  • Replies 191
i didnt think pt cruisers were all that rare/wacky?????......... :cool:
It's not necessarily what you have, but what you do to it.... Not sure about the rest of you, but that is the first (and ugliest) wood-panelled PT I've seen....
  • 4 weeks later...
I recently got sent this pic of a cefiro wagon with an r33 front
Never even knew they made cefiro wagons let alone ones with skyline frontspost-49054-1235474508_thumb.jpg
I think it looks alright but i havent seen ti from the back yet
THAT I LIKE! :)
It may not be everyones idea of what a wagon should be, but I think that is one cool looking vehicle. Love the rims too.
YUK! why would they even make a Cerifo wagon when the Stagea is Cefiro based!!!
Anyway, this is bit better, back from a time when cars were made of real steel,
1961 Chrysler New Yorker
YAHOO!
Edited by Appealing
Apparently it was a 1 off show car, built by Trial.
It's for sale, if anyone is interested: http://www.directimported.com/car-profile....1995&vid=15
I am glad they don't make a R35 GTR wagon cos if they did the house would be for sale tomorrow. I would happily live out of one of those babies its F***ing awesome. (Missus would be pissed as though, maybe I could trade her on a GTR coupe :D ) No no no bad bad thoughts....... I shall love my wife, the car does not come first.
it's not a cefiro, its a 33 with an Exa hatch grafted on i believe....
do not want.
    • Yes. You will need to get the original boost sensor and wire it in. That is.... if you plan to use a stock ECU - even a Nistuned ECU. The Nissan ECU will not operate correctly without it connected. And yes, it will do annoying stuff like you are experiencing. You will almost certainly be better off with some aftermarket ECU, than trying to hunt down rare sensors.
    • Ok so ABS/TCS is "not" the problem. Yeah i know now about the ABS with Nistune(i told that to the Nistune guy) but iam not 100% why or why i dont have ABS. ABS cube is in the engine (always has been) but i had braked couple of times rly hard and brakes just locked and scream. Does all Skylines have ABS cube? That boost sensor https://www.sau.com.au/forums/topic/367633-wtb-r34-gtt-turbo-pressure-sensor-pics-inside/ Is this it? I need to ask but i have a picture of engine bay and i do not see that (100% is not in that place) If i do not have this the car can do what mine is?(cutting around 4000 rpm) Here is the pic of my engine bay(only one i have) BUT i think i dont have that cuz loom was used from my RB20DE NEO and i know (obviously) that it does not have boost control or any wire to that...) so maybe that is the problem? (i dont know for 100% if that car where the engine is from had that)...but i dont have the loom from that
    • I'm with you here. It's either loom has an issue, OR, injectors are not functioning properly. It could even be they're just constantly dribbling, hence the wet, but not firing.
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
