What do u reckon of a Full Lock?? Too much on the street? n chop up my tyres easily? I'm thinking of doing this n ordering some shimms n rang nissan n said it will take 2 weeks ex Japan.. or i could get a full lock one for 300bux?? What u reckon?
Search for opionons on locked diff's, i have had one in my old rx7, very predictable and easy to manage, if its only a matter of waiting 2 weeks then i would wait, if its just a track car or a weekender then there is no reason not to lock it, if its a daily then i'd wait 2 weeks.
If you do search for other threads on locked diffs take note of the people who say that locked diffs are deadly blah blah blah, 95% have never had one, then note what people who have had them think of them!
Also how bad is your diff, i was all prepared to do this and my clutch in the one weekend, everything was set then found out i had to wait for shims, put some penrite limslip 85w-140 and now its all good.
Mine would single spin 10-20% of the time so it isnt totally shagged but enough to be annoying.
I wouldn't do it in a daily, mainly because of the destruction to tyres and bushes, also cops will hear/see it if they pull you into an rbt.
Just save for a 1.5 way, a second hand centre is only 500 usually, get the clutches machined and it all professionally installed would set you back maybe $1k max. Do it once do it properly.
i was planning to shim my diff also but all these ppl saying how it chirps and locks up on low speed/tight corners just puts me off.
do 1.5/2ways do this also?
if so then i will just stick with standard or whack in a GTR LSD.
1.5 ways and proper 2 ways don't. Kaaz and improperly shimmed LSDs will chirp and carry on.
I have no idea why people buy kaaz 2 ways that chirp etc, what is the point, might as well just get a locker if they are going to carry on and cause understeer.
Any1 else know where i can shimms besides Nissan n waiting 2 weeks? in Perth of course :D
The LSD feels a little bit loose.. in can feel it in full turn in low speeds like 1st gear.
Edited by Black_CSR
get them express from adelaide in 1 day?
im pretty sure unley nissan has had them that day whenever I've been there.
Express Adelaide?? u mean if they have to order it in the east like Adelaide?
No I mean that Unley Nissan here in Adelaide has always had diff shims in stock when me or a friend has purchased them, hence call them up, pay over the phone and get them to send them to you via an express post satchel so they arrive the next day.
Faster than 2 weeks from Japan and probably cheaper.
Black_CSR, which Nissan did you try?
I always go through Steve at Northside Nissan and I'm pretty sure Grifforelli got some from there last week.
I rang Total Nissan Cannington... Might call Northside then n try my luck.
Does any one have any negative on going to a ~4.6 shim, as in putting 2x 1.49 and leaving the standard .8's in there.?
Depends how worn the viscous unit is (if the shims have scored into it), a 1.49 each side was enough to lock my diff totally for a couple of weeks.
Bubba, has it ever single pegged since shimmed? Also does it still chirp around tight corners?
    • LOL, when one "money pit" is never enough Noice, and excellent work mate
    • I have more than enough digging, laying blocks, moving gravel, airrating, feeding and top soiling the grass, and setting up the veggie gardens growing some seedlings,  and then removing all the unused rock to keep me busy for the next few months at least,  hopefully the rain stops soon so I can get a few hours in this arvo, but, before that Sunday is washing day, is every body happy, you bet your life we are Nice country road day drives are a day off whenever I'm muscle sore from all the landscaping at the moment, but, more epic multiple day drives will start once the majority of the big jobs outside are completed
    • I hear that would involve some nice country road drives into the hills for Mark...
    • I thought I'd come back and add something I JUST learned. A Toyota LandCruiser with a 1HZ, mates perfectly with a bottle of Nulon brake fluid. As in, it perfectly screws in. Great make shift funnel when you cut the bottom of it off. This may work for your Corolla.   Unfortunately, tipping a 10L drum is much harder than a 4 to 6L bottle, and they no longer include the easy pour tap which was just perfection to use previously.
    • Guys since i bought r33 gts25t coupe 1994 automatic a/t(manual swap 350z gearbox)  all i got is problems, always problems. Lets start with that when i turn key into ignition(ON) fuel pump doesnt always works. Sometimes i have to turn key twice Off/on/off/on until it primes. Its new, dw300 - 340lph. My gearbox broke so i did gearbox swap, install different intake manifold, injectors and i take pipes. Car was sitting in garage for more than half a year. I did assembly all not that long ago and when i turn ignition cant hear prime. All of sudden it stopped working. Theres many videos on YouTube how to make relay mod on r33 straight from battery so i did and it doesnt work! 😰 30 - battery positive  87 - positive from fuel pump to relay 85, 86 - one of two wires from original fuel pump wires(light blue, grey) and it didn’t work. so I check on ignition and took original BLUE relays wires from trunk, next to fuses. (I believe it’s IGN+ and ECU pin 18. it didn’t work…  tried connecting (IGN+ from og relay) and (ECU 104 from 1of4 FPCM wires) to my new relay 85/86 and it didn’t work.  I unplug FPCM. Didn’t work. im thinking what’s wrong   fuel pump is working, if I leave IGN+ on 85 and 86 straight to ground it works but it’s just nonstop. Since it getting constant 12v after key in ON. light blue wire gives me 6-8v.  so how this should be connected? What causing ECU not giving — on pin? Or I did sth wrong and that’s why it doesn’t work? I need negative signal on ECU that control fuel pump. What this should be?
