Theoretically, 2.5kg each week is going to be over 60kg in 6 months. Assuming he can pull off the increase each week, that'll be 200kg for reps midway during this year...
P.S. catching you in deads Troy. I pulled 150 the other day, after squats and deads. I reckon fresh I might give you a run :P
Because Birds
This.
I have been considering putting squats on my push day...where they technically belong...to give deads a bit more potential. Problem is, after all the chest exercises on push day, I'm utterly sapped of energy.
Truth be told, I added deads and squats to my routine at the same time, so always just did them one after the other on the same day. There's interference, but I'm still progressing in both exercises, so maybe when I plateau or get sick of fainting I'll swap one over.
My deadlift is currently at 140kg for 5 reps.
Not great, but not doing too bad either.
Its going up steadily with your 5x5 program
Are bench and squats moving at a similar pace?
on another note, i have decided i enjoy doing back workouts the most. Nothing better than rows, deadlifts and weighted chins
Edited by Mitcho_7
Bench is being stubborn, but I'm incorporating heavy negatives on the smith machine to work through my sticking point.
Squats are slowing in progression, sitting on 92.5kg full depth, will probably try for 95 tonight.
Don't forget the forearm pump from back workouts too Troy!
so my Mrs bought me an Inzer lever belt, Tshirt and knee wraps for Christmas... Thanks to Markos! lol
squatted with the belt once before I left for Vic Harbour with a bunch of mates for 2 weeks of sun, beer, food, beer, sand and... beer
got back yesterday, hit the gym today... oh dear..
one week off is great every few months... two weeks off? not so much
What gym Nick? 2 weeks is ok a couple times a year, but its the 2 weeks Plus the beer that does it...
Not enjoying pasta of late, feel so blah afterwards.....
Big workout tomorrow; bribing my boys to behave in the small kids room with a reward of a cinema night - haven't gone in there yet with the kids in tow.
155 as of tonight!
And my gym has chalk now...wtf Genesis...
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
