  • Replies 89
Posted Images
You know its a 25 yeah. Its making 8psi at 2000 and full boost at 3500. Said to be one of the most responsive cars race pace has tuned. Everything seems to be working really well together.
So it has a 25 bottom end with 26 head and plenum? It looks to be a 3071R or 3076R based on the comp cover?!?!?! Sounds very nice and responsive. Very keen to see it at the track. LOL. i would so give you my new suspension (Tein RAs) and brakes (Brembo f50 on 340mm rotors) so we can see an R32 GTSt with all the good gear mixing it with the GTRs :domokun: (if only i could afford to )
I do have my now spare Bilsteins that i was going to get re-valved and new platforms on to suit Eibach springs
I said it before and i'll say it again: Looks awesome!!!
Top work Adz.
Bris: it's a rb25 head and bottom, soon to be stroked to rb28. Only using plenum and throttle bodies.
Is the Garrett 3037 bigger or smaller than the Garrett GT30R (GT3076R, 500hp)?
So it has a 25 bottom end with 26 head and plenum? It looks to be a 3071R or 3076R based on the comp cover?!?!?! Sounds very nice and responsive. Very keen to see it at the track. LOL. i would so give you my new suspension (Tein RAs) and brakes (Brembo f50 on 340mm rotors) so we can see an R32 GTSt with all the good gear mixing it with the GTRs :thumbsup: (if only i could afford to )
So yeah as Al said its a RB25 head and bottom end with RB26 plenum and throttle bodies. It requires a Blitz adapter plate which is very hard to find in aus these days. I believe I have one of two in Aus supplied by Autobarn. You then need to re fabricate the thermostat housing to clear the VCT and relocate the idling gear as well as fit a RB26 oil filter adapter. Im sure there would be some other little tricks involved that only Race Pace know.
The turbo is a 3037 garret equivalent which is a 3076R. I really wanted to put big brembo's on but will see how the current set up goes and might have to wait for the bank to gain confidence in me again lol. Should give a few GTR's a run for their money.
Dont want to drift it atm as its too pretty and I dont want to muck it up in a hurry. Im sure drift will get the better of me sooner or later. Pretty sure it will be drifting by Christmas.
I wonder if the variable timing of the 25 head and PFc combined with the inlet plenum is the reason why the thing is so responsive. So what is th efinal mumber the car makes with the 3076R?
Does sound nice...please tell me it has open gate...the invasion of the loud GTSts :thumbsup:
Dude!!! Open gate all the way.
Yeah thats what I was going for. The setup is garenteed 40hp at the wheels straight up with heaps of response. In fact its all working a little to well. Due to the low back presure exhaust system and an efficent intake set up the exhaust gasses prefure to go throught the turbo than out the wate gate so shes over boosting. So final power figures and dyno sheets are not available. A new manifold and a 48mm wastegate are on their way to fix it all up. Then its time to finish the tune and shes done. Looking to make 300kw on good fuel day in day out on stock internals.
CHAMPION :thumbsup: Stock internals GTSt all the way BABY!!!!!!!!!!!! :O
I have an adaptor for the inlet drawn up and ready to do a mock fit up with for the RB25 inlet side using the RB26 inlet. Also the exhaust side as i dont think i can turn 100% homo and go low mount twins on the 26 head. I think i need to make up my adaptor plate so that i can run my RB20/25 HKS exhaust manifold with Brother Gate providing the tunes, all with the reliability of low mount cast manifold. All the plans depend on what i can source at a decent dollar figure...as beign atight ass R32 owner, i wont dare spend more more then 60% of what i spend per week on grog and Indan :D
    • Well, the trouble with that ^^ is: The configuration shown is absolutely a 1-way, not a 1.5-way. There is no way that a 1.5-way can be said to offer LSD action only on acceleration. If Nismo cannot get that right, then it is impossible to believe their documentation. That ^ is not a 1.5 way setup. That is a 1-way.   And so now I have allowed all doubts to flourish and have gone back to look at the MotoIQ video. I originally made the mistake of believing him when he said "this is a 1.5-way" at the ~6:10 mark. Because what he did was take the gear assembly out of the 2-way opening and just rotate it one place to the left to drop it into the 1-way opening. When he dropped it in there, the cam was "backwards" compared to the correct orientation shown in all other photos of that config. The flat shold have been facing the 1° ramp side of the opening, not the 55° ramp side. And I thought, "gee that's cute", but I was concerned at the time, when he put the other ring back on, that the gap between the rings looked like it was wider then in the 2-way config. And then I said a lot of things in my long post on Tuesday that could only make sense if the guy from MotoIQ was correct about what he'd done. BUT... I have now done my homework. I grabbed a frame of the video with the 2-way config, and then grabbed another with the "1.5-way" config, snipped out the cam and opening of that frame and just pasted it direct on top of the 2-way config. I scaled it so that the triangular opening was almost exactly the same height in both. AND.... the gap between the plates is wider with the cam installed in the triangualr opening backwards. That is.... it cannot go together that way. There would be massive force on the plates all the time, if you could even reassemble it.  So, My statement on the matter? The Nismo diff is actually only a 2-way and 1-way. There is no 1.5-way option in it, regardless of what they say. Here's a photo of a real 1.5-way ramp opening from Cusco (along with the 1 way option). And the full set of 1 through 2 way options from their racing diff, which is not same-same as what we'd typically be using, but...the cams work the same. A little blurry, but it comes from this Cusco doc, which is quite helpful. AND.... Cusco do in fact do what I suggested would be sensible, which is to have rings that do 1 and 1.5, and 1.5 and 2. Separately.
    • Welcome Adam. Car looks great!
    • "With a 1.5-WAY, the LSD is effective only during acceleration."
    • Well it wasn't as easy as I thought.... and it also wasn't in my original manual which I did end up finding. They discuss the process in the Nismo catalogue though and it requires slight machining. Page 145.  NISMO PARTS CATALOGUE 2020
    • I'm an idiot, my intercooler is rated for 1000hp. I had clicked on the wrong product. Knowing the delta P would be nice, but I'm doubtful I'll do it. Now as for an EMAP, that would be great and I'll get around to it eventually but from my findings in my last post, I'm considering a turbo swap now.
