  • Replies 213
Well another Deca!!!!
I swear i wouldnt say this last time but It got better!!!
Huge thanx to Tony for letting me drive his car all day and James for the few cheater laps i did in the evo at the end of the day even if i did stuff up my last run :)
Was ace to see Team NSW again im sure to be back in Syd again for some drinks :)
And Team Wang what more can i say... We beat them :laugh:
Some good results. Thanks Chris for putting them together.
I think I need to be more aggressive next time to get higher up the list but 2 cones and 2 half spins really puts you back. 5th RWD is ok though. Good driving Ryan and Jarrod. Get up there! Also Dave1200. Good stuff!
thankx to chris for doing the results.
woo hoo i am not the slowest 4wd there. thankx to someone who was going more for style points than actual times :)
on a serious note i am also happy to see that i have improved, seeing i am faster than that pesky echo :) hope to see you all there on the next one. and yes i should try and learn how to do handbrake turns, might have helped me on the last two mokahanas.
also would publically like to thank my navigator, whose tireless efforts ment that i went the correct way, even though i was wanting to go the wrong way all the time :-)
