  • 2 months later...
OK i want to know if we change it back to Japanese?
I liked it better when the leaf worked the other way and old fuel consumtion calculation.
Yes you can. I will send you a japanese dvd rom for your one. Ive got a dvd rom that works fine just couldnt change it to english if you want to swap.
  • 1 month later...
  • 3 weeks later...
Just wondering, if it's not too late in the development cycle, can the fuel screen for the Series 2 be left as km/L?
OR if it is to be changed to L/100, can it be that the leaf goes from bad (bottom - red) to good (top - green) economy?
I guess I just relate a green leaf to good fuel economy. A bit OCD I know, but I use that economy screen All. The. Time. :)
  • 2 months later...
ive been searching this site for an hour and cant find the answer to my question
how do i get the secret diagnostic page to come up on the navi screen? i thought it was as simple as holding a button down as you turned the ignition on....
and can the answer to this please be put in the "read this first" sticky thanks
How long is "a while" estimated to be Brad? A year? Six months?
Also, since it is going to be a while, any chance (broken record time) that he can leave the economy screen as km/L?
I never get an answer Fedor just says he is busy with it. If Andy reads this he can ask Fedor about the economy screen.
thanks brad
any chance i can buy a navi disc off you?
I just have to get more dvds so I can copy it or you can bring your memory stick over and I can give it to you and you copy it onto disk yourself
    • Yeah, I don't believe the M35 uses a deadhead system.
    • Have you done your thinking backwards? 3 bar, 43.5 psi pressure drop being the presumed specification for an injector, means you need 3 bar upstream when they are firing into atmospheric pressure, and more upstream pressure than that when on boost (you add your boost to your rail pressure to maintain 3 bar across the injector) and you need..... less pressure upstream when you have vacuum in the manifold. So, presuming that you're idling at -10 psi, then you only need ~23 psi in the rail. I realise that I did not need to say all of that to you specifically Matt, once you'd realised your mistake. It's mostly there for complete clarity for others.
    • Have you reached out to the guys at Spool Imports? They are a Ross dealer, I can imagine they would have the rings just sitting on the shelf (I could be wrong).
    • There's one for sale at Grand Auto Wreckers in Lonsdale (SA), for .... let's suggest the sum they're asking for will make you cry. You may have to embrace the idea of modifying the rear subframe to accept some other diff. You could probably find a way to wangle a shortnose into there, with a custom rear adapter and some sort of shenanigans to relocate the front mounts. This has probably already been done by others, so there might be some guidance available as to how easy/impossible it is, out there in the googles. But you possibly needn't restrict yourself to Nissan diffs if you're going to contemplate that. There are similarish Toyota diffs, possibly some Euro ones, possibly some Seppo ones.
    • The ball joint taper and arm taper have to match angle and diameter, but just doing the bushes is a much better option.....seems like the industry moved to "it is cheaper to replace the whole arm than take on the labour for changing this bushes", glad the aftermarket supports it
