Well lets think:
Tyres, springs, dampers, bushes, suspension geometry, unsprung weight, differential type/setting all have an effect.
Further ride height, rake angle, toe settings, camber settings, caster settings, tyre pressures have an effect.
So maybe you need to start by having a think about what you want to achieve.
Do you want, for instance a nice compliant ride to take your Nanna to church on Sunday or something more tuned to lapping your local circuit? Or something in between?
What you would change depends on what you want & also on what type of car you have.... :laugh:
Start with sway bars front and rear - see SydneyKids group buys
Even with stock suspension, this will make a big difference to handling and is also the cheapest option to start with.
yeap...
a general thing is that people start by throwing in coilovers in straight away.
the standard spring rates on skylines are actually pretty good.
front and rear swaybars are the best bang for buck mod i've done suspension wise
I'd say an advance driving course or specific cornering course would be the first to do.
No point in having upgraded suspension if you don't know how to go through the corners.
I'd wager that most people on here would benefit more from learning to drive fast correctly than just upgrading suspension.
I'm sure people on here could tell you more about them.
It would depend where you are and what tracks you are close to.
I did one at malalla a few years ago when i had the R34. And it was great. Went all day and included lunch.
They taught me what kind of lines to take, how to balance the car when coming into a corner, and just made me a faster smoother driver.
And you will be grinning all day on your first time out, it's just awesome. Espicially when at the beginning of the day and your going into some corners at 70 kmph and your thinking to yourself "i'm doing pretty good" then by the end of the day your doing the same corner at 105 and having an absolute blast.
no point taking a slush box to an advance driver training course..... fix the sloppy handling, then learn how to put it to its greatest effect.
I completely disagree with that. It would take more skill to drive a crappy car fast than it would to drive a good car fast in the case of a skyline.
It's all well and good to have the fancy bits, but no good having them and not using them correctly.
  markimak said:
wats the price on the justjap items..? are they alluminum..?
link?
never seen an aluminium sway bar, and never seen just jap making/selling sways either so I'm not sure what you're talking about?
  Roy said:
Can some ppl start trying the Cusco/Jap swaybars. They are a bit lighter and im curious to know how good they are...as im all ears for dropping an easy couple of kgs out of my car :P
justinfox has the cusco bars. and I will be using them soon too. ;)
Hmm, maybe I can add my 10 cents worth.
Firstly, funny how no one seems to care what outcomes the bloke may want to achieve from his suspension upgrade.
Secondly, upgraded sway bars are great except:
1. If you want to go drag racing.
2. When the shocks on the car are stuffed.
In which case they are basically a waste of money. I put new sway bars on my tired stock suspension (They turned up first, ok) & basically they didn't make sod all difference to the handling other than exacerbating wheelspin by hiking the inside rear.
As for the bloke who reckons driving a car with stuffed suspension is a better learning experience than driving a car with sorted suspension. Well I hate to burst your bubble but driving a car with stuffed suspension only teaches you how to drive a car with stuffed suspension. You end up making feeble, timid inputs (brakes, steering etc) because of too much weight transferance. Now that is fine up to a point, but getting the best out of a sorted car is a very different proposition.
Now Cusco sway bars may be good (in that they are, atleast hollow) but they aren't worth a pinch of shit if they don't match the spring rates fitted to the car. The rates for the Cusco gear is very different to the rates for the Whiteline stuff. So as a direct replacement for those running Whiteline spring/shock packages they aren't much chop. :( Why? Because the front Cusco is softer than the Front Whiteline & the rear harder than the rear Whiteline. So you would need to have fully utilised the adjustment on the Whiteline gear before going anywhere near the Cusco stuff.
In anycase I really don't believe that running less front roll stiffness than the Whiteline setup would in any way help a GT-R to corner better. Running yet more rear roll stiffness will simply remove even more load from the inside rear when turning. So the damn thing ends up looking like a WRX. Funny how no one mentions such things as roll centres, cog, ride height etc etc etc...
Must go, tired now. :dry:
  bugger said:
How to improve the handling and stability of the car?
what parts must be change to achieve that desire results?
Step 1, fix whatever is broken or worn out and then get the wheel alignment correct. This usually means some adjustable bushes for caster, camber and rear subframe alignment.
Step 2, stabiliser bars are the best bang for buck suspension upgrade you can make for improved handling. Road or track.
Step 3, shock absorber upgrade, if the standard shocks were OK in step 1 then it is now time to upgrade.
Step 4, aftermarket springs if you want a lower height than can be achieved with standard springs and aftermarket shocks (ie; The Bilsteins in the Group Buy come with additional circlip grooves which enable you to lower it using the standard springs. Around 24 mm works very well).
Check out the Group Buy for your particular model;
R33GTST
http://www.skylinesaustralia.com/forums/in...showtopic=85467
R32GTR
http://www.skylinesaustralia.com/forums/in...showtopic=87521
R34GTT
http://www.skylinesaustralia.com/forums/in...showtopic=88141
R32GTST
http://www.skylinesaustralia.com/forums/in...showtopic=85591
etc
:( cheers :(
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
    • When you pulled it off, there is no signs of blown head gasket? Is it possible you have some other issues going on? Possible cracked blocked? Or do you think it's straight up lifting the head? Did you check what the head was torqued to before pulling it down (To see if possibly they're stretching, or starting to break threads out etc)?
    • Seems like a decent result for a modded JZX110. They are bulky in comparison to the 100 and 90 models (which I'd prefer myself) but they are getting very few and far between here in JP these days. Thanks for the detailed review and the import process into the UK. I also have a car which I'm hoping to export from Japan at some stage so it's good to know if someone from the UK was interested in it. By the way the corrosion underneath is par for the course for cars which were located in/near the mountains or along the Japan sea coastline. They get huge amounts of snow every winter and the sodium chloride is used on the roads. Many cars have some kind of rubber like treatment underneath but they tend to limit it to the wheel arches underbody and fuel tank. Suspension arms and sub-frames will have similar corrosion to your JZX110 which is a common sight. See it all the time and car dealers here generally don't even mention it unless asked.
    • If the sound goes away when you clutch in, the 1.5/2 way diffs are just shit, and you are a normal person. The diff is likely "fine" but driving at anything under 30kmh is a violent horrible experience. It would be exaggerated with solid diff bushings and subframe bushings if you have those.
