i guess everybody else new about the cd player issues..........mine is f#@ked and i never got the chance to use it. didnt think to check it when i bought the car.
what are the options?
repair or Ipod. ipod is cheaper.
Just replace the stereo/head unit = easiest option.
My cd player worked at first but eventually it ate my cd and wouldn't play it and wouldn't spit it out either.
I got an aftermarket head unit installed, and then I had to take the stock unit apart to retrieve my cd.
Any audio installer can do the install - its an easy job (according to autobarn who fitted mine - didn't have any trouble).
I did give them a printed copy of the instructions for a V35 ipod/stereo install (very similar to M35 dash) but not sure if they used it.
$80 & 45 mins for the install. very happy :)
You'll get better radio reception and better sound in general from an aftermarket head unit.
And they all have aux input nowadays, but some also have ipod compatibility so either way you can have the cd player AND the ipod, now thats having cake and eating it too.
Not an option for us AR-X and also the RX owners... In-dash 6 disc changer.... Needs some serious aftermarket panels to get that audio out and replace with a DIN/ISO standard unit that fits the RS....
Just get an iPod and a PA11-NIS.
Easy to install and works beautifully :)
ah thats right...sorry my bad.
one of the reasons I bought my rsfour 250t was that I could put my own stereo in
Hi all,
Just bought an M35 (250t RS Four V) from my girlfriend's brother (I'm Aussie, he's Japanese, I'm in Japan for the next 2 weeks).
Been enquiring about importing it into Aus through RAWS. Under RAWS guidelines it is legal for a registered dealer to import certain M35s with a production date from October 2001. Girlfriend's brother says this one was built in October 2000... and i'm looking at paperwork that says the same thing. RAWS importer I was talking to never heard of an M35 built before 2001. I've googled production dates, and 5 different sites say production of the M35 was from 2001 to 2007.
Are the paperwork and brother mistaken and it's actually a 2001?
Anyone ever heard of a M35 built in 2000?
Will be great if it turns out to be a 2001 because I can't import (or get compliance) if it is 2000.
Thanks for any help.
Langers
Hi all,
Langers
Something not right there. M35's were definitely not built before mid 2001. Other evidence of this is that a lot of the new bits in the M35 didn't show up in most Nissans until 2002 or late 2001 (VQ Engine, 5speed auto, Front Midship Platform, different styling, new dash layout etc). Also the series 2 stagea was still being built up intil sometime mid 2001 so it seems very unlikely they would have had 2 different models in production at the same time.
Does anyone have a part # for the plastic guard that protects the front axle and the hardware affixed to it?
Its the one after the big one that protects the bottom of the motor etc.
I had a major bottom out in Windsor not long after I got the car and the plastic protector is in pretty bad shape, thinking about getting it replaced when it get's serviced.
Hi all,
Langers
NM35 and HM35's began rolling off the production line in mid 2001.
If you give us the VIN, we can look it up in FAST for you to find the build date.
Yeah, mine went on the way back home after picking it up from the storage warehouse.
That was 2 years ago and I haven't yet replaced it.
Having said that, the part number you are after is 75881-AQ060
Edited by iamhe77
I recently replaced my 6 stack in dash cd player from my 25ot rs four with a dvd/sat nav eclipse unit from frankies auto electrics. Speak to Chris Rogers about the double din fascia and new a/c control buttons. Fits and looks sweet.
Hi all,
Langers
Another possible way to check build dates, that i have used on import motorbikes, hopefully same for cars is to check brake and fuel lines etc. By Law in japan they have to put month/year on brake and fuel lines as they have to be replaced every three of five years or whatever, thats why we get them cheap because of the prohibitive cost of doing all that work. Worth a look. Was quite commen on bike to find year xx bike had actually been built 6-9 months earlier etc....
    • I get that taking off the head is best but that's a bit much for "just" valve seals. I was just under the impression that one would be able to rotate to TDC and be able to temporarily drop the valve without losing it and effectively having to remove the head to then recover it. I never knew people actually pushed rope into the cylinder to do valve seals hahaha So just to confirm, just going to TDC will not work? In that case I know when I do valve seals I'll maybe just remove the head and do some other things while I'm there, or just wait until I do an engine build.
    • The old approach was to fill the cylinder/chamber with a length of rope pushed in through the sparkplug hole. The new approach is to connect compressed air to the sparkplug hole and fill it with enough pressure to push the valves up. Doing either of these things with the head on and the engine in the car is a lot less pleasant than doing it properly.
    • Can't you put the pistons to TDC and then do the valve seals? Or will the drop down too far to pull them back up?
    • One thing I can tell you is, do it properly the first time. If you encounter unexpected problems just let the car sit for a week or two if you have to get some other parts or figure stuff out.  I'd have said go and use as many OEM parts as possible but since you want to change the turbo later on a custom kit is probably the better choice. Since I have no experience with RB25 just compare parts diagrams and images before buying a line kit and it should be easy to see if it has everything you need. Amayama has very good parts diagrams and part number lists, that is what I used a bunch to figure out what I might need. And don't forget to plan ahead and possibly renew other stuff that's easy to get to while you're in there doing the turbo lines. Happy wrenching
    • Update 4:   Hi all, good news. Engine is running and all the gaskets and seals seem to be working as intended. No leaks so far, even the JB Weld seems to hold. I flushed out the old coolant a few times and put in fresh coolant, not Nissan stuff, I decided to try the Ravenol Protect FL22, they claim it works for a wide variety of JDM cars and the opinions on it by some people were pretty good. And it has the nice poison green color! And man am I glad I bought a coolant system tester earlier this year, vacuum filling works wonders on this engine. I can definitely recommend this to anyone still doing it the old school way. All you need is compressed air supply. Will have to do a small test drive as soon as I can, I removed the gauge cluster again as the tacho needle was still bouncing around a bit but it was much better than before already.  I also found some cracks on all 4 tires inner and outer sidewalls. Apparently these tires should 't be parked on for extended periods or be kept under 0 degrees during storage, which I did not know. Clearly the previous owner didn't look into those details either, he probably bought them just cause they are cool semi-slicks. I'm just wondering how tf I am supposed to reach 30-80 degree tire temperatures on the public road consistenly, these tires were never going to work for my use case. I'll probably order Continental SportContact7 ones as these are the best allround summer tire available right now and I don't think I'll need anything crazier for now. Do let me know if you have experience with various tires and which ones you recommend.
