Hey guys,
I have another switch question. I picked up my S2 Manual Stagea and have seen a switch on the dash which is to the right of the steering wheel.
It has a pic of the windscreen and wiper and also looks like it has a wavey water level at the bottom of it. If I press it the only this it does light up an orange light on the switch itself.
Sorry if its hard to explain and my camera is buggered at the moment. The switch also is not an on / off switch. if you press it down it will flick back up and the light will come on and if you press it again it flicks back up and the light turns off but it doesnt seem to do anything.
Im assuming it has something to do with the windscreen of washer bottle but I have no idea what it would do!
Cheers
Dave
p.s. I am loving the stagea!!! I had no idea they were so nice to drive!
https://www.sau.com.au/forums/topic/191695-dash-switch/
hahaha well i dont think ill be using that any time soon, cheers.. I guess I can't really test them then? how does it work?
Put your wipers in the freezer for an hour, pop them back on, time it with/without switch on to see how long before the defrost. :laughing-smiley-014:
https://www.sau.com.au/forums/topic/191695-dash-switch/#findComment-3448454
The "Wiper de-icer system" usually came with a cold weather spec pack which also included heated wing mirrors, rear fog lamp, bigger battery, better heater, bigger starter, & if you coupled that with the "S Pack" you would get a rear viscous Limited slip diff (LSD)
https://www.sau.com.au/forums/topic/191695-dash-switch/#findComment-3452124
and the remote start option maybe? or is that something else again?
'Fraid not, the remote starter was a seperate option...
Type A starts or stops the engine
Type B starts & stops, alarm function, locks & unlocks the doors.
Type C starts & stops, alarm function, auto rear demister if ambient temp is less than 5 deg, and answer back function
Type D starts & stops, alarm function, lock & unlock, auto rear demist, & answer back which basically sends a signal to the car (at up to 300m away) the lights on the car flash, then the little LCD screen displays the car temp, if it's locked, if the alarm is armed, and if the engine is running or stopped among other things...
All of these were only available on the auto
https://www.sau.com.au/forums/topic/191695-dash-switch/#findComment-3453336
Holy crap. That's just the remote start options???!! I'd choose... type D :(
https://www.sau.com.au/forums/topic/191695-dash-switch/#findComment-3453531
Nice, my stagea just keeps getting better... It is the 'S' and has the rear fog you mentioned as well.. I love it, I can't believe it took me so long to decide to get one!
rear fog? whers that ands more importantly where is the switch?
https://www.sau.com.au/forums/topic/191695-dash-switch/#findComment-3461215
  • 1 year later...
rear fog light is for they really foggy days, say if you can just see the car up ahead that is only 20meters or so infront, well then i guess the car behind you can just see you too.
fog light is really bright, and being red they will know that there is a car infront and thats your car they can now see.
little switch is for the wiper arm, if you have snow on your wiper arms, thick snow, that basically heats up, melts the snow around the arm to allow it to move much easier. :D
https://www.sau.com.au/forums/topic/191695-dash-switch/#findComment-4451083
Hey there
The switch that you are talking sounds like it could be to heat up your wipers, you can tell by having a close look at your windscreen, if it does have the heating elements in the glass they are orange in colour and usually have three long strips where your wipers sit in the off mode. If the heating elements are in the black part of the glass (ceramic) it will be very hard to see but you should see them.
If you do happen to have the heated windscreen make sure you have glass cover on you insurance, if you think the price of a normal windscreen for a stagea is expensive wait till you find out how much a heated one is!!!!
Edited by Punk72
https://www.sau.com.au/forums/topic/191695-dash-switch/#findComment-4451095
the switch heats up your front windscreen... if you look at your windscreen you can see a few lines of that demister strip around the outside... turn it on for about 5 minutes and touch the windscreen near the strip, nice and hot... i didnt know it heated up the mirrors... will come in handy in winter when im down at the snowys...
p.s. i was lucky enough to have remote start type b... theres a few tricks to using it tho which is good... push the start stop button twice the car starts... push it once it stops... push the other button twice alarm arms and locks doors, once will disarm and unlock... only thing that shits me is once the car is running it will turn off when you open the doors... i am thinking of a timer circuit that holds the door switches on for like five minutes so you can get in the car put the keys in the ingnition... as soon as the keys are in the ignition its orite... if you have the window down and put the keys in the ignition its sweet as so it wont be too hard to come up with a circuit...
