Hey ppls,
My hunt for a replacement for the standard 'sucky closed under boost" inlet pipe has never really ended, even after I gave up on the super difficult steel version I spent a lot of time on.
I've seen some which cost people $450+, I've seen others that require modifications to the standard BOV return and PCV vent hardware or pipes.
R32 GTS-T
1 glendon.......................Blue..............PAID
2 vsute..........................Black............PAID
3 Haysey........................???..............Paid
4 SNISMO......................Blue...............Paid
5
R33 GTS-T
1 wolverine...................Black Paid
2 R33Driftr....................Blue Paid
3 beastien.....................Blue Paid
4 dOOdz.......................Black Paid
5 Fry_33.......................Black Paid
6 (B1) Mr Fanny.............???? Paid
7 johnnilicte..................Black Paid
8 MANWHORE................Black Paid
9 Gtshortie....................Black Paid
10 Mearcat....................Black Paid
11 Sydneykid.................Blue Paid
12 tuitahi.......................Black Paid
13 Shano3000................Black Paid
15 damuscat Black Paid
16 onthehunt..................Black Paid
17 FLYSLY.......................Blue Paid
18 zebra.........................Blue
19 SoFly.........................Black Paid
22 teazn_r33...................Blue Paid
25 Race__24....................Black Paid
26 Skyhy.........................Blue Paid
28 frx026.........................Black Paid
R34 GTT
1 Bass Junky.......................Black...............Paid
2 Wolverine.........................Black...............Paid
3 Haines..............................Black...............Paid
4 Black_Widow R34..............Black...............Paid
5 so_tred.............................Black...............Paid
6 joe26f...............................????................Paid
7 J34....................................Black..............Paid
8 Darrinspencer....................Blue................Paid
9 Brycey...............................Black..............Paid
10 chuckie..............................Blue...............Paid
11 Marc2................................Black.............Paid
12 oxford1327.........................????..............Paid
13 nightcrawler........................Black.............Paid
BASS OUT
Edited by Bass Junky
  • Replies 233
Yea Black, but Blue looks sexy too..
Interested as long as it's similar to stock and/or fits in this box im getting made up.. Will they work with std clamps?
No rush for me to get it..
Cheers Bass!
Hey guys,
I'm enquiring about the black.
I hope that they have it, because that's what I want, if not, I think the blue will be better than the red. They do say that the air flows through the red one better though.... :thumbsup:
And yes, standard clamps should fit.
Hi put me down for a black R33 one.
Cheers,
Johnny
Man I'm still curious to know who drives that ricey looking R33, that blew the shit outta me a few weeks back around canley vale approximately 11pm.... scremer pipe, chromie wheels, noisey diff that whines.....
    • For once a good news  It needed to be adjusted by that one nut and it is ok  At least something was easy But thank you very much for help. But a small issue is now(gearbox) that when the car is stationary you can hear "clinking" from gearbox so some of the bearing is 100% not that happy... It goes away once you push clutch so it is 100% gearbox. Just if you know...what that bearing could be? It sounding like "spun bearing" but it is louder.
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
