very picky. He'll have more hard times if he add sunroof, manual, brembo on to his must have list. larger spoke std 18" wheels are not uncommon. but if he wants 19" he will have to go with late 2005-06 model but he'll miss out the 04 anniversary full leather opportunity.
Hi Guys,
Any idea if this translation will be compatible with an 06' model v35?
Or if there are any other options in any case?
Thanks
We don't believe it will be. At this stage we believe it will only work up to late 2003 or early 2004 models.
Cheers
Andy
Hi, I'm Matt from Auckland NZ I'm new to these forums.
I'm hoping to get a V35 Skyline myself at sometime this year, I'm also looking forward to this English conversion for the system (I just read the whole 13 pages of this thread haha, although actually very interesting).
Awesome!!! ^_^
any update on the english conversion
unfortunately no news is bad news in this case.
I do not expect to see anything for at least 3 weeks.
I was told to expect close to completion then but I do not like keeping you all waiting, so at the moment I am sorry I don't want to commit to any date till I have more information.
The good news is that the language part is converted. It is just creating a secure system so the developer will not be pirated.
Cheers
Andy
Hey, I'm really glad to hear that the software part is fully completed.
That means that it's actually done and an English version actually EXISTS =) WAHOO!!!
I'm not quite sure how he would be able to stop his software from being used more than once tho, I can't think of any possible way myself.
Do you know how he is planning to do this?
same as the EC5W/A software translation for the sumitomo box in the legnum that I have here and was given simply by asking.
two matching cds would be enough to stop it I figure.
Cheers
Andy
mate i picked up a v35 03 model about 3 months ago and have been watching this site for that long,
please keep me in the loop once the software goes live...
i cant wait to be able see english on that screen
It'll be a logistical nightmare for Andy to keep track who need to be kept in the loop when it's finally released.
Those you who are new to the forum I suggest utilize the forum's thread subscription, just make sure in your profile you enter your email and when Andy or someone post that the software is available, you'll automatically get an email notification, with a nice preview of what is being posted about.
Done, the mods should delete non related items like the type of kits to choose at the beginning of this thread
Ok, I'll do that too, thanks for the good idea =]
picking up my v35 on monday, so started searching info on how to fix the jap dash issue and what can be done to the car..
i read from first page to the last... getting more and more intense and excited for this conversion..
Hopefully, we can get this update very soon :rolleyes:
    • So for the wide band is a Bosch 4.9 correct for the Link G4+ along with a Can bus? Just get the Link gear or is generic ok too? Eg here: LINK LINK DIGITAL WIDEBAND CAN MODULE WITH BOSCH 4.9 SENSOR : KYP Performance House
    • Bit difficult to follow. Have a look below and see what the standard R32 layout was like. Note there was a restrictor in place immediately before "turbocharged pressure control solenoid" that, if removed, magically got you 1 bar boost.
    • I might be way off the mark here.. there must be a T junction under the manifold. That takes manifold pressure through a check valve prior to the T, one side splits out to this bleed off orifice, the other straight to the wastegate actuators.
    • Carrying out some engine due diligence before my first drive in a 260RS that has been in storage for 10+ years, and found two lines that are susposed to be plumbed into the boost control solenoid. One of the lines (the wastegate boost supply line) to actuate the gates, had a bolt in one end blocking it. The other line (main boost signal line) from the very rear of the intake manifold (RB26DETT) and runs up to the boost controller had this pill in the end of it as seen in photos. Other than the obvious (T28 Ceramic turbos might well be cooked)  Can anyone shed any light on if there is any validity at all with this mod, bleeding a constant fixed rate of manifold boost pressure off through this 3mm hole?  Is it deliberate?  Was this a 90s Jap mod done to RB26's? Or has someone just fitted this without any idea of what happens to ceramic T28s if they are not gate controlled?
