Morwell Sprints - Sat 22 Sept - Club C/ships - Rnd 7
  • Replies 50
Posted Images
Entry forms and Supp Regs are now avaialble.
Cheers
BEC
Entry Form
Supp Regs
Talk it up.......
Is this the new track that was supposed to be built or the old hill climb track?
Anyone got a plan of the layout if it is the new track?
I actually might have ny gearbox done by then...FINALLY...then I can hack around behind all the ultra quick GTR's.
LOL - thanks West - fixed.
Its Friday and all I can think about is leaving work and finding a nice cold beer.
And Nick - its being held at the old Morwell Hill Climb Circuit - the new track has not been finished yet.
so is it hill climb or a sprint? as the sup regs say its a hill climb. seeing its not on their forums yet, does anyone know approx how many runs will each person get.
will there be any driver training or actually is there any point of driver training?
Unless you have read something i havnt seen, you dont need special tow hooks, the ones on your car are fine.
Last point after Vehicle equipmen and safety. page 3.
and point e)? What sort of clear adhesive do you guys use on the headlights.
I'm thining of entering the Gemini, since the GTR is going to be off the road for a bit.
My advice is do not do this day unless you are completly comfortable in your car. Don't do this event if you havn't done a few track days before.
There is not much room for error.
FYI, we'll be running a new course on the old track.
Starting on the National Circuit heading up hill towards the bridge, you'll turn right and go anticlockwise around the keyhole before heading up the straight around the bend and down the 'S' to the finish.
8 people so far! LOL
I'm out. I really wanted to do Morwell before if shut down but I've still got this pesky ear infection and I'm not about to try and drive fast anywhere whilst my balance is all out of whack.
Jeez, not very popular this year! I liked Morwell, though it did cost me a clutch, a gearbox and a hell of a drive back to the workshop! :P
I liked it too except I wasn't driving and we had to get up at 5am and It was a HELL of a drive back to the workshop, I think you banned me from speaking for most of the trip back!! And we saw that yellow TMU car which was scary And we had no ciggarettes and couldn't stop because the car wouldn't make it back if we did!
Fun drive.... hehe :)
    • Great work! Thanks for documenting the process.
    • How would you even adjust the clutch if the pedal already has the correct free play? The operating cylinder has no adjustment in mounting position or rod length. On pull style clutches there is also no ability to adjust the bearing carrier. Push type I can see how adjusting the carrier height makes it all work.   If this is the twin plate clutch did you verify that your friction disks were oriented correctly? It's not mentioned in the directions at all you just have to notice that one side the friction disks have a part number on the hub fingers and a subtle coning to those fingers. Another thing that I noticed was if you put the friction disks in backwards the pressure plate fingers will not be even and flat when the clutch is installed.
    • yeah, mechanically, it is probably do-able, off the top of my head, there would be the transfer case, which I believe will bolt up to the rear of the RWD transmission, the shorter rear tail shaft. A front drive shaft, front diff, engine upper sump, front drive shafts, front hubs and front AWD struts (they are shaped around the front drive shafts), LCAs (at the very least from the front suspension) oil cooler.  You might want the rear diff from an AWD too, so you can be certain the front and rear diff rations are identical.  Who knows what brackets and mounts you might need.  So a whole doner car might be the best option if you need to maintain RHD. Then actually making it work, that would be a whole different story.
    • Take the fall as a warning sign for future endeavours  Stay safe mate
