Anyhoo,
my first little incident on the track.
Ohh, accident damage! How many of you guys out there have some pics to share?
Here's my first attempt at crashing a car las year. Don't know if you've seen it already.
Bent the rear suspension arm and buckled two wheels, smashed back window, dented the fuel tank, smashed headlight etc. Got it fixed in two weeks and didn't miss an event!
My latest attempt from the other week, just clipped a bank on my way to 2nd in class and my fastest run of the day.
Many have already seen this, but this is the first lap of a supersprint at Sandown....
Gearbox was blowing fluid out the breather and split boot all over the underside of the car = locked rear brakes OR shitty suspension just didnt ride the bumps of the back straight so locked up over the bump OR just ran out of talent :ninja:
Screamin: Love the car, and the fact that you rally it!
Rally is my favourite form of motorsport, but I've never looked into it too much as I have always thought it would be massively expensive.
Do you have any details of the events you do in NZ? What kind of costs are involved for a year, if you don't mind me asking?
Cheers
Dane
hehe nice stacks!!
here's mine, no brakes and then pulling the handbrake on in shear panic!! nearly ran into the porsche 4wd in the background
Ive seen that video heaps, always wondered who owned that car!
I think you done well to only sustain the damage you did. :ninja:
Gearbox was blowing fluid out the breather and split boot all over the underside of the car = locked rear brakes OR shitty suspension just didnt ride the bumps of the back straight so locked up over the bump OR just ran out of talent :D
Some big offs there boys! That's the first time I've seen the vid of yours Troy, geez you were lucky mate...
I remember seeing the incar vid of yours Russ, scary stuff.
Well, my car is making a bit more progress, so hopefully not too long now. I just got my new plenum, fuel rail, throttle body, injectors and FPR, as well as my rocker cover back with new fittings added to it. Also had the bay seam welded and painted. Now I just need to get my manifold sorted and we can put the last pieces back together. Can't wait to get back in the thing, it's been way too long! :thumbsup:
plenum looks hot Dane :pwned:
it will be cool to see your car back out there...
so, now that you have the seam work, sell me your tomei tri point brace, it won't fit over your plenum... there's no point even checking, safer to just send it my way ;)
I think you done well to only sustain the damage you did. :pwned:
Yeh i was lucky....here is me doing my best attempt at looking shocked by the damage...fact is i was stoked that it was as minor as it was.
In hindsight i normally give the car two laps before i have a go...if i had of stuck to that routine i would have picked there was something wrong on the warm up lap. I went for it on the first lap as i wanted to bag a time and wanted to get on with it before the tyre and water/oil temps got too high. Sandown has so much wide open throttle that temps in my car really climb quickly. Oh well ;)
Well its not the most embarassing thing to do, have an off, at least you were having a red hot go. Not putting the bonnet pins in...... theres a story.
I lost some of it along the way and need to have it in better shape for Gatton this weekend, So it is dodge it up time in the shed.
I will have to get a new one soon. I promise.
Cheers
Dane
It's really cheap when compared to building a car for track work. The biggest money saving factor is that hp doesn't always help you go faster on the loose stuff.
My car is just a stock engined GTS. Currently building a new motor but.
I stripped the car myself, got all the panel work fixed (the car was pretty rough) put in a cage, race seats, harnesses, removed the HICAS etc and was on the startline of my first event for $4,500NZ including buying the car for $1,000.
Ongoing costs are not bad, as long as you don't keep crashing! I've been rallying the car for 12 months and now I'm starting on some development work with suspension, engine etc, so I'll be spending some coin now.
At Clubsport level you don't need the best of everything, I run against some pretty trick Escorts and one big $$$ R30 - was only 0.5 seconds of him the other weekend!
If you want to see the build and more rally pics go here: (that's if the website server doesn't crash!)
screamin' rally
    • Well, this is probably where a wiring diagram and a multimeter come into play.
    • I can say to anyone thats doing this; having done a number of R clusters; just be careful if its an unknown cluster.  It takes a bit of force to pull up; but if it feels excessive then its probably stuck. I've had this and pulled the entire hair spring out; and I can tell you; its not easy getting the correct spring replacement with the correct inner diameter and winding. In my case someone had used some sort of adhesive to stick it to the spindle and it pulled the whole spindle out; which the force seperated the hairspring from the spindal and caused it to deform.  You may have to clean it (IPA); or in my case if i'd known i should have used some sort of solvent on it.  Also check out Cruizin Central on eBay. He does all sorts of dials; and you can email him with any custom designs you want. So if you want like certain logos etc...he'll send you a mock of what it will look like then you accept the order and he'll take care of the rest. Fantastic dials and he can do basically any design you want.
    • Have you confirmed its the actual axles? Also the wheel bearings that mount on the hubs to hold the axles wear out. I replaced mine as they got play in them. It sorted my play issue.
    • Ive converted a few clusters for the R33 with 320km/h dials. On the back there are some pads which can be bridged or unbridged (using solder or wick braid) to calibrate it. There is one bridge which is for MPH <> KPH; and there are combinations of bridges to offset it. There is probably a diagram  For example; this is my conversion for a 180km/h dial to a 320km/h dial (I put custom GT-R dials on it with the GTS25t layout) If you have J2 soldered (assuming the S clusters have a similar config to the R clusters); you may need to remove that solder
    • Back on topic 😉, these are some of the notable pages from the booklets that are supplied with each weekly parts update. I never knew the BNR32 test mule car had an S13 Silvia front end... *Edit: On closer inspection the test car still had the R32 body, but only the front end had Silvia panels etc.
