Yeah, it was a GTO. Well, it had the black rear cavallino, GTO badge and GTO wheels as well as a GTO number plate. Where did you snap your pic?
Friend on fb posted it so not sure where. But seems to be out and about quite often
Ok here we go
As Terry said, at about 1:00 it's really bizarre as there's this couple standing on the side of the road who have seen the Lambo go past and now the Ferrari, and they're pointing to my 12 year old Bimmer and saying they prefer that! Haha! :P
Edited by God_speed
Well what's a bit weird is if you watch the video again, when the 599 creeps past when still inside the valet area, the exhaust seems to 'blare' a bit, all of a sudden. Not sure if he just presses the sport button or whatever, I don't know what setup there is on the GTO (or Aventador) but it's possible there's a bimodal exhaust setup like the current Maseratis. So in normal running mode it'd be just under 90dB up to the test RPM, above that the valve would open. In sport mode the valve would always be open regardless of RPM?
I found this with an Aston Martin Vantage V12, but the opposite. Sit in neutral and give it a rev and you get creamy V12 goodness up until you get to 3000rpm, when something shuts off in the exhaust and it goes all quiet! I was like giving me a taste of the goodness, then not letting me have any more! Damm NVH engineers!
Ok here we go
I have to laugh at the 'innocent' bystander in this whole dramatic clip of...
* the Aventador
* the 599GTO
* the people on the footpath complimenting your bimmer; and that's...
the Disability Sticker hehe...
Nice sounds tho' in between city buildings :)
The SG9 '06-'08 model was riddled with the 1410 & 2432 fault codes Marko, where the air pump could deliver moist air into cylinder #1 > corrosion.
Fortunately mine was blanked off in time.
I think you should be happy with yours, for sure.
The SG9 has slightly better power/weight but Pulse Racing has a couple of tweaks that can help yours get along that much better.
The torque curve is steep on takeoff, but it runs out of puff pretty soon after.
Overall, the Foz XT is a very respectable 'sleeper' that shocks most V8s
Very happy with its reliability too with over 174xxxKms on my '06 model.
Are your rear seats a tad uncomfortable for long trips? If I see yours, I'd like to check out if I should update anytime soon.
I keep having 'arguments' with Nick about the XT being better than his Stag - haha
I've heard about this air pump and I think the series 3 has this as well? Does it run for about 30 seconds on cold start up and its purpose is to recycle the pollution back into the engine?
Yeah I've heard good things about pulse racing actually...bottom end and mid range is great and yes top end is not as strong due to the smallish turbo.
The rear seat is comfortable in fact...we should catch up as I'd like to see your n1 as well :) what part of Sydney do u live in? I'm inner west.
P.S. what is a stag? Not that old triumph thing haha
definitely is over 90DB - how do these exotic cars get away with this level of noise pollution?
harleys fall in the same category when it comes to noise...hmmm
First of all it isn't noise polution, it is noise orgasm.
2nd is stock standard factory ADR approved exhaust with valves.
3rd is there isn't a whole heap of them around where as in normal cars you can put a loud exhaust on any engine and it wil be annoying and every p plater will be doing happy laps around the streets for hours.
4th is it's a f**king V12, nuff said.
R35's are louder than 90db as well under full throttle, not just an exotic thing.
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
