Suspension wise i would be clueless as well. But as they are commonly used for a bit of drift both in the US and in Japan you should be able to find a reasonable amount of info, particularly for the front end.
Why webers?
Suspension wise I am not to sure... More research will need to be done!
use custom compact weld on sleeves.
http://www.ae86drivingclub.com.au/forums/s...ead.php?p=75969
dunoo, will have to ask him. Maybe google the name above the door if you can make it out.
also, bought this from Revzone in melb.
replacement rear half should be arriving at the shop next week. rebuild imminent. tempted to chuck an SR in it for shits n giggles :P
Looks like Trevor Voss' old car, was a nasty wack at Dandenong Rd corner at Sandown...
Cut & shut FTW!! :teehee:
just cut the fkn thing off and put a long rear on it....its stuffed you dont need no underbody measurement for that :teehee:
well we've bought a long rear and waiting for it to get to the shop. altho I'm hoping the driver side rear quarter is salvageable.
Why webers?
Well its that or dellorto's or scoring a 20V on the cheap...
My reasoning seems to be based around nostalgia and noise more than anything - call me indulgent :teehee: .
In terms of size, my carb tuner recommended 40's if its a daily and 45's if its seeing race and high rpm use. Expected outcome will be doughy down low (he said from 2500 rpm and below) but above that it should be peachy with excellent high RPM response.
He seems to believe with the cams I am looking at it will all come together nicely.
Just an idea of what they sound like with carbs for those who don't know:
http://www.youtube.com/watch?v=HrXMSCRHwug...feature=related
except benms lone nascup car which of course was US built or at least designed.
Designed and built in USA more than 10yrs ago (with minor updates done to chassis and new shell designs over the past 10yrs).
I'd much much rather be in an accident or rollover in my nascup (baby grand mmra) car than in the current Aussie Racing Cars due to the chassis/cage design. But then, i'd much much rather own an Aussie Racing Car than my Nascup car but not for the extra $20k purchase price.
I think the suspension plans for my car are thrown out the window.
I am kind of sticking to improved production guidelines because if I ever got serious thats the path I would take. It seems that I am unable to change the rear suspension to a type other than stock apart from the obvious springs / shocks and so on.
Exerpt from rules:
9. SUSPENSION AND STERING
9.1 Springs: Springs are free provided that the type and location are unchanged (by type is meant: coil, torsion bar,
leaf etc.)
Am I correct in thinking that I would be unable to change to weld in coilovers?
Weld in coilover suspension for the rear. Essentially changes strut suspension to coilovers. Erm its easier for me to link the product:
http://www.fullboost.com.au/forum/showthread.php?p=42402
KE70's have a five link rear end stock.
So changed the springs to 6kg - I had harder springs in for a little while but I found it made the rear even MORE tail happy when I just want something fairly neutral with perhaps a touch of oversteer. New adjustable shocks. New canard bar. New heavy duty Whiteline sway bar and strut bar coming. Lots of polyeurethane bushings. Also scored some free power - removed everything in the boot, rear seats, some sound deadener and most of the centre console. Enough to be an advantage but no so much that I would be uncomfortable as I am driving it on the street a lot of the time still.
Hell it weighs 940 kilos stock (or there abouts) anyhow :thumbsup:
repost all the pics of your car dane! forum lost our posts. :D
anyway, carrying on from our now invisible conversation I went out and got one of those green tomei 3 point braces for the S13. I'm not impulsive :)
was not too bad on price, and will be here today. schweet.
haha! awesome work, i paid nearly $300 (incl ems) and had to wait a month for one to come up on yahoo jp, you were very quick!
i actually noticed a positive difference in the front end "feel" of the car when i swapped out the old cusco and installed the tomei.
    • Increasing overlap will bring the torque down earlier (and make your idle sound sick lol). Worth a shot (if you dyno time) to experience a bit (providing you are confident your valves won't kiss your pistons). Is to just take off 5 degrees across the boosted area of the map, and then retard the exhaust cam let's say, 3 degrees at a time and then overlay all the runs with VCT on all the way and VCT off as soon as you make positive pressure. Ideally you would have a total of 6x overlays to looks at 0 exhaust & VCT off once manifold pressure is +ve 0 exhaust & VCT on all the way -5 exhaust & VCT off once manifold pressure is +ve -5 exhaust & VCT on all the way -10 exhaust & VCT off once manifold pressure is +ve -10 exhaust & VCT on all the way Just leave your O2 wideband closed loop on for all of the boost area & RPM, and hopefully there isn't too much fuel correction needed and the Haltech is fast enough to compensate (I do this, then apply the correction to the main table). Getting that overlay data should give you a good indication of what to aim for.
    • So, my main limitation here is that the car does not have an oil pressure sensor by default, just a switch. As part of my tune I bought an oil pressure sensor upgrade so I now have access to oil pressure levels and logging rather than just the boolean behaviour of the switch but this means I need to use the tuning app to display this value. So, this rules out using any other app on the iPad. The app will also flash when pressure drops which is a nice feature. I have replaced the centre screen with an Android one, which is awesome for Android Auto, but I think it might be too far away and out of my line of sight. I might add some gauges to it this weekend and just see. I guess if its just temp and oil pressure I can make them massive! 🤣
    • This is what the look like normally. Except we only got the 2 doors locally
    • Back pressure is not really a function of the exhaust itself, but the turbine/housing. So the question/point remains valid. I would be fitting an EMAP tapping point and seeing what is going on in the exhaust manifold before committing to throwing boost at it. Flow. No intercooler is actually rated for continuous operation at any power level wrt temperatures, as they are no actually capable of shifting the required amounts of heat on a continuous basis. They get hot during a pul, then dump some of that heat into the external air (and some back into the internal air) during off load moments/periods). You probaby do need a bigger core, given the power level you're already at is somewhat above the "rating" of the cooler. Put pressure tapping points either side of the core (which possibly you already have, if you have a boost source near the compressor outlet and tapping near the throttle for existing purposes) and report on delta P across the core.   I haven't done the mass flow calculation to see where you would be sitting on the compressor map at the ~450is rwkW level we're talking here, but if you look just at the PR you're running at, which is ~2.8-2.9, then you have a really really wide swath of the compressor map to run in, and so long as you were making between about 45-75 lb/min of flow, you should have really good comp efficiency, with the ideal being betweem 55 and 65. I can't see the need to shift drastically on the map to get better results.
    • Welcome 🙂 The ER34 wheels and slight lowering suit the R33 sedan really well. I'm firmly in the 'keep it stock, at least on the outside' camp.
