howie are you watching the thread while thinking about buying a V35.... thats why i am always lurking
Frank.. TOP effort.
haha.. maybe subconciously i'm being steered towards a V35 :closedeyes: Would love a 350 though.
Thanks.
Have a look a t the newest issue of HOT4's, you will get dep understanding of V35, from WA's C-WEST 350GT
Yes my car is a good example :kiss:
But Correction, its C-Red - not C-West haha :D
JK
Hey Frank,
Would you consider doing another car? Mine is the 05, non BOSE but should be similar. I'm in Syd as well.
PM me if you like on how long it will take and your price.
I can take everything apart and help you as well, but am pretty hopeless with the rest of it.
Cheers
Bobby
Hi Bobby:
I am free this weekend. if you need me to help you with the A/V, please send me a PM, we can make a time.
Cheer
Frank
hi
any suggestions for those of us that already have a reversing camera (and my wife will kill me if i disable it cos she uses it everytime:) )
ok - have done one with a camera. fairly straight forward . camera still functions and DVD (source) works when not in reverse. cannot remember if audio switches out with camera on.
someone remap the FKN virtual buttons on these things! both of us had problems finding the AUX in on the screen.
pics:
DVD unit screen.
DVD playing- DVD is encoded in PAL. hence colour issue.
closeup of AUX in plugs
distant shot of aux in plugs
OE reverse camera
TV box - clarion box in corner is the camera switch box - for those without cameras I believe I can still make this work so you gain a reverse camera.
car in reverse looking up our horrible driveway..
there ya go- it does work.
(ta WAZ!)
man that's one sexy car!
it works great - when the aux input is playing, and you throw it in reverse, the audio doesn't cut but the video does. works well.
but i just realised that i don't have the ability to watch it whilst in drive, only when i'm at a stop.
does anyone have one of those boxes that cuts out the factory sensor for the brake so you can watch the screen while driving?
cheers chris. ive had a read of g35driver.com and it might be as simple as unplugging and grounding one wire that goes to the foot-brake, but i'm not 100% sure. i will also have a look this afternoon.. but i don't want to screw up some other electrics by removing a wire..
if its only the park brake then its no biggie, but if it also monitors the speed sensor then it might be an issue cutting that..
Edited by WazR32GTSt
  • 4 weeks later...
Thanks Frank for this, but do you have the photo that go along with the original post, they are not coming up....
For your reference I have found someone elses photos of a DVD System mod here:
http://photofile.ru/users/yura7264/
Using a "Mystery" DVD player...
Photos are working again now.... slowly but they do show up....
How is the video in Activated?
Edited by GTS4nMore
video will show up under VTR. select TV then VTR input. from there it will work if you have done every thing correctly.
it will not work witht eh IGN on UNLESS the handbrake is on and the car is stopped. driving the car shuts the video off at 5kmh.
I finally rigged mine up today and my video only stays on the screen for maybe 5 seconds and then it dissappears and some jap writing comes up. This was with the IGN on or car running, in park and handbrake on. As soon as I took the hb off the video dropped and audio continued, but the damn video kept dissappearing after a short timeout. Is this a user setting somehow? I noticed an option button in the VTR screen but it didnt make a difference. I have attached some pics of what Ive done.
PS for my cabling i used the wires from a 4 pin floppy drive power connector and some insulation tape - perfect :P Finding a suitable plug was too hard.
Image 1 - Video playing
Image 2 - Warning Message
Image 3 - VTR toggle option? What does this do?
Image 4 - Another warning
Image 5 - My wiring Job
Cheers
JK
Hi Jaik, its the display option. Press the 1st button on the 2nd row to go into the Display menu. Scroll down to the second option (should be 3 options available) then press enter to disable it.
Cheers
Cheers
JK
  • 3 weeks later...
I have set up my Stagea ARX with this RCA input and I have found that I can play the movies whilst driving. On my car it seems related to the setting of the GPS.
By playing with the GPS menu (right hand top button) I have found that I can have the GPS active or static. What I mean is that when the GPS is active it tracks me across the japanese map (although this is obviously wrong). I have found that I can make the GPS static, it does not track me accross the map but does show the direction I am heading. When it is in this mode the movies will play all the time.
When the GPS is active, the movies will only play with the hand brake on.
Very strange but great result.
Andy
    • The incentives are mostly the same, yes. Ethanol is cheap compared to the cost of doing 98-100 RON with crude oil alone. 87 to 93-94 AKI all with E10. In 2020 Canada mandated E10 as a part of their "renewable fuel standard" and is supposedly going to go to E15 in 2030. In California where there are only 8 refineries with two threatening to shut down next year it's been over 20 years now of E10 and 91 AKI maximum because there's just not enough refinery capacity or crude oil supply relative to the demand for premium unleaded fuel. And CARB's low carbon fuel standard means functionally none of the diesel available at the pump is made from crude oil anymore. It's almost all entirely 20% biodiesel blended with 80% renewable diesel (hydrotreated vegetable oil) now. The number of gasoline vehicles that support E15 or higher ethanol concentrations is surprisingly low, I can't imagine it being wise to play tricks like this without flex fuel sensors in most of the fleet.
    • It's almost certainly the same as the one next to it. Have a fish around amongst these hits https://www.google.com/search?q=surface+mount+transistor+m33&sca_esv=9cb49794e0b2005d&source=hp&ei=2vJ5aNjTB7Kw0PEPldnS8QM&iflsig=AOw8s4IAAAAAaHoA6qkfmF6XcygtrZ4Vu9f92NXF_RFd&ved=0ahUKEwjYqIPP7MWOAxUyGDQIHZWsND4Q4dUDCA8&uact=5&oq=surface+mount+transistor+m33&gs_lp=Egdnd3Mtd2l6IhxzdXJmYWNlIG1vdW50IHRyYW5zaXN0b3IgbTMzMgUQIRigATIFECEYoAEyBRAhGKABMgUQIRigAUjKCFAAWABwAHgAkAEAmAHfAaAB3wGqAQMyLTG4AQPIAQD4AQL4AQGYAgGgAuYBmAMAkgcDMi0xoAfMBLIHAzItMbgH5gHCBwMyLTHIBwU&sclient=gws-wiz
    • South Australia, which is hardly as far behind as the rest pf Oz makes out, and who is also not a paragon of progressiveness (read that as over-legislation) in the area of vehicle standards, has this to say on the subject: Adjustable coil-over suspension Aftermarket adjustable coil-over suspension components are suspension units that incorporate an external thread on the main body and corresponding threaded spring saddle that allows the vehicle's suspension height to be varied. If fitting aftermarket or coil-over suspension components you must submit an Application to modify a light motor vehicle form and a report from a light vehicle engineering signatory (LVES).
    • Hi all, Long time since I've posted here. Looking for some advice on what I can remove to further identify the cause of my issues.  I can move the passenger seat forward and back but the knob used to adjust the seat angle is pretty much free spinning, there's very little resistance.  Removing the side cover I can see that the chain is intact but the shaft for the adjustment spins without the gear attached to it moving.  What's my next step for disassembly here? Is this a common fault? Just being a little cautious as I didn't want to start removing bolts for a spring to fly out or something equally as stupid.  Cheers
    • Those above shitboxes, mediocre and above usually have a turbo strapped to them, hence the slightly higher octane is required.
