last night. My car is a 2016 so remains to be seen if it is compatible, requires a TCU swap, or is impossible.
