  • Replies 539
your early posts are a bit suss, but you threw together a nice package. well done, good stuff. look forward to the next results :P
Thanks!!!!
suss... why !!!!! no bullshit here sly33. bullshit would be a 300kw white elephant gt-rs story
or maybe im not understanding you!!!
Edited by WARLORD
Heya you had an awesome result!!
How come you sold the GTRS?
firstly :yes the result was great, lots of fun awesome acceleration and mid range
secondly:i never made the power figure i wanted,i listened to the white elephant theories.lllol
thirdly:i got to used to the power as it is a every day car and i do a far bit of highway flying .lol
fourthly:i got the price i wanted for the gt-rs kit and my nismo 550cc injectors .
fifthly:i was debating nos kit or 3037 for the last 5 months so i picked 3037 cos i can use it everyday un-like nos.
sixthly:most of my mates have old school v8s that run 11ns and i wanted to at least give them a better run .
sevenly:my mate how has a R32gtr has relit my greed for more power well thats what i told my wife so marko its your fault...thats the story im sticking
Wait for a SAU or club "dyno day"
Just saw this thread for the first time VERY impressive and a nice selection of mods.
I too have a HKS GTRS kit; but running Tomei Poncams, head porting, std plenum and std bottom end. My a/f ratios were kept at approx. 11.5:1, to keep the engine "safe". Running 18psi i made 268.2rwkw, but your response is WAY more impressive. Could be due to the plenum, cams, fmic (i was using a truck core), but most probably to the fresh rebuild.
The engine has since blown, while i was at a race track (cyl #3 dropped compression), and i have decided to build an rb2530, which means upgrading the turbo, again. I guess i will never know what the GTRS's true potential is, but yours demonstrates it clearly. Well done mate, an excellent build and it would feel awesome to drive.
Below is a comparison between our two graphs, you will be happy:
For my new engine i have bought a new GReddy plenum, XTR 100mm fmic, Garrett GT30R turbo 500hp (smallest recommended turbo), ATI balancer and a whole lot of other parts. Unfortunately it takes my mechanic a lot longer than 3 weeks to build an engine, but we'll get there.
All the best and enjoy :D
Damn 11 months since that post and i am only getting the car back this week :)
Car was ready 4 months ago, but had to go back to be rebuilt as the block used had a pin-hole and was weeping oil.
Any built as described in my quoted post: not sure i mentioned rb30det, and using a 70mm core not the 100mm
Note: Dyno graphs for "running in" tune. Once run in car will be tuned properly with an extra 5psi, more aggressive timing, adjustments of the IN and EXH cam gears and 8000rpm rev limit.
Damn 11 months since that post and i am only getting the car back this week :banana:
damn, that looks awesome Al! Can't wait to see it at a SAU event- you'll have to take me for a spin - i was plently impressed with you previous setup - this ones gonna be a monster! :thumbsup:
I've got the GTS4 booked in for cam gears and a retune - but any gains will seem pathetic compared to your's! :yes:
Thanks for that.. I might give it a try when i got some time..
hows my toyo t1rs going? lol
Believe it or not, they have just been fitted to the car last week :banana:
I am yet to drive with them, but all should be good, read some good reviews on them, before i bought them off you.
damn, that looks awesome Al! Can't wait to see it at a SAU event- you'll have to take me for a spin - i was plently impressed with you previous setup - this ones gonna be a monster! :banana:
I've got the GTS4 booked in for cam gears and a retune - but any gains will seem pathetic compared to your's! :)
Thanks Phil
Next time we meet, i'll take you for a drive mate. It's totally different to the way my rb25det setup delivered power. In the dry, this is more tractable and doesn't tend to kick out violently; unless you want it too :)
Good luck with the re-tune buddy!
Thanks Sly33 & Warlord,
No build-up thread unfortunately.
Can't wait to wind it up myself. You can't see it in the pic, but at the moment i have a direct line from the comp cover to the actuator, no solenoids, restricters or boost controllers. In most setups, this normally makes the power feel doughy or laggy, but i get 1bar of boost by 2800rpm :banana: So once the engine is bedded in we'll be playing around a fair bit with the set-up and extract as much response and power as possible.
Dotted line = Power curve
Solid Line = Boost curve
    • Yeah good luck out there! Will be good to see a mighty GTST going harder than the GTRs
    • i will be there 😁
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
