  • Replies 83
Originally posted by Nexus_SiX
Grand total of :269.8RWHP
This was achieved with a pod; "bush airbox"; 3" from turbo with exhaust wrap and a Power FC
Not forgeting the BOV and 2 SAU stickers
Nice to meet ya too btw.
Originally posted by Steve-SST
We need to Dyno test these stickers.
You'll have a tough time. Theyre pretty bloody impossible to come across, hey memphis?
If you'd listened to me I could have saved you $25
Originally posted by S13_Angel
PSI GTSII: huh??
I told ya before ya put it on the dyno it'd do 230rwHP;)
I am also quite talented with a 'Crayola Caddy' and could have knocked you up a great dyno graph to:p
Not sure how much credability it would have held though:rolleyes: :D
zanda lol @ 13.1 on stock turbo. not unless your running 20psi
My old Red top T25G SR20 did 228rwHP on 13.3psi.....and ran a low/mid 13 on this setup....with a good 60ft Its 'do able';)
Nice result Matty
must be a nice streetable package now - swap you a drive when I get back from OS.
Thanks Gav - yeah it's not too bad - the tuning is the secret.
No worries with swapping the drive, hey, if ya need me to look after the R whilst you are away, just drop me a line!
:uh-huh:
Ohh calm down, I slept in and didnt have time to drop in at the office!
But i do have a heap of them ready to be dropped off at works auto
Also, I hate to see what my car would have got without my 3x SAU stickers :uhh:
nice to see u all - dont think ive seen so many skylines in one place haha. I was too wussie to put my car on - its nothing to get real excited about anyway.
But good job guys must admit there was some surprises in there as well ;)
    • Just as a thought, if it's in neutral, thats your drive line disconnect, not the clutch. Clutch slip at the dyno with pedal fully out, is actually adding a second disconnect. So it's not a clutch issue if you're in neutral. Just a bit of friction dragging the output around while in the air.
    • The HG high flow is excellent, and costs about the $$ you're talking about. But it, and probably every other highflow, uses a diffeent core than the original turo, and the original Hitatchi core is quite long. So, I think it is inevitable that there is likely no such thing as a highflow that just "bolts on" with no other effort required. And the same is likely true for HG's outright replacement "bolt on" turbos (the ATR things). And the same is likely true for anything similar from elsewhere. I have no idea if the cheap Chinese/Taiwanese complete turbos from eBay/Temu/etc are as bolt on as they claim. I mean, they claim the bolt onto the NAs as well as the turbos, and we know that can't be "bolt on". But it wouldn't matter because I'm not buying a $169 4 psi turbo for anything other than a paddock basher.
    • Bummer...yeah i "need" something to "ease" up the work and for my driving it would be enough.    Iam counting the tune "without" turbo. I do not mean "cheap" like something from Temu around 200 USD, "Cheap" is something around 1000 USD?
    • Starter motors used to use the weight of metal (magnets) to provide torque. Now they use (more) current instead. This. It's completely normal.
    • So thing that had me stumped, but I think is OK....is that when it was up in the air, in neutral I had it running to bleed to coolant while I put the wheels back on. I noticed the rears were turning (slowly) which I'd never seen before 20250928_163512.mp4     Because there had been an issue with clutch slip due to pedal adjustment on the dyno, I assumed there was still and issue so spent some quality time upside down under the dash adjusting the pedal....but no matter what I did the wheels still turned in neutral. Even disconnected the master cylinder to pedal rod and same. In despair, I even removed the clutch slave so there was no chance of any preload causing it.....still happened. So either: 1. Something is not right in the bellhousing, or 2. Its a thing sometimes with cold, thick gearbox oil Internet says it might be 2, I hope so!
