  • Replies 89
Posted Images
You know its a 25 yeah. Its making 8psi at 2000 and full boost at 3500. Said to be one of the most responsive cars race pace has tuned. Everything seems to be working really well together.
So it has a 25 bottom end with 26 head and plenum? It looks to be a 3071R or 3076R based on the comp cover?!?!?! Sounds very nice and responsive. Very keen to see it at the track. LOL. i would so give you my new suspension (Tein RAs) and brakes (Brembo f50 on 340mm rotors) so we can see an R32 GTSt with all the good gear mixing it with the GTRs :domokun: (if only i could afford to )
I do have my now spare Bilsteins that i was going to get re-valved and new platforms on to suit Eibach springs
I said it before and i'll say it again: Looks awesome!!!
Top work Adz.
Bris: it's a rb25 head and bottom, soon to be stroked to rb28. Only using plenum and throttle bodies.
Is the Garrett 3037 bigger or smaller than the Garrett GT30R (GT3076R, 500hp)?
So it has a 25 bottom end with 26 head and plenum? It looks to be a 3071R or 3076R based on the comp cover?!?!?! Sounds very nice and responsive. Very keen to see it at the track. LOL. i would so give you my new suspension (Tein RAs) and brakes (Brembo f50 on 340mm rotors) so we can see an R32 GTSt with all the good gear mixing it with the GTRs :thumbsup: (if only i could afford to )
So yeah as Al said its a RB25 head and bottom end with RB26 plenum and throttle bodies. It requires a Blitz adapter plate which is very hard to find in aus these days. I believe I have one of two in Aus supplied by Autobarn. You then need to re fabricate the thermostat housing to clear the VCT and relocate the idling gear as well as fit a RB26 oil filter adapter. Im sure there would be some other little tricks involved that only Race Pace know.
The turbo is a 3037 garret equivalent which is a 3076R. I really wanted to put big brembo's on but will see how the current set up goes and might have to wait for the bank to gain confidence in me again lol. Should give a few GTR's a run for their money.
Dont want to drift it atm as its too pretty and I dont want to muck it up in a hurry. Im sure drift will get the better of me sooner or later. Pretty sure it will be drifting by Christmas.
I wonder if the variable timing of the 25 head and PFc combined with the inlet plenum is the reason why the thing is so responsive. So what is th efinal mumber the car makes with the 3076R?
Does sound nice...please tell me it has open gate...the invasion of the loud GTSts :thumbsup:
Dude!!! Open gate all the way.
Yeah thats what I was going for. The setup is garenteed 40hp at the wheels straight up with heaps of response. In fact its all working a little to well. Due to the low back presure exhaust system and an efficent intake set up the exhaust gasses prefure to go throught the turbo than out the wate gate so shes over boosting. So final power figures and dyno sheets are not available. A new manifold and a 48mm wastegate are on their way to fix it all up. Then its time to finish the tune and shes done. Looking to make 300kw on good fuel day in day out on stock internals.
CHAMPION :thumbsup: Stock internals GTSt all the way BABY!!!!!!!!!!!! :O
I have an adaptor for the inlet drawn up and ready to do a mock fit up with for the RB25 inlet side using the RB26 inlet. Also the exhaust side as i dont think i can turn 100% homo and go low mount twins on the 26 head. I think i need to make up my adaptor plate so that i can run my RB20/25 HKS exhaust manifold with Brother Gate providing the tunes, all with the reliability of low mount cast manifold. All the plans depend on what i can source at a decent dollar figure...as beign atight ass R32 owner, i wont dare spend more more then 60% of what i spend per week on grog and Indan :D
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
    • When you pulled it off, there is no signs of blown head gasket? Is it possible you have some other issues going on? Possible cracked blocked? Or do you think it's straight up lifting the head? Did you check what the head was torqued to before pulling it down (To see if possibly they're stretching, or starting to break threads out etc)?
    • Seems like a decent result for a modded JZX110. They are bulky in comparison to the 100 and 90 models (which I'd prefer myself) but they are getting very few and far between here in JP these days. Thanks for the detailed review and the import process into the UK. I also have a car which I'm hoping to export from Japan at some stage so it's good to know if someone from the UK was interested in it. By the way the corrosion underneath is par for the course for cars which were located in/near the mountains or along the Japan sea coastline. They get huge amounts of snow every winter and the sodium chloride is used on the roads. Many cars have some kind of rubber like treatment underneath but they tend to limit it to the wheel arches underbody and fuel tank. Suspension arms and sub-frames will have similar corrosion to your JZX110 which is a common sight. See it all the time and car dealers here generally don't even mention it unless asked.
    • If the sound goes away when you clutch in, the 1.5/2 way diffs are just shit, and you are a normal person. The diff is likely "fine" but driving at anything under 30kmh is a violent horrible experience. It would be exaggerated with solid diff bushings and subframe bushings if you have those.
