  • Replies 40
RE55s were way too quick imo - I only got around 1500km from them before they needed replacing
Advan are ok, but they flat spot really easy
RE540s were ok, but now they are no longer
Toyo R888 seem pretty good, but I am not sure about how long they last
Toyo RA-1 are also very good, but dont live forever
Federal 595RS probably the best I have tried so far, dont have quite the grip levels of the Toyo or RE55s, but last ALOT longer - have done around 15,000km now, including some several hard high speed track work and they are still going strong. As one of the cheapest around, I reckon you cant go past them. The sidewalls are a bit softer than other Rcomps I have used, but nothing so bad as it has caused issues
Federal FTW imo.
https://www.sau.com.au/forums/topic/160760-track-tyres/#findComment-2987436
Gavin,
I use the Bridgestones (SR) and they do work very well.
I am in the middle of working a deal that will see me on a set of Yokys. Ill let you know how good they are.
The Federals are a good sticky street tyre, but as used on our other car our times around the MC courses has dropped 2 seconds.
https://www.sau.com.au/forums/topic/160760-track-tyres/#findComment-2987524
If you want Toyo's go to Bayswater Tyres. It's in, um, Bayswater. 22 Embleton Ave. Phone 9371 9988. They should be able to give you a price on Bridgies also, just not quite as nice as the one they can manage on Toyo's.
If you want Khana action the Toyo will be better suited than the RE55 IMHO.
Also, Federals are gay so tell all your mates to use them. Same for Falkens.
https://www.sau.com.au/forums/topic/160760-track-tyres/#findComment-2989868
other than costs is there any reason not to got 18's for track work. Run 18 inch rims and street tyres am considering getting another set for use as track day tyres an running some decent tyres looking at most of the tyres mentioned above as possibilitys.
Well looking at this here price list for RA1's & R888.
255/40/17 cost $425 & $436 respectively.
255/35/18 cost $548 & are only available for 888's.
So um, $450 per set is a fairly persuasive argument...
Given you don't get any gain from the extra inch rim unless you are running large brakes, there isn't much of an up side.
As to Keefy: The RT615 manages to combine the downsides of running R compounds (Rough ride, tramlining, noise) but misses out on the grip levels that a proper R compound can deliver. For one I have never seen a track car here in WA running the Falkens. Overwhelmingly people here run RE55's (Cheaper in the larger sizes than the Toyo's). You will see kharna cars & the small fry using Toyos moreso than Bridgies. You rarely see Dunlop/Yokohama/Michelin/Pirelli. I think this is a price issue as much as anything.
https://www.sau.com.au/forums/topic/160760-track-tyres/#findComment-2994657
Falken RT615 pwns the street legal tyres. 2nd runner up advan nova ad07. Well.. I'm my books that is.
haha. c'mon mate. they have a treadwear rating of 200 (or was it 240, i'm a bit hazy). R-comound tyres like A048, RE55 etc have a rating between about 40 and 60. see if that gives you a hint. RT615s are ROAD TYRES, that happen to have a construction like a track tyre, but the rubber of a road tyre. AD07s are road tyres too... Have you got either of those? or ever owned either of them?
https://www.sau.com.au/forums/topic/160760-track-tyres/#findComment-2994671
    • Fark what are the changes of that snapping like that, clean. Nek minnit, custom radiator goes in, with built in oil cooler like those discontinued PWR ones from yesterdeacades ago
    • I thought I'd do a write up on an auto transmission fluid change for a the nissan 7 speed Automatic. At some stage the genius engineers decided that the fluid in the trans was "for the life of the transmission", (which seems kind of self supporting to me) and removed the dip stick and fill tube (funnily enough there is still a casting for it). Anyway, for this job you do need 2 specialist tools in addition to regular hand tools, jack and good chassis stands. You need a way to pump fluid up to the transmission; I got one of these but there are plenty of other options: https://www.ebay.com.au/itm/364584087070 Don't trust the generic listing though, it does not come with the required adapter for the Nissan 7 Speed. You need one of these, can't do the job without it: https://navarapart.com.au/product/genuine-nissan-patrol-y62-d23-np300-navara-re7-dipstick-fill-connector1 You need a heap of compatible transmission oil. Could be Nissan, could be anything else rated for Nissan Matic S. You need at least 10 litres, I had 15 to give it a better flush... Also, you need some biiig oil catch trays, at least one of these, or bigger if possible (volume was fine, size was very marginal): https://autobarn.com.au/ab/Autobarn-Category/Tools-%26-Garage/Specialty-Tools/Oil-Service/Garage-Tough-Oil-Drain-Pan-Black-16L---GT1068/p/TO03191 Finally, a measuring jug is very useful if your pump does not have volumes marked on it, I got a 6l one: https://www.repco.com.au/oils-fluids/fluid-accessories/measuring-jugs/penrite-measuring-jug-6l-pmj006/p/A5322648 Oh, and gloves.....this stuff is horrible (not as bad as diff oil, but getting there) ....First, jack up your car.....
