Did my 1RMs tonight - 230kg squat, 200kg deadlift, 120kg bench, 70kg press. Stoked about it - I hit all the goals I was after, and squatted more than I thought I could. 8 or so months of PTC beginner routine and eating LOTS of protein.
Now for my 5/3/1 to begin!
Paradoxically the only thing to cure my calf doms was squatting.
Edited by bozodos
I always go below paralell Birds, I try not to have hamstring touch calf though. Still at 120kg or so unfortunately - diet started to get a bit out of hand again lately. Would have liked to got 240kg squat for double bodyweight, but I didn't want to fail it.
Can't really remember my starting numbers, they were pretty damn low though - when I started the PTC routine I was benching around 40kg, squatting 100 or so, and deadlifting 80. I had to do dips with ~90kg assistance, which I can now do bodyweight.
I've started doing stair / hill runs and sprints to get some conditioning in too.
Sensational man, really happy for you, so jealous of the Squat and DL =D
Happy because you've worked hard for it and happy because your attitude has been excellent since the beginning, no bullshit, no ego, just getting in there and getting it done.
*BroHug*
  • Like 1
Good work Boz. Only real powerlifters squat more than they deadlift!
Don't need to worry about knee wraps but a belt for squats is really handy, especially once it gets heavy. Just helps you keep tight and makes the whole thing a nicer movement.
It doesn't really protect your back and only maybe gets you a handful of kilos but it's definitely worth having.
Thanks Nick. I'll look into a belt - my Chuck Taylors are here so at least I'll have some reasonable footwear. I've had a strong squat and legs since I started, lucky I guess.
Been agonising over 5/3/1 assistance templates, I decided on Simplest Strength due to it having a squat and deadlift variant more than once a week, and not eating enough to give BBB a hard go
5 sets of 5, there's a heap of different programs, Markos always used to reccomend it more for lifters beyond the beginner stage, and I'd agree with that.
Common examples of programs are: Stronglifts, LP Greyskull, Madcow, Bill Starr's 5x5.
Cheers boz, I had a quick look online but thought id ask my fellow gym sauers. I had a chat with a 50 year old at the gym today. This bloke is bigger than most blokes at the gym. He said for me to shake up the routine ( 5x5, pyramid etc ) he swears by the pyramid program.
http://blackironbeast.com has a good calculator for 5/3/1.
I have started the boring but big program 4 day, very similar to the program I was doing but all the % and sets are done for you.
I will roll with this for the full cycle (about 9 months worth) from now and see how it goes, 2 days in so far.
I like it as it seems its a "get strong for dummies" type of thing, which suits me down to a tee.
    • All 3 I guess. The car came with the JASI Aero 4 door Type R Full Kit unpainted so this was one thing at the top of my list to complete then I noticed there were body panels parts for this kit so i picked them up along with some black mesh to fill in the front bumper and front side air vents. car is at a paint and body shop atm completing this work. Next I will be addressing the internal bells and whistles, great summer project I can do with the kids.  full interior removal - ,boys car sound deadening - pads and spray ,boys stereo, sound, lighting - Big 3, GTT or bigger alternator ,kids head lining - dye black add star lighting mod ,daughter. That's it for the next 5-6 months. I have some motor maintenance  work i have to plan out. oil filter relocation, gaskets, mounts. beyond that, mind is starting to turn over if i can use a DET intake plenum, block off turbo ports & pipe in a air intake.
    • roller coaster of a ride. Alarm system was removed & main harness was repaired where possible. still no fix just random successful starts. moved on to the replacing the ignition switch and relay. well all this troubleshooting & repair has been going on, the car is at a paint and body shop being pushed around. Ive been going down there on odd days after work to get it sorted.
    • 5th November if you want to come out for a spin wakfield
    • PROBLEM WAS BROKEN COOLANT SENSOR!!! Replaced with a new one and its running mint.
    • I think he was only proposing to use the wire, not the sender. Simply because it runs from the right place to the right place. Personally, I wouldn't hack up the factory wiring like that. I'd just lay in the Defi loom.
