QUOTE (STAG250 @ 29 Oct 2008, 07:41 PM) *
A heads up re high stop light. I failed WOF today because of it and learned from Nissan that there is only a full top panel replacement above the tailgate window. Cost to you sir? $425 NZD. $300 2nd hand. f**k that s@#t. Managed to pass after some messing around and busting into the sealed unit but a precautionary tale should you be in a likewise unhappy situation.
:) to whoever thought up that nonsense in Japan
just got back from having the resistors and diode replaced on circuit board and all is sweet again
total cost $40:40 parts/labour
Should any of you need to do same the resistors are rated at 2.62v but I replaced with 2.7's and this is ok. I also was recommended to replace the diode and this the Auto Electrican supplied.
Btw it's a delicate operation removing inside panel to get access to nuts and bolts holding the led light assembly on. Be careful not to break it.
Ford-land? You sir have just crossed the line! ;)
Actually find that the gears being the other way around (down = accelerate, up = decelerate) comes more naturally as you are pushing the lever in the same direction of G force.
ie, When accelerating, G forces push you backwards into your seat, thus instead of fighting and pushing the lever forward against these forces, I would prefer to pull it back. I do believe that this is the general setup for non-paddle semi-automatics in the racing world (WRC, v8 Supercars etc).
It just feels natural to me, as opposed to having to think about changing with the current directional setup. That is why a rarely use my tiptronic.
Sorry mate, wasn't intending to label anyone. I happened to also notice on the weekend that the V8 supercars (the sequential shift ones) have it the way you describe as well - and thats when I realised the whole G-forces thing.
You see I rarely use the tiptronic just because I dont find the gear shifts quick enough to make it worthwhile.
But now that the above has been explained I stand corrected and agree with the logic. Cheers :D
thnx for that
mine are warped and was told that fronts cost $300 and rears $150 but will check tomorrow the prices for those4 you mention
Hey I was told mine were warped and I had the discs machined during compliance.
It still makes a funny grinding noise very briefly when I take off from a standstill sometimes - and there is noticeable vibration at the rear when travelling at over 80km/h...
would this be the same issue? My other feeling is that maybe I just need a good wheel alignment on it.
I guess they warp because the car is under braked yes?
Brake rotors are prone to warping on all automatic cars because when a car is brought down to a stop, such as at a set of traffic lights, the brake is used to hold the car in place. Because there is already heat in the brakes from slowing the car, and the fact that all that heat is concentrated in one spot on the rotors while the car is at a stand-still, the rotors are softer in that area and more likely to be pushed out of shape.
then youd get that on ALL cars. using the gears to slow down in a manual doesnt take all that much from the brakes. and youre still on the brakes when youre at a standstill :P
the key is to let you brakes warm up before you go stomping on them from 80km/h
Depends how hard the owner/driver is on the brakes. True, using the gears in a manual isn't a total solution, but it does help. If I've been hard on the brakes I use the handbrake when I come to a complete stop. I had a (manual) Corolla for over a decade and never had to replace front rotors.
fact is this is the first car I've had this problem with and then I 'm told they're under braked anyway
Yeah, underbraking would be a factor. My cousin owns a Prado. I'm not sure how hard she is on the brakes, but it suffers from pretty bad brake shudder.
:( to whoever thought up that nonsense in Japan
Hey Stag250
Im interested in your repair of the high stop light.
Once you removed the actual light panel from the car, did you access the LEDs by cutting through the bottom of the black plastic strip? Or, were you able to remove the red lense from the black strip, and then access the LEDs?
Strange that this has failed on two cars.
Thanks
Murray
Hey Stag250
Thanks
Murray
Yeah it was through the black strip. My friend has an old surgical saw so I was able to cut a rectangle out of it and access the LED's. We pulled the cable through and pulled the LED assembly out to get access to the resistors. Re-assembled and sealed it up.
Hi guys, first post here,
I had a look at an M35 Stagea today and took it for a very brief spin up the road and back. Didn't seem very quick but the boot is huge which is just what we need. I loved the car, this one had leather and dual sunroof although they also had a silver one offsite without leather or sunroof. I think i'd prefer the silver to the blue.
Had the TV screen in Japanese. Has anyone managed to find a DVD with local maps yet?
Also didn't have the three gauges but had an in dash 6 stacker instead. What are the gauges? I'm guessing Boost, Oil Temp and Volts? Can someone confirm this as the dealer said he can put the three gauges back in I prefer them.
I wouldn't be buying this to modify really, its going to be the family wagon. The only things i'd do is change the tiptronic switching around, and hopefully get the TV/NAV function working properly (if thats possible).
Cheers,
Jono
if its an RX or ARX model then its a bit of mucking around to get the gauges back in. if its an RS, then youll have no problems probably.
there is no disc for satnav, nor will there probably ever be.
the tv can be made to work easily with an external tuner, do a search on here for more info. its been covered many times before!
actually the NAV can be fixed. pressing the map button will bring the new system in. I do these for a living.
where are you?
theres not a lot thats NOT possible with these. I'm working on a cruise setup for these cars as well. it will take the place of the blank silver tabs on the wheel.
gauges are volt,boost and oil temp (unsure on the last one - I see more of the integrated dash cars.)
as for pulling the 6cd out and popping guages back in - yep VERY doable. the harness is there regardless of the dash fitted.
Cheers for the reply, I'm in Sydney. I think i would prefer the gauges than the 6 stacker, i could always upgrade the single DIN unit for something better anyway. I didn't check this particular car for the Bose sub in the wheel well, one of their other models had the sub and the integrated 6 stacker.
So whats the go with the NAV? What is the new 'system' to be brought in? Upgrade DVD?
Cheers,
Jono
navi gets a garmin unit put in. OE screen is retained and the OE DVD rom is retained.
DVD into the system can be done easily as well ( they do not play DVD video as standard.)
    • For these last 7 years of ownership, I've always had to use a small scissor jack under one of the front tow hooks to raise the front just enough so my low-profile jack fits under to reach my subframe jack point. I'm beginning to get annoyed of always having to do this. Are there any lower low-profile jacks that fit under the gtr lip on a dropped car?
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