neway ive got a stagea to wash
https://www.sau.com.au/forums/topic/191695-dash-switch/#findComment-4451745
    • Thanks for the reply mate. Well I really hope its a hose then not engine out job
    • But.... the reason I want to run a 60 weight is so at 125C it has the same viscosity as a 40 weight at 100C. That's the whole reason. If the viscosity changes that much to drop oil pressure from 73psi to 36psi then that's another reason I should be running an oil that mimics the 40 weight at 100C. I have datalogs from the dyno with the oil pressure hitting 73psi at full throttle/high RPM. At the dyno the oil temp was around 100-105C. The pump has a 70psi internal relief spring. It will never go/can't go above 70psi. The GM recommendation of 6psi per 1000rpm is well under that... The oil sensor for logging in LS's is at the valley plate at the back of  the block/rear of where the heads are near the firewall. It's also where the knock sensors are which are notable for 'false knock'. I'm hoping I just didn't have enough oil up top causing some chatter instead of rods being sad (big hopium/copium I know) LS's definitely heat up the oil more than RB's do, the stock vettes for example will hit 300F(150C) in a lap or two and happily track for years and years. This is the same oil cooler that I had when I was in RB land, being the Setrab 25 row oil cooler HEL thing. I did think about putting a fan in there to pull air out more, though I don't know if that will actually help in huge load situations with lots of speed. I think when I had the auto cooler. The leak is where the block runs to the oil cooler lines, the OEM/Dash oil pressure sender is connected at that junction and is what broke. I'm actually quite curious to see how much oil in total capacity is actually left in the engine. As it currently stands I'm waiting on that bush to adapt the sender to it. The sump is still full (?) of oil and the lines and accusump have been drained, but the filter and block are off. I suspect there's maybe less than 1/2 the total capacity there should be in there. I have noticed in the past that topping up oil has improved oil pressure, as reported by the dash sensor. This is all extremely sketchy hence wanting to get it sorted out lol.
    • I neglected to respond to this previously. Get it up to 100 psi, and then you'll be OK.
    • I agree with everything else, except (and I'm rethinking this as it wasn't setup how my brain first though) if the sensor is at the end of a hose which is how it has been recommended to isolate it from vibrations, then if that line had a small hole in, I could foresee potentially (not a fluid dynamic specialist) the ability for it to see a lower pressure at the sensor. But thinking through, said sensor was in the actual block, HOWEVER it was also the sensor itself that broke, so oil pressure may not have been fully reaching the sensor still. So I'm still in my same theory.   However, I 100% would be saying COOL THE OIL DOWN if it's at 125c. That would be an epic concern of mine.   Im now thinking as you did Brad that the knock detection is likely due to the bearings giving a bit more noise as pressure dropped away. Kinkstah, drop your oil, and get a sample of it (as you're draining it) and send it off for analysis.
    • I myself AM TOTALLY UNPREPARED TO BELIEVE that the load is higher on the track than on the dyno. If it is not happening on the dyno, I cannot see it happening on the track. The difference you are seeing is because it is hot on the track, and I am pretty sure your tuner is not belting the crap out of it on teh dyno when it starts to get hot. The only way that being hot on the track can lead to real ping, that I can think of, is if you are getting more oil (from mist in the inlet tract, or going up past the oil control rings) reducing the effective octane rating of the fuel and causing ping that way. Yeah, nah. Look at this graph which I will helpfully show you zoomed back in. As an engineer, I look at the difference in viscocity at (in your case, 125°C) and say "they're all the same number". Even though those lines are not completely collapsed down onto each other, the oil grades you are talking about (40, 50 and 60) are teh top three lines (150, 220 and 320) and as far as I am concerned, there is not enough difference between them at that temperature to be meaningful. The viscosity of 60 at 125°C is teh same as 40 at 100°C. You should not operate it under high load at high temperature. That is purely because the only way they can achieve their emissions numbers is with thin-arse oil in it, so they have to tell you to put thin oil in it for the street. They know that no-one can drive the car & engine hard enough on the street to reach the operating regime that demands the actual correct oil that the engine needs on the track. And so they tell you to put that oil in for the track. Find a way to get more air into it, or, more likely, out of it. Or add a water spray for when it's hot. Or something.   As to the leak --- a small leak that cannot cause near catastrophic volume loss in a few seconds cannot cause a low pressure condition in the engine. If the leak is large enough to drop oil pressure, then you will only get one or two shots at it before the sump is drained.
