Sorry but that still doesn't tell me why.
Don't apologise...
Not taking anything away from his effort, but look what happened when Ghosty reached the end of his rep range...his back and core wobbled and he stumbled around (forcing legs out of their previously locked position) trying to catch the last rep. A less...injury prone...way to standing overhead press, is one leg in front of the other and knees slightly bent. Done properly, you'll never move around like that.
Don't apologise...
I'm not apologising it's just a figure of speech.
Splitting your legs may take some pressure off your back as it stops you from leaning back as much. However, this has nothing to do with knees being locked out or not.
And leaning back has nothing to do with the exercise, it has to do with the person. If you are pressing overhead and start to struggle, you can either stop, start push pressing, and/or lean back to try and reduce the rom. Just don't lean back stupidly and you'll be fine.
I personally think flexing your quads gets more muscle fibres activated and provides a more stable base and core. And to do this your knees have to be locked out.
And to finish, the exercise 'military press' is done with legs locked out. If you are doing anything else you are not doing a military press.
Don't apologise...
But that was due to bad technique/overdoing it. Not because of the intended way to do it.
Edit: husky got me.
Edited by jangles
I'm not talking about him leaning back a bit, that's fine. I'm talking about the wobble in his midsection that is a result of pushing the set til failure and his back/core being the first part to give way at the sign of a struggle. With straight legs, your back and core take the full brunt of it, as that's the only place flex can occur. Bending knees slightly, gives you more control over the movement; allows you to use your leg muscles to maintain a straight back and regulate/reduce/counter wobbles on the Y axis when you start to struggle.
As for military press defined, in it's strictest sense I'd agree with you...but people do it sitting down and call it that, so as long as you're not driving with the legs when splitting, I don't see the harm in a slight variation to prevent injury when lifting heavy.
The military press/strict press was a lift that was done at the olympics. These guys were pushing 200kg's, and they had to have their legs locked.
Doesn't matter what people do or what people call things, the military press is done standing, with legs locked. It's not made up gym rules, it was a sanctioned olympic lift.
If you want to military press, stand up, knees locked, and don't bend your back too far. If you feel you are straining your back, stop the exercises and/or drop the weight. Work on your core strength and lower back strength.
If you just want to overhead press, then doing whatever way you want. Bent knees, split legs, sitting down, upside down....who cares.
I said I agreed with you about the definition of it? I just don't care if people think what I'm doing isn't military press, I'd rather save my back. I'm doing it for the exercise, not the title. If you want to talk semantics, I originally referred to bending the knees during overhead press movements, not military press specifically.
Anywho, I've already broken my rule of one argument + rebuttal, so time for me to let this one go.
I'd rather strengthen my back.
Change the way you think Birds ;), if something is weak then make it strong, don't avoid it.
/gah simon beat me to it
Edited by GHOSTrun
Current stack:
Synthol & some horse hormones that I got from some bloke who wanted to keep his name secret so he called himself chestbrah.
Seriously, eat clen and tren hard. Ty men.
Strong post to join date
Strong AVI
Strong username
strong everything
This guy.... uses every damn quote that annoys me from Facebook pages
Edited by Dani Boi
From Facebook pages...? L2internet my friend. I loved these quote UNTIL I saw them on Facebook, at which point all the little social media faggots cancer ruined them.
I'm sorry for offending you Tom.
Strong AVI
Strong username
strong everything
hehe ty men.
Some people just want to see the world burn. I'd agree with you there though, almost everything from 4chan (/fit/) included it's hilarious. You would NEVER hear anyone talk about "epic" things or "memes" circa 07.
Yes your bulging discs are doing a great job of that. Strengthening doesn't fix bad form, correcting with proper technique does. I'm not avoiding any weakness here...the back and core get worked just as much in my method, only less susceptible to injury because it's a stricter movement.
    • End game is to: - Remove all the slop from old worn parts - Adjust setup so that the wheels actually fit and the car is drivable (currently it is not because of the extreme rubbing on the guards).   Progress over the last couple of days, removed the rear hubs! Next steps: - Buy bushings - Replace bushings/bearings on hub - Reinstall
    • Cracked deck  And other cam snap stuff
    • A few random issues have popped up since my last update. My WMI pressure sensor failed within about 10 minutes of it seeing liquid. It was a 20$ China special, so I'm not surprised. My name brand replacement should arrive today.  My power steering assist also decided to crap out last weekend. The usual, works for about 60 seconds after starting the car then I lose it. I dusted off my old copy of NDS and connected to the HICAS ECU. Code 4 for assist solenoid.... I tested the solenoid and it's fine.  I knew the day where my HICAS ecu would crap out would come, and I welcome it. It was the last HICAS part on the car that is now in the bin. I've ordered an SSR and I will control the power steering solenoid with my Haltech ecu. It will be nice to have proper speed referenced assist again after all these years.
    • Haha I just finished the last season of TPB: Jail last month. I'm happy they're still pumping out episodes.
