Deads are coming along again after a deload, only warm up weight for some but on my last 2 sets today I managed 5 x 150kg then 3 X 160kg, I should have only gone to 155kg and will drop my last set to 155kg next time.
I did manage a good 270kg from the top of the knee to lock out on my last set of 5 x 1 of them though, started at 250kg and went up by 5, I did make some noise though.
I am going to rotate between 3 x 8 deficit and 5 x 1 knee height to try and keep it slowly going up.
Sorted out all those injuries that prevent you from progressing yet Dan?
Is this supposed to be a thinly veiled jab somehow? Despite me having already said I wouldn't be lecturing anyone based on having injured myself with poor form/mechanics? If so, lol
100kg x 7 on bench, I think that's a pb for me!
Nice job dude. I'm slowly bringing up that 3rd incline set, started out at 54kg and the bar was very hard to control, now got about 75 on it and managing 10 reps (just) after doing 10 then 8 at of flat something just over 100, think it's like 102.5 or so.
Thinking I might drop the second flat bench set and swap in another incline set as I don't want too big man titties (I have cut eating also to assist until I can do some decent cardio again).
Edited by ActionDan
Mine are big enough now. I don't want them to be any bigger to make it easier when my metabolism slows more and I find it harder to change weight as easy.
My thinking is that as I get older I'll slowly lean off a bit over time to avoid sag if possible lol
Hahah, that's my thinking too, but I more so mean I'll step down in weights and move more into cardio as I get older. For that leaner less bulky look and hopefully that will help keep me tight like a tiger.
What's a better game plan then, legit question.
My theory is if the muscle is a little smaller through lighter weights higher reps and my body fat is lower through cardio and diet I should be OK.
I know muscle itself doesn't sag but the connective tissues do. Less weight on those would help.
Less fat is always going to help.
All old people sag - fact. No training will avoid that. Even skinny low fat triathlete oldies sag. You either get lucky or you don't.
Look at Stallone...as roided up as he is, he's in top nick for a man in his 60s...very defined...but you can see the age; you can see the sag. Nothing can be done. Deal wit it.
Keep the fat off and that's the best you can do.
    • I went and found the actual FSM again (Yeah, I squirreled...) Screen grab of the FSM for M35. 51PSi with engine idling.
    • I thought the same too, and more than happy for others to bring another source for what it is. Just throwing so me caution out there, as potentially an extra 30% current needed than expected.   Well worth more investigation, but right now, I'm going over my Cypher knowledge while Expendables 4 provides mundane noise in the background, ha ha!
    • You still around Terry?
    • If true then....wierd. That's a very high base fuel pressure for a shitty old early 2000s Nissan.
    • I may have my math slightly wrong, I'm not double checking that again, but the factory spec for fuel pressure is to set it with the engine IDLING (in vacuum). That spec is 51PSi while idling. So now add +10psi for atmospheric, and +7 for 7psi of boost, and we need 68psi of fuel pressure at full noise, and 51psi idling. That's according to the FSM I found last night for M35. So MINIMUM fuel pressure should be 51psi and it climbs from there.
