Troy you muppet.. the deadlift for reps is with 100kg.
and you want to 1.5 times body weight making it 115?
but don't want to hurt yourself?
Please explain
1.5BW was just a suggestion (which for me comes to 109.5kg anyway). It was more to even the playing field. Perhaps work out what ratio of bodyweight the 100kg reps were for Joey and then apply that to everyone.
These vids are from 2007, weighed ~60kg
http://youtu.be/JmvveXH5lrw
Ps. do not deadlift like that ^ I have 2 bulging discs and I'm pretty sure the way I deadlifted back then is what caused them.
it's rare to have someone that can OHP body weight so I doubt you'll get people even able to do a single.
I certainly can't.
Pffttt...What is this ' I certainly can't ' rubbish.... you can and will ha ha..... People just need to add this as a goal.
If you are able to put time into bench press you will do well to train to press your body weight for reps.
Besides if you can train yourself to this goal , my bet is your bench will increase.
Not a proper strict press anyway
Sit down an do it, stops punters from hurting themselves initially before they do the standing version. Standing strict is just without the leg drive but, that is also a good version of the press worth throwing into training.
    • No requirement for JDM vehicles,  which the 33 is, maroney label only needed in the US market for new cars I believe (Federal law stuff) Google knows all
    • Hopefully you can just unbolt them, thank them for their service, then bin them and not replace them Apparently the sensors like to set them off with only minor impacts at low speed It looks like they do a delete kit for some of these, but, it is costly
    • I hope it's actually possible. This is a write off in insurance world.
    • Yup. 2-way with shallow ramp angles. Still works.
    • That was the first session so not a lot to take from the day. It was low 20s ambient and the coolant had got to 110 (and obviously had some pressure!) so that still needs to be addressed. I haven't downloaded the data yet but will. I had refilled the auto trans with Redline DT6 because it claimed the best viscosity I could find at 100o. It wasn't really long enough to get a good feel for that; while the trans got to 100o in the session it still wasn't shifting crisply as I hoped. I think I'll try a few more sessions before judging. No steering motor overheat but I'd hope not in only 1 session! But finally the suspension; it was night and day over the standard stuff and the car was a couple of seconds quicker on the same crappy tyres, which is a huge difference. I'll stick with that and get some sway bars and a mechanical diff sorted too and see how that all goes together
