:D You don't have to drive slowly to get good economy mate.... just efficiently :)
although I guess it would be easier if you had that operation to remove the cinder block from your right foot :)
Edited by iamhe77
Well its going to be very interesting to see a before/after fuel econ for the Stagea after we get it Nistuned. Obviously we will running a bit more boost but the mix should be a bit leaner - so yeah, I really cant wait.
When I got my Nistune install and tune with the gcg hiflow (stock SMIC) I went from 130rwkw to 194rwkw and still get about the same distance to a tank - around 400-430kms. So yeah, I think it worked for me :D
Went down to nowra on monday mostly freeway driving I only got 570 out the tank and I still just under 10litres left wen I filled up best liters per hundred I got i think was 11.8
You have to learn to be lighter with the right foot Damo. LOL
Cheers
Andy
i was sitting at 250kms at exactly half way - nearly stock rs4s
mostly city driving too, was prob on the highway for 50kms
anyone know if there is a cheap replacement to the neo o2 sensor? like how u can use a falcon one for 33's
i dont really wanna pay $200 from kudos motorsport for a nissan one
Pretty sure they're the same; I used a Bosch part, can't remember what the part no. is (I'll have a look for it) but I just called Sprint and asked for the Bosch EGO sensor for an EF Falcon lol. Then cut & solder plugs. Sensor cost ~$70.
Edited by DaveB
You can use the falcon one - theres a thread on it in the DIY section.
Ah yeah that's right - this one
rad, i should have read on when i read it the first time
looks like my next purchase is gonna be one of those :)
cant wait
looks like 450kms from this tank hopefully (its been raining = mad sliding action)
my Stag (S2 RS4S) seems to do pretty good on the highway
a mix of 50/50 city/highway returned ~ 11.9L/100km (42.9L for 359km)
and a 20/80 city/highway split (although this included some squirts through the twisties near Berry/Kangaroo Valley) and my fuel guage was on the low side of the half indicator for ~ 300kms.
not bad if you can keep the right foot in check, lol
I got a genuine Nissan one off Ebay for something like $120 delivered about 18months ago. I don't mind paying that little bit more than the generic bosch ones as at least you don't have to cut the plug.
But I wouldn't be to worried about 250kms on 1/2 tank. Thats really not that bad at all would have to see what you got after the rest of the tank is gone.
yeah, have emptied a couple of tanks now, 1st full take = 13.9 l/100, 2nd tank 13.4l/100 so im pretty happy
just got an ecutalk and it will show instant fuel consumption :rofl: and o2 voltages too - seems its getting a bit lazy
cruising at a constant speed of ~60 its getting close to 9l/100, yet to a bit of highway so im not sure what im doing at ~100kmh
is there much difference in economy between turbo and NA on a vq25?
Depends on how you drive.... but on the whole I would say there would be a significant different considering the VQ25dd is direct injection and runs a much higher compression than the VQ25det.
Edited by iamhe77
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
