+1 for Remsa's and +11ty billion for GLS Rallysport.
Remsas are a great pad, no squealing or poor low temp response; and when they're warm; wow!
They are dusty, but I'd rather have brakes that work; than wheels that stay clean on a car that doesn't stop.
Brake dust washes off anyway.
On my R34 GTT 4dr, ive tried Remsa, Intima SR and QFM A1.
All installed by myself using normal cleaning and run in techniques.
All running on DBA T3 clubspec rotors.
QFM a1 out performed the other two considerably on street and light track.
  • 1 month later...
Hey guys, I'm confused now haha lol, can I please get some help.
I have a R34 GTT with 220rwkw, standard weight, gets driven harshly on the street (EDIT: Before you think I'm a hoon, I mean this as alot of stops and alot of them are kind of sudden) and a odd track day, standard rotors.
I'm due for front and rear pads, what do you guys recommend I go for? and I absolutely hate brake dust, the car is white with white wheels haha.
I was going to go for Bendix ultimates because I can get them for $130 a pair but after reading here I've seen that they produce heaps of brake dust, but at the beginning I was set on EBC greenstuff but due to the price, availability and the feedback here I have been turned off them.
Are Ferodo's really good? I've always looked at them as a cheap crappy pad.
Any help is greatly appreciated, at the moment I have some kind of blue pads (came on the car from Japan) and they are spongy as. thanks.
Edited by MrRx7s3
I'll be trying the Type M from Dixcel next time I'm due for a pad change. While I like the Remsa's street performance, they are too dusty for my liking...
http://www.skylinesaustralia.com/forums/topic/418505-dixcel-brake-pads-m-type-review/
So should I just go with the Bendix Ultimate then, because if I do go for the Bendix ultimate I gotta get them today as my mate won't be working till next weekend and my car is a daily and it won't last that long haha lol.
Edited by MrRx7s3
ok now im totally confused :wacko:
i have 320rwkw r33 gtst.(currently building rb30 bottom end)
im about to buy rda slotted and drilled rotors. still want to use standard calipers.
i DO NOT want sqeeky brakes when cold!!!!!!!!!!!!!!!!!!
mainly track use, but also street..
i would like good bang for my buck
thanks
This might sound daft, but I used Bendix 4WD pads in my 32 years ago. They do a 4WD heavy duty pad. 80 series landcruiser pads fit perfect (my old mans car) they pulled up great, no noise and bugger all brake dust
thanks
I wouldn't bother with drilled rotors.
Try QFM A1RM. They don't squeak cold and stop very well. Contact GSL Rallysport
  • 4 weeks later...
Threw in some project mu type ns in the r33 on the weekend. Must admit they have a good cold bite, haven't had a chance to push them through the hills yet but it's looking pretty positive so far. Little squeak at low speeds when pulling up lightly but that's expected from a performance pad I guess... It ain't no Prius.
Please don't, they're a god awful pad. I pulled a set out of my car and replaced it with Intima SR..
I didn't, I ended up getting remsa brake pads off gsl awesome brake but dusty as f**k, I should have listened to the bloke and got qfm, but oh well, the remsas are bity as f**k from cold to hot, it took me around a week to get used to the pedal feel, I looked like I didn't know how to drive with really hard stops all the time haha lol, I had intima in there previously they came on the car when I got them, and no brake fade and 2000kms in and the rotors still look the same except I have to wash my white wheels daily, but hey that's why I got a Mrs she can wash them :-D.
Guys,
I have just recently upgrade the brakes on my 34 GT-T to DBA T3 rotors (F&R) + QFM HPX pads. The upgrade was done about a month ago.
The issue is that the brakes are squealing VERY badly. The squeal does not happen at a particular time (such as after a thrashing), but it randomly squeals even at low speeds. I've been told that I should remove the pads and file them down. If this doesnt work, what softer, road pads would you recommend for the T3's.
Thanks.
Both my cars squealed with new HPX pads. Filing the surface and the chamfered bit shut them up. My R31 is in it's third year with silent brakes now. GT-R pads are getting swapped out.
If you want something kinder than the HPX, look at the Bendix HD or even their GeneralCT (no, I am serious). No idea if they come in R34 sizes.
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
