Q; What is the difference between a series 1 and series 2 R33 Gtst?
A; There are several differences...
  • The front end of the series 2 is sharper, slimmer headlights, different front bar (indicators and fog lights are round and located at the bottom of the bar). The bonnet has much sharper ridges.
  • The "skyline" panel at the rear of the car is body coloured on the series 2.
  • The interior of the series 2 has been updated including different trim, a passenger airbag and the dash facia has been updated.
  • Mechanical differences include an updated ECU and a ceramic turbo.
  • The series 1 was in production from late '93 through to late '95. The series 2 ran from early '96 through to early/mid '98.
https://www.sau.com.au/forums/topic/17349-r33-gts-t-series-1-and-2-differences/
  • 8 months later...
Also the S1 has an ignitor located on top of the motor at the back on the rocker cover near the firewall, whereas the S2 has the ignitor built into the ECU. Another small differance is the headlight backings, where S1 has black backing and S2 has chrome backing.
  • 1 month later...
  • 3 weeks later...
There are some similarities though, i believe the 'different wing' on the Series II (think it's called an M-Spec?) also appeared on some of the series I (or 1.5) 33's as well. Plus the other day i saw the lower stock R33 Series I wing on a car that had the Series II skyline imprint on the boot, and not the panel of plastic. This may have been custom though.
here is something else for you, in 1995 there was a series II also, it had the series I front, but had the series II engine, dual airbags, colour coded rear skyline badge, updated interior, different seat trim to 93-94, not the same as 96, series II instrument panel, series II floor mats.
  • 3 weeks later...
Here's what my '95 R33 has, which is still a bit different again. Not sure when it was made other than 1995.
Series 1 - front bar, steering wheel, with airbag, interior (velour) but with updated pattern (not quite as dark), rear badge (clear plastic and silver letters, not colour coded).
Series 2 - wing, engine, boot lid badge (titanium)
??? - instrument cluster (I wouldn't know the difference), suspension
??? - grille (which I quite like) that's kind of like a rounded GTR grille rather than the slat style of most that I've seen. I think this was just a factory option though, I've seen very few around, and some '95 models with the slat grille.
NO passenger air bag
And while we are dumping shit on other people's Skylines, I would just like to say that the indicators on the Series 2 front bar look like huge blocks of Lego (blerghhh!) :)
everyone mixes answers to which turbo is which up
this is the difference.
the series one AND two exhaust wheels are ceramic, and prone to delaminating from the shaft, due to excess heat and resistance, resulting in bits of tubo stuck in your cat :)
The difference is in the intake side.
The intake wheel of a series one turbo is steel, where in a series two (and even r34 gtt) has a nylon wheel. this results in a quicker spool up.
the problem is not with the intake side of the turbo, its the exhaust, so if you had to compare the two, the series 1 turbo is no less likely to fail than a series 2 turbo.
Ive just about finished putting a motor out of a series 1.5 into my series 1.
dunno if anyone cares, but the clips for the coil packs are a bit different, so i had to swap them and the harness from my blown series one motor and put them in the series two, but again, dont know if anyone cares about something so trivial...
  • 4 months later...
  • 3 weeks later...
i know i've gone thread digging but i wanted to know if anyone has heard of a series 2 being made in 1995. not a series 1.5 but a full series 2??? and do people commonly find importers reffering to 1.5's as series 2???
    • Bit of a pity we don't have good images of the back/front of the PCB ~ that said, I found a YT vid of a teardown to replace dicky clock switches, and got enough of a glimpse to realize this PCB is the front-end to a connected to what I'll call PCBA, and as such this is all digital on this PCB..ergo, battery voltage probably doesn't make an appearance here ; that is, I'd expect them to do something on PCBA wrt power conditioning for the adjustment/display/switch PCB.... ....given what's transpired..ie; some permutation of 12vdc on a 5vdc with or without correct polarity...would explain why the zener said "no" and exploded. The transistor Q5 (M33) is likely to be a digital switching transistor...that is, package has builtin bias resistors to ensure it saturates as soon as base threshold voltage is reached (minimal rise/fall time)....and wrt the question 'what else could've fried?' ....well, I know there's an MCU on this board (display, I/O at a guess), and you hope they isolated it from this scenario...I got my crayons out, it looks a bit like this...   ...not a lot to see, or rather, everything you'd like to see disappears down a via to the other side...base drive for the transistor comes from somewhere else, what this transistor is switching is somewhere else...but the zener circuit is exclusive to all this ~ it's providing a set voltage (current limited by the 1K3 resistor R19)...and disappears somewhere else down the via I marked V out ; if the errant voltage 'jumped' the diode in the millisecond before it exploded, whatever that V out via feeds may have seen a spike... ....I'll just imagine that Q5 was switched off at the time, thus no damage should've been done....but whatever that zener feeds has to be checked... HTH
    • I think Fitmit had some, have a look on there (theyre Australian as well)
    • Hah, fair enough! But if you learn with this one you can drive any other OEM manual. No modern luxury features like auto rev-matching or hillstart assist to give you a false sense of confidence. And a heavy car with not that much torque so it stalls easily.
    • Actually, I'd say all three are the automatic option. Just the different trim levels. The manual would be RSFS, no?
