Valve Springs
HKS-R33
 Share
Hey, im looking at getting some bigger cams for my r33 gtst and i wanted to upgrade the valve springs while im doing it.
The cams im looking at getting are:
HKS 256 8.8mm lift on the inlet
HKS 264 9.0mm lift on the exhaust
I wanted to get the tomei valve springs but they say they are for 8.8mm lift only. They have another set which is 10.25mm but its for solid cams only. Now i know that if i go too hard of a valve spring you can damage the valves/valve seats so i want to know what the best combination is.
Also, I was wondering if i would be better off going for a solid cam setup?
I'd like to know the answer to this aswell.
You doing any head work while putting the cams in? I've heard that making the exhaust side of the head slightly bigger and putting in some oversized valves gets good results. I think the RB25 Neo's have the slightly bigger exhaust ports and valves.
Why a larger exhaust then inlet?
Apparently the exhaust valves on RB engines are a bit small when running big boost and it helps this problem a little by having more duration on the exhaust cam.
Anyone know anything about which valve springs to use?
Mike.
Does anyone have anything constructive to add?
Or does anyone know if tomei valve springs will be ok for cams with 9mm lift
Tomei springs would be fine but Spoolup is on the money. I think he has them bloody cheap too!
I thought I was being constructive.
I have used Performance Springs in three different engines and never had a problem. Current engine turns to 8000 rpm everyday - numerous times.
yea i was wondering y u have bigger ones on exhaust?!?!
on nengun they do that too. but thought it was a typo. wouldnt it be better to run 2 of the bigger sized ones. instead of 2 cockeyed sizes??
fyi...any springs out of the nengun catalogue is sweet.
their tomei springs are pretty cheap at about $400, same with solid lifters.
if your going bigger cams dont leave home without them
Edited by r33cruiser
Hey mate, sorry about my comment, when you said "Performance Valve Springs" i thought you were meaning any brand is good. I didnt know there was a brand actually called 'Performance Valve Springs".
How do i get into your website, it doesnt seem to be working. Would you be able to PM me a price on the valve springs.
Thanks for your help,
Mike.
i thought u didnt even need valve spring upgrades for 9.0mm lift????
isnt 9.0 a step 1 cam shaft?
Im not too sure if they are step 1 cams, but im pretty sure its recommended to change the valve springs.
The tomei poncams 256/256 8.8mm lift dont require the valve spring change, but its probably better to change them anyone to avoid any valve bouncing issues etc.
Mike.
...on nengun they do that too. but thought it was a typo. wouldnt it be better to run 2 of the bigger sized ones. instead of 2 cockeyed sizes??...
Going big on the intake as well affects idle, low end, emissions etc, whereas big on exhaust seems to reap benefits without so much negatives.
As mentioned RB's have reasonably poor exhaust port flow (comparatively to intake)
Agreed.
I'd be going HKS 256 on inlet and HKS 264 on exhuast with slightly oversized exhaust port, and that's what i will be going with in the future :banana:
can anyone confirm if the neo do indeed have larger exhaust ports/valves? Are they bigger the the rb26? Im getting the performance springs installed along with tomei 260 cams. Is it the rpm or hp that start to cause issues with aftermarket springs? It has rb30 bottom end, 8k rpm limit and t04z with 2bar. And spoolup can you confirm what material is used for the NEO lifters?
cheers
 Share
    • Wow mate that's huge, congrats. Glad you found better people to deal with and all seems like it's going in the right direction.
    • The best setting for street is what gives the best tyres wear for your driving style Different tyres like different camber You want the whole surface of the tread to wear flat, if the inside of the tyre is wearing more than the outside reduce camber settings For toe, have the minimum amount to give the handling you want Caster, from my experience if you can adjust it, is as much as you can get without clearance issues And while -2.5° of camber on the front might work well with good tyres for "spirited" cornering, it may be too much for a street car Lots of front camber will effect braking Just like to much rear camber will effect rear traction (rwd), and braking  When I set my Bogan Cruise Ship (VX SS) up for drags I tested how much tyre width I actually had in the rear by doing a hard launch (skid), it originally had -1.5° in the rear, and you could see that the tyre wasn't putting down alot of the tread, I maxed out the settings to get as little camber as I could with the OEM adjustment and some camber bushings and got it down to just under -0.5° with 0 toe, that gave me a fair bit more "rubber on the road" and helped it hook up for my 60' and my 0-100kph And with -1.5° in the front the big old boat handles fine on the street and my tyre wear is nice and even on both front and rear tyres (currently Hankook RS4's) As for semi slicks at the track, again, it depends on alot more IRT the suspension, the track and lots of other things, so, I'll leave that up to people who have more experience, especially with a AWD In saying this, street settings are pretty easy, just look at the tyre wear Meh, Necro thread, it's late at night, and I has been drinking beer
    • Thought I'd give an update. There needs to be scarce details in some areas due to ongoing discussions. Here's the journey of trying to make the booked registration appointment (again). Sent a complaint to Car Inspect outlining the concerns and made some demands. Went to a service center in Geelong, got assaulted with bullshit items on the RWC, as you know. Tried to quote $2.5k AND wanted a structural report Only seemed to be one place around Geelong that does them, they demand $495 just to end up telling me it's f**ked, at least $11k to fix and tried to sell me his own Skyline in the process (bro, wtf?) Started stressing about what I'm supposed to do with this possible pile of steel. Awaiting that, I was sent an angel friend who works in Melbourne and knows real mechanics and body shops.  They laughed at the reported quotes (don't get work done in Geelong) Car underwent some front surgery and brought back better They then sent it to the mechanics for RWC Registration appointment is two days away at this point. Mechanics pointed out two issues: driver's seat and shocks - that's it. He offered couple options and I chose coilovers. Frantically I scoured the jungle realm that is Facebook Marketplace (again). Found what looks to be a decent Series 1 seat actually - $100 Guy is friendly, offers to bring the seat with a colleague who's heading to Geelong (thanks man, that was cool) Seat arrived, looks good. Throw it in my car and drive to Melbourne and drop it to mechanic T-1 day, mechanic reckons job will be done for the fronts only, gets it done by 4PM Mechanic heads to get the coil-overs that night as a favour to help me make the appointment Get driven to Melbourne, drove the car back - RWC Unlocked! ✅ VicRoads tomorrow, the goal is close now. 🙂
    • Gtr are still available through the heritage program but don’t have the wiring
