My old car had high rollcentres which is actually quite dangerous, I reckon if the roll centre is under the ground then the car can't roll above the ground! :)
As you found out, that isn't true. High CoG and low CoR = fall over (technically called excessive roll couple).
Cheers
Gary
Way to ruin my stupid joke with facts and reason and logic!!! :wub:
To be honest I think the main problem was too much Peugeot.
pauls twoogle , is one beautiful looking r32 too ! it's a credit to him.
ross, yeah, the oil to water oil coolers are great, we are seeing much lower engine oil temps now! before we were seeing up to 130 degree's!
cheers russ
+1 for twoogle. Looking good on the DVD too Russ again well done.
Also thanks for the info i think ill get one as it can get hot here in wa.
lol. you crazy kid.
laurence.... world famous gaijin drifter and amatuer stunt driver extrordinaire
+1 again. :D Laurence hope your trip home was good.
Ross
i have ordered one of these Maple A-1 Gages, should arrive in a few weeks. will keep everyone updated once i get some camber & castor bushes in.
anyone know the equations required to calculate castor?
Hey mate, how did you go with this kit if you don't mind me asking?
Cheers
Dane
I finally went past a newsagency and got my hands on a copy of HPI with the ignition DVD...
Hioctane GTR OMG!
the incar footage of that thing is something else!
The full lap of incar is incredible.
great work guys, it will be damn interesting to see how things will pan out with a few hundred less kilo's in the car.... or another car for that matter.
and perhaps some super sticky rubber, similar terminal speed to the Msports GTR says it all.
i can't get over that.... :blink:
Cheers
Dane
in my final year of uni so i've only had fiddle with it - but not on track just yet.
i've spoken to sydneykid and managed to work out a few formulas to calculate the necessary alignments. the thing is there's nothing to compare it to - cant even go in to get a laser alignment to confirm the settings.
so far so good, from the minimal amount of play i've had i have no doubts that i've got the exact settings it tells me i have.
    • Then, shorten them by 1cm, drop the car back down and have a visual look (or even better, use a spirit level across the wheel to see if you have less camber than before. You still want something like 1.5 for road use. Alternatively, if you have adjustable rear ride height (I assume you do if you have extreme camber wear), raise the suspension back to standard height until you can get it all aligned properly. Finally, keep in mind that wear on the inside of the tyre can be for incorrect toe, not just camber
    • I know I have to get a wheel alignment but until then I just need to bring the rear tyres in a bit they're wearing to the belt on the inside and brand new on the outside edge. I did shorten the arms a bit but got it wrong now after a few klms the Slip and VDC lights come on. I'd just like to get it to a point where I can drive for another week or two before getting an alignment. I've had to pay a lot of other stuff recently so doing it myself is my only option
    • You just need a wheel alignment after, so just set them to the same as current and drive to the shop. As there are 2 upper links it may also be worth adding adjustable upper front links at the same time; these reduce bump steer when you move the camber (note that setting those correctly takes a lot longer as you have to recheck the camber at each length of the toe arm, through a range of movement, so you could just ignore that unless the handling becomes unpredictable)
    • I got adjustable after market rear camber arm to replace the stock one's because got sick of having to buy new rear tyres every few months. Can anyone please let me know what the best adjustment length would be. I don't have the old ones anymore to get measurements. I'm guessing the stock measurement minus a few mm would do it. Please any help on replacing them would be fantastic I've watched the YouTube clips but no-one talks about how long to set the camber arm to.
    • Heh. I copied the link to the video direct, instead of the thread I mentioned. But the video is the main value content anyway. Otherwise, yes, in Europe, surely you'd be expected to buy local. Being whichever flavour of Michelin, Continental or Pirelli suits your usage model.
