i have bought a turbosmart type2 veeport bov and installed it on my skyline.
now my car keeps stalling and ive followed the instruction and tightened the spring but it still stalls,we have checked over it and theres no leaks,no blockages and no collapsed or twisted hose.
i got the spring as tight as it could go and it still stalled so i ended up taking it off and put the factory part back on and it runs perfect and doesnt stall and now i have wasted $400 on the adapter and bov.
im confused to why it stalls,hope yous can help me out.
The car is overfuelling due to the ATMO BOV.
The car expects the re-circ BOV to be there, its tuned for it.
Hence when you put it back it works fine.
So you have two choices.
Get a ECU & tune it ($1500)
Or go back to the stock one... which is is how Nissan intended it to be :D
Nothing wrong with the stock BOV so not really sure why you would want to change it anyhow.
thanks for the info.
im having the same problem with my turbosmart BOV but i have set it up so its set to recirc and its still stalling i have no idea whats goin on with it and im looking at being in the same boat as blitz becuz im gunna have to put the stocker back on or get an aftermarket ecu and tune (better start saving lol)
installing a HKS Fuel Cut Defender should override this problem? i think.
i experienced the same with my Blitz. I didnt mind the stalling every now and then, but i removed it to avoid the boys in blue.
The stock one does its job well enough!
as previously mentioned.. maybe investigate if you can adapt that BOV back to a plumb back .
also vac leaks can be quite hard to track down .. make sure you look for cracks at the places where other pipes join the inlet ( if there are any )
to be honest I was really impressed by the stock recirc valve on the rb25det NEO .. looked very well made! and at least if you have a recirc BOV the boys in blue have got one less thing to bend you over for !
and if you have a pod you should still hear the BOV noise.
ive heard alot of specualtion, but how much boost can a standard r32 gtst bov handle?
has anyone had a problem running 17-18 psi thru one?
im ready to put my stocka back on and see if it helps with the stalling..
From what I've read on SAU, the standard 32 gtst bov can handle about 14psi before it starts to leak if I remember correctly. If you want to run the standard plumb back system, I think you can just get the GTR's bov and put it in its place. They handle up to about 20-ish psi.
Feel free to correct me.
Its wierd mine has worked fine on the car and it has never stalled. Might change it back just cos it gets annoying sometimes. Did you make sure you used the gasket between the bov and the intake pipe?
  • 8 months later...
  • 16 years later...
My tuner told me this as well that the reason the car will stall is because it has a AFM system, he said it I want to do it properly I need to delete that system, he said I can try it though to see how it goes. My BOV recirculates btw (can hear flutter sometimes though), how do s15's and stuff not stall and they also have the AFM system? I was considering blocking it off for ovbious reasons but was hesistant because of the above.
1 minute ago, GTSBoy said:
By changing to a Halaltech and not having an AFM, typically. Or, they stall or otherwise carry on.
A lot of them are driven by p platers with stock ecu's lol. When does the stalling usually happen is it high speeds?
Edited by silviaz
If you block off the BOV entirely you will get reversion out of the MAF and get a lean spike instead of a rich spike as the MAF double-counts the airflow.
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
    • Nah, that is hella wrong. If I do a simple linear between 150°C (0.407v) and 50°C (2.98v) I get the formula Temperature = -38.8651*voltage + 165.8181 It is perfectly correct at 50 and 150, but it is as much as 20° out in the region of 110°C, because the actual data is significantly non-linear there. It is no more than 4° out down at the lowest temperatures, but is is seriously shit almost everywhere. I cannot believe that the instruction is to do a 2 point linear fit. I would say the method I used previously would have to be better.
