I've been using it for a while now, I like it.
its great.. i do a mixture of city country and freeway driving, country is a pain due to roundabouts everywhere and lots of changes in the speed limit
just changed o2 sensor, reset ecu and done my first tank since using shell 98 and dropped from 14.82/100 to 12.91/100
this whole tank was using the power button also, nice driving a few heavy moments here and there as its just too tempting but overall a gentle drive.
was having issues with stuttering at 80/100kph and more so in normal driving mode hence using the power button it seemed to clear it for some reason so see how we go with a tank on normal mode :)
That's interesting with the united 100, to bad there aren't any near me to try it.
On my first tank after getting my RS4S i got 12.6l/100kms. running BP 98. 50/50 driving and being a new car i was boosting it quite a bit. should get it pretty close to 10l with sensible driving.
thats interestinga and worth a look, whats the difference in price from shell to united 100?
I can't remember off the top of my head.
It works our to about 16l/100 on 98 and 14 on 100. So not great either way, but there is a definite improvement on 100 for me.
  • 3 weeks later...
i put in 45ltr of BP ultimate,
30km to work, half on the expressway half in traffic.
i usually get 400k out of it.
i recon i need new coilpacks and a tune then see where we end up
RS4-S sII
Gulf western Synx-6000 in and all diff oils changed (still need to do gearbox but the filler is too tight)
Seems to have helped the economy a little bit
10.5ish l/100 which is really good for down here in tassie (about 1% flat roads)
  • 1 month later...
just replaced the tired coilpacks with brand new splitfires and a brand new oxi sensor, interested to fill her up and see if i have improvement, definatly an improvement on reving her out so far :D
Drove to landsborough today and got 9.0 - 9.7 km/ltr highway. Tried to keep it off boost as much as possible. Was at about -4.3 - -0.8 vacuum most of the way
Get your calculator (or phone) out and convert that to litres/100km
  • 5 months later...
After fitment of the following to my M35
1. Power intake duct
2. Fujitsubo legalis cat back exhaust
3. Scotty stainless dump pipe
On a recent trip I got 7.6L/100k. That was cruising down the Princes from Melbs to Bairnsdale (possibly with tail wind!)
I was running United 100.
Awesome! Had to re-do the calcs a couple of times!
I've done similar economy on highway trips (down to apollo bay for example), not giving it the berries and taking it easy.
Hey guys, I have had a bit of a search but I'm just wandering what size is a stock Stagea S2 Fuel tank?
I think my economy is crap, I've been using premium 98 and while i haven't tested from full to nearly empty I've done 150km and my fuel gauge has dropped half? (would calculate but don't know tank size)
Does this seem out of the ordinary for an S2 in normal suburban conditions?
Fill up the tank till the pump clicks, reset trip meter, drive until most of the tank is gone, then refill. Take note of the distance and the litres consumed. The fuel gauge is useless for calculating economy.
Fuel tank is 68 litres, but youll never get close to emptying it. Nor should you since the pump can get uncovered leaving you with a car that wont start.
For example Im finding that when I fill up my "empty" tank, there is still consistently ~15 litres left, if the tank is 68 litres. Big margin for error.
I have put 63 or 65 litres in.
Live on the edge!
I left my car parked on a slope to the left once when the tank was low but not what Id call "empty" low. The damn thing wouldn't start till I rolled it onto flat ground. I think the fuel pump would be living on the edge (or slowly heating itself to death).
I had that happen once. Had probably 1/8th of a tank left....parked in my usual spot and the friggin' thing wouldn't start. Wrst still it was nosed into a spat where I had to reverse back up a hill to get out....had to jump on the bike and go get a jerry of fuel. Very annoying.
