  • Replies 3.9k
Posted Images
This proves my suspicion that, oh you work it out for yourselves....
http://www.carcentral.com.au/20080506589/m...-indy-2005.html
after the farce they created at A1, you would think these bastards would have given up the team orders game. But Rubens now saying that he was 'invited' reinforces what people already think about this team.
i feel now fully justified in booing the cars and drivers for the last 10+ years
it just proves that hamilton has no talent. it's all just lots of practice made him good. and his dad is a wanker. tried to pull a nice second gearie up his own street and fked it up nicely into a playground. had there been kids playing there he would be in some serious sh1t.
well... lewis is on a roll then
blitz'd quali by 6 tenths. BMW have again chosen to pt 4 laps of juice into Kubica's car.
Ferrari's are really struggling in the final part of the lap, Massa and Heikki no where near their team mates, but they've probabl gambled on early saftey cars dn filled up for a few more laps thn the others
Good session tho, the track breaking up is going to be pretty tricky tomorrow
what happened to webber? going by his times in Q1 and 2 relative to the others in those sessions he was looking good for 7th or there abouts but didn't set a time in the last session... :)
he spun it after setting his time in Q2 and clipped a wall, damaging the suspension
    • After using a protractor for an actually accurate assessment of what is required,  and by NOT using my uncalibrated eyeball I worked out I need a 25° silicone bend from the TB ro the MAF, but, my choice was either a 30° or a 23° (23° is a weird spec), so I grabbed the 23° one from Raceworks I also grabbed 1mtr of 3" straight from Just Jap, I needed 350mm, but they only had 300mm, or 1mtr lengths....meh Also ordered a 1/2" hose bulkhead fitting from fleabay, this has a smoothish mushroom looking head (they are designed for below the water line of boats) that will fit inside the bend, the hose bit and threaded bit looks to long, but nothing that a hacksaw cannot fix if required, the hose will then just get jamed on the threaded bit up to the retaining nut Fingers crossed and the unsightly amount of hose clamps will be reduced down to 4 once all the parts arrive
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
