Troy you muppet.. the deadlift for reps is with 100kg.
and you want to 1.5 times body weight making it 115?
but don't want to hurt yourself?
Please explain
1.5BW was just a suggestion (which for me comes to 109.5kg anyway). It was more to even the playing field. Perhaps work out what ratio of bodyweight the 100kg reps were for Joey and then apply that to everyone.
These vids are from 2007, weighed ~60kg
http://youtu.be/JmvveXH5lrw
Ps. do not deadlift like that ^ I have 2 bulging discs and I'm pretty sure the way I deadlifted back then is what caused them.
it's rare to have someone that can OHP body weight so I doubt you'll get people even able to do a single.
I certainly can't.
Pffttt...What is this ' I certainly can't ' rubbish.... you can and will ha ha..... People just need to add this as a goal.
If you are able to put time into bench press you will do well to train to press your body weight for reps.
Besides if you can train yourself to this goal , my bet is your bench will increase.
Not a proper strict press anyway
Sit down an do it, stops punters from hurting themselves initially before they do the standing version. Standing strict is just without the leg drive but, that is also a good version of the press worth throwing into training.
    • Hi. Yeah thanks. Car is already at tuners and it staying there to resolve "many" issues they do not like. So it is in a good hands. Getting a good tune on that Nistune ECU too so the car would be good. Just needs a little tune up and love.
    • Probably gonna remove manifold and turbo. I’m not sure if I can get M12 x 1.5 air tight. Could use high temp Loctite 246 or something similar, but I don’t know. Maybe it’s just best to remove everything again and weld an 1/8NPT on there instead.
    • Yeah, saw the ratios, not impressed. Would like the punch I have in the first gears now. With those ratios it won't be the same.  Also want the h pattern gearing, or at least a quiet gear set that don't need to come apart for service each year. Looks like the only "reasonable" way Is a 8hp70 transmission, but where is the fun in that🤷‍♂️
    • Hey mate, really appreciate the help. Have been looking pretty extensively myself and was certain they were retro fitted, but then ended up finding a 4 door with what looks like the same side skirts or at least the closest I’ve seen. The photos from the Offset Kings event at Sunrise 2016. https://fatlace.com/offset-kings-okayama-at-sunrise/
    • Isn't there a PAR engineering gearset that has closer to stock ratios? And they claim they'll do whatever ratios you want.
