  • Replies 812
hey stu guess whooooo??????................ you need to bring this thing to wake feild next week end!!!!,(i need a good mechanic for miracle fixes when i hurt my little sil, sorry i didnt make the "wet the head" ive sliped a disc, plus im resting my back for my first ever TRACK DAY!!!!!
thanks for the well wishes guys, Mum & bub are at home and doing well.
Hey Tristan, bit early for me to leave the wife alone i think, i wont push my luck yet.
have to buy a drum of fuel and give it a check over as i havent had a look under it since i went off a couple of times.
want to repair the front bar too.
i think we have another one in a couple of months, and i might take it down to wakefield before then.
hope your well for OP, youll have a great time. Caution through turn 1 lol.
NOTE:
You may have noticed this thread has been moved.
SAU Admin have decided to run a new section for "Projects, Overhauls and Build-ups"
As such your thread is a prime example of what we wanted to house in this section.
We have left links in the sections you originally posted also to allow easy access to the threads new home.
Any issues, please feel free to pm myself or N1GTR.
Cheers Col
sorry as there has been no updates as i havent touched the car sinse OP, have been preparing spare bedroom for my daughter as to prepare her current room for my new arrival who decided to join us at 11.55am on sunday morning. Gorgeous little girl weighing 3kgs and 50cm tall. Mum and new daughter doing well, still havent named her.
ill give it a couple of weeks for them to settle in at home and then ill be back into it.
Thanks for all your suggestions and input also, just have been offline for a while and unable to reply till now.
Congratulation with a Baby girl! :P
Sorry for beeing so late with the gratulation, but I stopped recieving E-Mail when this thread is updated...
How is she? Found a name for her?
Best Wishes
Morten and Caroline
thanks guys, her name is Ella Jade. She is doing well, put on 440grams last week.
Going to have a play with the car this weekend, firstly going to test the valve springs as the mechanical missfire at high RPM can only be them, and have heard some rumours about Comp valve-springs having this problem. Get my missing 20 killer wasps back.
Going to remove and repair front bar, swing a spanner over car and fabricate an engine cover/intake duct to insulate the intake from the headers and direct some air from the front bar. Also going to check for any damage due to my off track excursions lol. Hope to have it ready in a week so i can go to next event that pops up.
Congratulation with a Baby girl! :merli:
Best Wishes
Morten and Caroline
have narrowed missfire/harmonic down to the Yella Terra rocker arms after springs tested fine. Have re-installed standard arms as to run it on dyno on saturday and see if problem is gone, a little birdy told me that Yella Terra has re-designed this part number, nice of them to tell us.
Bar is off and getting repaired, and will do engine cover soon, lots of track days coming up.....going to put a passenger seat in also as to get some driver tips this time, might need headsets though lol.
Sucks that its the rockers.
Harland-Sharp Rollers FTW :)
Too bad that the rocker arms are failing, but it is good to know that they are easy to replace... What brand of rocker arms are you choosing if it is the rocker arms that are the problem?
I hade a test run with my car on the road this saturday, and the CAM I am using is just mean!!! :P
Without proper tuning (Running between 11.0 and 11.5 AFR) I managed to get it to spin at aprox. 4000 rpm in 4th gear... Started rolling at 2000rpm in 4th gear and floored the throtle, and I am running 235/40-18 Road Slicks...
Hoping that the Rocker arm change works for you!
its OK, if our tests confirm that the ams are the issue then Yellaa Terra will be replacing them or reimbursing me, i can guarantee you that. Hey Morten, how good are 4th gear skids lol.
I hade a test run with my car on the road this saturday, and the CAM I am using is just mean!!! :D
our diagnosis was confirmed today, the car was perfect. clean power curve through too 7000rpm and beyond.
put some fuel back in here and there but overall tune was good. Running it a bit fatter for security but still making 400hp and 1600 lb of torque. So will be chasing rocker arms up this week.
Fitted GTR Grille purchased off forum which looks great. Bar is in for repair.
All is looking good for October track day.
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
    • Thank you so much for the help