    • sold listed as a Tomei LSD 1.5 Way For 1998+ Nissan Skyline ER34 25GT RB25DE w/Open R200 https://www.ebay.com/itm/174006114594?campid=5338967980&mkevt=1&mkcid=1&toolid=10050&customid=&mkrid=711-53200-19255-0&loc_physical_ms=108689&loc_interest_ms=&campid=5338967980&mkevt=1&mkcid=1&toolid=10050&customid=71883f2ccc571356e0a757bc7adfdde2&mkrid=710-53481-19255-0&loc_physical_ms=108689&loc_interest_ms= it went in like butter all gears, alignment, back lash etc, rotation and clearances correct, and if rolling all rotates smooth and free when coasting down road , clutch in or out over 10 mph smooth... its the binding, clunking and jerking from a stop that is most concerning, also seems like its going to tear the tires off in 10 miles of normal road driving.
    • What 1.5 way? There's no such thing really as a 1.5 way, just different ways of explaining 2 ways with different ramp rates. HOWEVER. In any driving in a straight line your 1.5 or 2 or 1.7 way should have no clunking at all. With the clutch fully depressed the diff should be silent (unless it's welded but I'm assuming it's not). Something aint right here.
    • Clutch is a spec brand, new clutch system,( PP, flywheel, friction disc, etc. pull type) installed 100 miles ago, with no problems.
    • looking for some help and maybe some insight on others experience with a new LSD. R34 GT ran and drove beautifully, but always alot of grip loss due to the open R200 rear end, so I just installed a new 1.5 LSD way into the stock open R200 for a ER34. Simple. Everything seemed right. I test drove for the first time this weekend. as I started to back out the garage the first time slowly with tires straight it sounded and felt like I had a loose or half disconnected drive shaft...that was clucking around loose and shaking entire vehicle, and making it feel like the trans clutch was spontaneously slipping then grabbing very roughly while just letting out pedal slowly. I backed it out went to pull forward with the same noise, shake and slip grab feeling with hesitation, I turned the tires to back out more and then pulled ahead some same thing but worst because of added wheel resistance (which that I expected) puzzled … pulling it back in checking everything over and finding nothing wrong, I tried it the next day. same thing, couldn’t believe how it shook everything again making a terrible noise and making it feel like the trans clutch was slipping and grabbing, but I got it out of garage into the driveway, got it straight, drove forward and then reveres a few times in a straight line everything shaking , causing what felt like clutch slip and grab every time, sounded like right behind front driver tire and I could feel it in the floor board with my feet,... worst right when beginning to let clutch pedal out to engage slightly, shuttering and sounding terrible along the way…I managed to slowly get down the road, babying it the whole way, once I was rolling (out of 1st) seemed to be better and between shifts, then clutch felt closer to normal…not slip/ grab etc., but back down to any stop, straight road or turning, same thing. Made no difference if all tires were straight or if I was turning. All other gauge read out correct. with in 2 miles as planned I reached the empty parking lot and performed the break in procedure that came with lsd, essentially to drive in a figure 8 a bunch.  Did this, binding chattering, and shaking the car the whole way. I drove it back home seemed somewhat normal once I was in straight line and past 10 mph or so, and I know it will “bind” on corners and cause some tires squeal when turning especially from a stop, but when I begin to move it still causes what feels like the trans clutch to slip and jerk badly as well as shaking the entire car, and sounds terrible, that I didn’t expect. I used the fluid they supplied with LSD kit and did the breaking, planning to change fluid as they suggest after breaking, but wondering will it get smoother or less aggressive with use? maybe a 1.5 is just too aggressive for normal road driving?   I have a LSD that I put in my 71 cuda when I restored it, with amazing smooth , quite yet effective results. Different style LSD but that ones a joy to drive. maybe expecting too much from this R200?
    • Join SAU NSW for a flame-grilled feed & flame-spitting cruise! Sunday 17th August 2025 3:30PM Meeting Archies Flame Grille Sylvania Waters 4:45PM Cruise Departure 5:15PM Arrival at Cape Solander Kurnell Meet Location: Archies Flame Grille Final Destination: Cape Solander Kurnell *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
