My old car had high rollcentres which is actually quite dangerous, I reckon if the roll centre is under the ground then the car can't roll above the ground! :)
As you found out, that isn't true. High CoG and low CoR = fall over (technically called excessive roll couple).
Cheers
Gary
Way to ruin my stupid joke with facts and reason and logic!!! :wub:
To be honest I think the main problem was too much Peugeot.
pauls twoogle , is one beautiful looking r32 too ! it's a credit to him.
ross, yeah, the oil to water oil coolers are great, we are seeing much lower engine oil temps now! before we were seeing up to 130 degree's!
cheers russ
+1 for twoogle. Looking good on the DVD too Russ again well done.
Also thanks for the info i think ill get one as it can get hot here in wa.
lol. you crazy kid.
laurence.... world famous gaijin drifter and amatuer stunt driver extrordinaire
+1 again. :D Laurence hope your trip home was good.
Ross
i have ordered one of these Maple A-1 Gages, should arrive in a few weeks. will keep everyone updated once i get some camber & castor bushes in.
anyone know the equations required to calculate castor?
Hey mate, how did you go with this kit if you don't mind me asking?
Cheers
Dane
I finally went past a newsagency and got my hands on a copy of HPI with the ignition DVD...
Hioctane GTR OMG!
the incar footage of that thing is something else!
The full lap of incar is incredible.
great work guys, it will be damn interesting to see how things will pan out with a few hundred less kilo's in the car.... or another car for that matter.
and perhaps some super sticky rubber, similar terminal speed to the Msports GTR says it all.
i can't get over that.... :blink:
Cheers
Dane
in my final year of uni so i've only had fiddle with it - but not on track just yet.
i've spoken to sydneykid and managed to work out a few formulas to calculate the necessary alignments. the thing is there's nothing to compare it to - cant even go in to get a laser alignment to confirm the settings.
so far so good, from the minimal amount of play i've had i have no doubts that i've got the exact settings it tells me i have.
    • Can u check this way it works for power supply?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
    • That worked out PERFECTLY! Thank you big time to JJ. He was able to swap me his stock diff. He drove all the way to me as well. Killer! Removal & install was pretty straightforward. The diff itself is HEAVY. So that’s a 2 man job.  Man does the car drive nice now! Couldn’t have worked out any better 👌
