Well, I had no hand in building my car but I sure have pulled it apart and put it back together many times. Poor Duncan has been under my car more than I care to think about.
The car started out as a track day weapon because the wifey told me no more thrashing the Skyline. So a car was needed that was as fast or faster than our GTS-T. 7 grand was the original price but that has blown out ages ago. Lets see what I can remember of just the breakages. 1st motor was crap,,,rebuild lasted no time,,,2nd rebuild was a little better, my god rotors are quick,,time for another one,,,this time on a very limited budget I had better reliability and more power(lots of 2nd hand parts) and now injected. Now I'm going all out with a NEW engine. Ah I forgot 2 gearboxes about 5 axles and a diff that exploded up Bathurst Mountain straight that frightened the living shit out of me.
Neil.
yeah vg - vq runs timing chains.
neil....you need to post up an engine bay pic, its enough to make anyone who has ever worked on a skyline cry about the acres of space. not to mention 1 person/ about an hour to take the gearbox out without hoist
*** DISCLAIMER ***
Car's owner doesn't understand all those bendy bits he keeps seeing in your photos. Talk slowly and in words of three syllables or less and he probably won't brain haemorrhage.
Hahaha, Im with him^^ what are corners??
Will you be ready for jambo mate? My rings and bearings arrived from america yesterday... .25 oversized instead of standard... FARKING STUPID IDIOTS! ah well rather then cry the crank will now be ground to suit... otherwise there will be no jambo for me...
Love the old ZED!!!
What do you do after you take the car off the road for close to 12 months tidying up the bodywork? Well you go to Sandown and get it wrong and end up doing this :)
That was quick :D
Bloody hell with all these flash paint jobs on race cars i gunna have to throw a coat or two of jam onto my old girl.
try as i might i can find a good pic of the old girl lol if you look close you can still see the gel coat on the bonnet. Still it has cost only 13k to date with new turbos and brakes and radiators and and and......
Whats happening with you mate. No money I except???.
g'day neil
mate the last time my rb30det ran was jan 06. the shell has been sold and the donk is now in a hr31 coupe. as of tomorrow's payday i am 100% debt free. all money from hereon in will be sent towards car. last week picked up my jcc widebody kit from powerplay (cost me the same price as what the entire car cost me. stupidity, but what the heck). same kit as on this jap group a hr31 ive uploaded
ive stripped the coupe, then it goes to be caged, kit fitted and painted up.then cams log book then swapped to race/rally rego.
then i'm back in the game. just fun track days, some drag days, and hopefully my aim is joining you on the hillclimb meets
cheers, mark
    • So for the wide band is a Bosch 4.9 correct for the Link G4+ along with a Can bus? Just get the Link gear or is generic ok too? Eg here: LINK LINK DIGITAL WIDEBAND CAN MODULE WITH BOSCH 4.9 SENSOR : KYP Performance House
    • Bit difficult to follow. Have a look below and see what the standard R32 layout was like. Note there was a restrictor in place immediately before "turbocharged pressure control solenoid" that, if removed, magically got you 1 bar boost.
    • I might be way off the mark here.. there must be a T junction under the manifold. That takes manifold pressure through a check valve prior to the T, one side splits out to this bleed off orifice, the other straight to the wastegate actuators.
    • Carrying out some engine due diligence before my first drive in a 260RS that has been in storage for 10+ years, and found two lines that are susposed to be plumbed into the boost control solenoid. One of the lines (the wastegate boost supply line) to actuate the gates, had a bolt in one end blocking it. The other line (main boost signal line) from the very rear of the intake manifold (RB26DETT) and runs up to the boost controller had this pill in the end of it as seen in photos. Other than the obvious (T28 Ceramic turbos might well be cooked)  Can anyone shed any light on if there is any validity at all with this mod, bleeding a constant fixed rate of manifold boost pressure off through this 3mm hole?  Is it deliberate?  Was this a 90s Jap mod done to RB26's? Or has someone just fitted this without any idea of what happens to ceramic T28s if they are not gate controlled?
