  • 2 months later...
OK i want to know if we change it back to Japanese?
I liked it better when the leaf worked the other way and old fuel consumtion calculation.
Yes you can. I will send you a japanese dvd rom for your one. Ive got a dvd rom that works fine just couldnt change it to english if you want to swap.
  • 1 month later...
  • 3 weeks later...
Just wondering, if it's not too late in the development cycle, can the fuel screen for the Series 2 be left as km/L?
OR if it is to be changed to L/100, can it be that the leaf goes from bad (bottom - red) to good (top - green) economy?
I guess I just relate a green leaf to good fuel economy. A bit OCD I know, but I use that economy screen All. The. Time. :)
  • 2 months later...
ive been searching this site for an hour and cant find the answer to my question
how do i get the secret diagnostic page to come up on the navi screen? i thought it was as simple as holding a button down as you turned the ignition on....
and can the answer to this please be put in the "read this first" sticky thanks
How long is "a while" estimated to be Brad? A year? Six months?
Also, since it is going to be a while, any chance (broken record time) that he can leave the economy screen as km/L?
I never get an answer Fedor just says he is busy with it. If Andy reads this he can ask Fedor about the economy screen.
thanks brad
any chance i can buy a navi disc off you?
I just have to get more dvds so I can copy it or you can bring your memory stick over and I can give it to you and you copy it onto disk yourself
    • Hey crew, Failed my WOF cause of a lower control arm, and I've decided to hit both arms, and also the compression rods at the same time(seems they're gonna be the most likely upcoming failure points from some discussions with the lads over on the G35 reddit). I've looking at these form Z1:  https://www.z1motorsports.com/front-suspension/hayaku-automotive/hayaku-g35-front-compression-rod-p-40716.html https://www.z1motorsports.com/front-suspension/hayaku-automotive/hayaku-g35-front-lower-control-arm-p-40674.html I asked Z1 if they'd work as it's the same platform, just RHD vs LHD. I basically got told "Lol dunno". Specifically they aren't aware of any difference but can't guarantee fitment as they haven't done it on a 350GT. So guess I'm asking is if there is any issues with using 2005 G35 coupe suspension parts on a 2005 350GT coupe? Orginally I thought it could be something in the way of the arms that each control arm is designed to be positioned around, but that'd be an engineering nightmare for Nissan needing two different shaped control arms 😅
    • ^ This. The mode door actuator is a common failure, as is the actuator and/or the actual valve for the coolant flow control valve. I also don't know how available the mode door actuator is these days. I've been meaning to look into it and get one from wherever is possible, to keep in the shed for the rainy day when mine eventually fails. Anyway, the advice to you is to search the usual NOS part supply places, or even just go to Nissan and see what they list.
    • Have you got a pic of the actuator? My guess is that unit has failed internally and was flopping around, so the previous engineer who owned it forced it to be fully open to cold air (blocking the heater core path). As far as you can tell, is anything else wrong in the system? Likely you just need a new actuator (not sure how available they are) and then "installation is the reverse of disassembly"
    • I'm happy with the Lsailt unit that I put in, it puts full Android on the top screen so you can run whatever Nav and other Apps you want, while still existing inside the factory functionality like automatic reverse cams, audio input switching, retains factory bluetooth etc. Not cheap and the install was moderate (not simple, not hard) Yours is a V36 not V37 though right?
    • Yeap, all the NC's that I originally looked at that had a hard top were PRHT, which makes the roof line look horrible, hence why I said nope to them My only caveat for another MX5 was it needed to have a hard top, and initially I didn't think you could get a detachable hard top for the NC,  like my NB had Again, a big thanks to Matty for helping me source the detachable hard top for my little girl, they are as rare as hens teeth in Australia, and the few people who have them, keep them Also to Greg, for initially pointing me in the NC direction NC PRHT 🤢🤮 Not mine (I really should take more photos of my car), but a NC with the detachable hard top 😁 To me, the difference in how the detachable hard top roof line looks, and how it actually follows the bodies lines, like they do on NA's and NB's, is chalk and cheese compared to the bulbous looking PRHT