    • So I mentioned the apprentice, @LachyK helped take the bonnet off. We just undid the nuts on the hinges and unclipped the gas struts, then pulled the bonnet back a little as the front was catching on the front bar.  I had a good look at everything today and have removed the rams, repaired/reset the hinges and bolted it back together like it never happened. I'll do a separate write up on the repair, and I also removed the poppers from the Fuga today too to save grief down the road.....as said above it is at least $5k to repair retail. I'm also happier about my ability to prepare a race car, and less happy about Nis-nault's engineering (I can hear @GTSBoy sAfrican Americaning) because the top hose of the radiator didn't slip off.......it snapped clean off. By practice I put the hose clamp hard up against the flare on a neck to make it least likely to ever move (thanks @Neil!). I guess that puts a little more pressure on the end of the pipe as it is further away from the rad, but still, that is pretty shit. I've put it back on for now as there was a fair bit of neck still there, but obviously there is no lip on the neck any more so I don't think I'll track it again until I have a new rad. Speaking of which....more research required. It looks like Koyo makes a standard size radiator in ally which I'll grab in the meantime, but I really want something thicker so might have to go custom in the medium term (ouch) Coolant still needs a refill and I have the pressure tester on it over night, but other than a wash down of the engine bay it seems alright. And @MBS206 noted something noisy on the front of the engine and I think I agree....time for a new accessory belt and tensioners I think.
    • our good friends at nismo make a diff for it, I have one (and a spare housing to put the centre in) on the way. https://www.nismo.co.jp/products/web_catalogue/lsd/mechanical_lsd_v37.html AMS also make a helical one, but I prefer mechanical for track use in 2wd (I do run a quaife in the front, but not rear of the R32)
    • What are we supposed to be seeing in the photo of the steering angle sensor? The outer housing doesn't turn, right? All the action is on the inside. The real test here is whether or not your car has had the steering put back together by a butcher. When the steering is centred (and we're not caring about the wheel too much here, we're talking about the front wheels, parallel, facing front) then you should have an absolutely even number of turns from centre to left lock and centre to right lock. If there is any difference at all then perhaps the thing has been put back together wrongly, either the steering wheel put on one spline (or more!) off, and the alignment bodged to straighteb the wheel, or the opposite where something silly was done underneath and the wheel put back on crooked to compensate. Nut there isn't actually much evidence that you have such a problem anyway. It is something you can easily measure and test for to find out though. My money is still on the HICAS CU not driving the PS solenoid with the proper PWM signal required to lighten the load at lower speed. If it were me, I would be putting either a multimeter or oscilloscope onto the solenoid terminals and taking it for a drive, looking for the voltage to change. The PWM signal is 0v, 12V, 0V, 12v with ...obviously...modulated pulse width. You should see that as an average voltage somewhere between 0V and 12V, and it should vary with speed. An handheld oscilloscope would be the better tool for this, because they are definitely good enough but there's no telling if any cheap shit multimeter that people have lying around are good enough. You can also directly interfere with the solenoid. If you wire up a little voltage divider with variable resistor on it, and hook the PS solenoid direct to 12V through that, you can manually adjust the voltage to the solenoid and you should be able to make it go ligheter and heavier. If you cannot, then the problem is either the solenoid itself dead, or your description of the steering being "tight" (which I have just been assuming you mean "heavy") could be that you have a mechanical problem in the steering and there is heaps of resistance to movement.
